Sealing a rust patina with clear coat keeps the aged look while stopping the rust from spreading further, because DiamondFinish Clear and KBS MAXX Clear both block moisture and oxygen from reaching the metal underneath. KBS recommends either coating whenever a customer wants to preserve, not remove, a rust patina.
| Products | DiamondFinish Clear or KBS MAXX Clear |
| Coats | Minimum 3 thin coats for bare metal rust protection |
| DiamondFinish Clear cure | 50 to 82 degrees F, handle after 1 day, full cure at 7 days |
| Prep | Wire brush loose flakes, clean with KBS Klean, dry completely |
Patina is a thin layer that develops on the surface of metal, wood, leather and other materials, giving an aged look. Patina can result from age, exposure to sun and moisture, and wear, and it can also be produced artificially with chemicals, specialty coatings and abrasion. Rust can be considered a desirable patina, but left unchecked it can eventually eat metal away completely. Every now and then we get inquiries from customers who want to keep the patina look of rusted metal, even heighten its appearance, while also protecting the metal from further rusting. When asked for advice on coatings that can achieve this, we recommend DiamondFinish Clear and KBS MAXX Clear for rust protection using clear coat to keep and maintain a rust patina look.
Rust Protection Using Clear Coat
To stop rust, rust must be separated from oxygen and moisture. DiamondFinish Clear and KBS MAXX Clear coats can be used to seal rust and provide rust protection with a durable, impervious barrier that blocks moisture and oxygen from reaching metal surfaces. By using a clear coat for rust protection, the rust patina look will remain, but the rust will not continue to progress.
Preserving Rust Patina with Clear Coat
Rust patina can be delicate. Since rust can be powdery or flaky, it is susceptible to being marred by impacts and abrasion. A clear coat provides a hard, durable, protective coating that can preserve rust patina. Another benefit of sealing rust with a clear coat is that the rust will not be exposed, so it will not rub off onto clothing and other items.
Enhancing Rust Patina with Clear Coat
A clear coat brings out richness in rust colors and gives depth and luster. Applying a clear coat to seal rust patina gives it a beautiful wet look and adds a darker tone and contrast to the color of the rust.
Protecting Metal Sheets from Rust While Preserving Patina Rust
A customer told us about a wall he constructed in his basement using steel sheets that had patina rust. He said he just wanted to coat it with a clear coat to keep the look and prevent future rust. For this job, we recommended DiamondFinish Clear.
About DiamondFinish Clear
DiamondFinish Clear is a one stage, single part (1K) moisture cured clear coat that can be used indoors or outdoors. It provides a beautiful, crystal clear appearance. DiamondFinish Clear is made to be extremely durable and hard, yet flexible. DiamondFinish Clear is UV stable and will not yellow, crack or peel.
DiamondFinish Clear is offered in cans for brushing, rolling or spray equipment. Since it is a single part coating, no mixing of two components is necessary; just stir and it is ready to go.
About KBS MAXX Clear
KBS MAXX Clear is a single stage, two component (2K) polyurethane clear coat with superior impact resistance, weather resistance, UV permanence and gloss retention, plus fast drying characteristics. Like DiamondFinish Clear, KBS MAXX Clear provides a beautiful, crystal clear finish. KBS MAXX Clear and the KBS MAXX Activator Medium are easy to mix and yield a clear coat ready to spray or brush.
Full technical data and directions are on the DiamondFinish Clear directions page and the KBS MAXX Clear directions page.
Application Tips
- Before applying a clear coat to rust, remove loose rust flakes with a wire brush. You do not have to be aggressive, but you want to remove rust that is falling off the surface.
- Clean the surface with KBS Klean mixed with warm water in a 10 to 1 ratio (10 parts water to 1 part KBS Klean). A cloth can be used to scrub the surface.
- Rinse with water and allow the surface to dry thoroughly. It is often best to force dry to get all of the water out of the rusty surface, which tends to be porous.
- Apply a minimum of three coats of DiamondFinish Clear or KBS MAXX Clear. The number of coats can vary based on the coarseness of the rust; it is important that the peaks and valleys of the surface profile are completely sealed to prevent rust and corrosion from spreading down the road.
Application Tip
Special tip: DiamondFinish Clear and KBS MAXX Clear can also be used to seal non-rusted, bare metal to keep it from rusting.
Frequently Asked Questions About Clear Coating a Rust Patina
Will clear coat stick to rust?
Yes, when the rust is stable and prepared correctly. DiamondFinish Clear and KBS MAXX Clear are made to seal a rust patina surface once loose flakes are removed and the surface is clean and dry; they are not made to stick over powdery, actively flaking rust.
What is the best clear coat to use on rusty metal?
KBS recommends DiamondFinish Clear or KBS MAXX Clear for sealing rust while keeping the patina look. DiamondFinish Clear is a one part, moisture cured coating that needs no mixing; KBS MAXX Clear is a two component polyurethane clear coat that dries faster and adds impact and UV resistance.
Can I clear coat a patina truck?
Yes. Remove loose rust flakes with a wire brush, clean the surface with KBS Klean, let it dry completely, then apply a minimum of three coats of DiamondFinish Clear or KBS MAXX Clear. This keeps the patina look while sealing out the moisture and oxygen that let rust keep spreading.
If you are looking for rust protection using a clear coat while keeping a rust patina look, DiamondFinish Clear and KBS MAXX Clear provide long lasting durability and a beautiful appearance. If you have any questions about sealing rust with KBS clear coats, please let us know.
Related guides: How to Clear Coat Over Rust and Preserve the Patina Look, Best Clear Coat for Outdoor Metal Art, or browse all KBS application guides.
