If you are restoring a car or truck—or preserving one—properly coating coil springs and leaf springs is critical. Suspension springs face moisture, road debris, and corrosion, making them vulnerable to rust and early deterioration.
Using the KBS Klean, KBS RustBlast, and KBS RustSeal 3-step system, you can prepare and paint suspension springs to prevent cracking, peeling, and corrosion.
Why do people paint suspension springs?
Main reasons include rust prevention—sealing metal from moisture and oxygen—and aesthetics, providing a clean or custom look.
- Factory-correct OEM look in black
- Custom colors: red, blue, yellow
Common reasons for coil spring paint failures
Flex, coil-to-coil contact, excessive thickness, and moisture trapped under isolators are the main causes.
Flex-induced paint cracking
Coil springs flex continuously. Thick paints crack under stress, allowing moisture in.
Coil-to-coil contact wear
Contact between coils scrapes paint away, exposing steel and causing rust.
Excessive paint thickness
Heavy coats interfere with spring seating and may cause squeaks or uneven loading.
Moisture under isolators
Water trapped by rubber or polyurethane isolators can cause hidden corrosion.
Common reasons for leaf spring paint failures
Wear between leaves
Trapped water causes hidden corrosion.
Edge creep and capillary rust
Moisture wicks between leaves, promoting rust; thin, flexible coatings prevent this.
How to paint coil springs and leaf springs
Use thin, flexible coatings to accommodate continuous flexing. Avoid thick or brittle paints.
Best practices
- Thorough cleaning and degreasing
- Proper rust removal and surface treatment
- Thin, even coats of flexible coating
- Full curing before reassembly
Preparing springs for coating
- Remove springs from the vehicle
- Clean with KBS Klean
- Remove rust mechanically (wire brush, sandpaper, sandblasting)
- Final cleaning with KBS Klean
- Treat with RustBlast
Applying RustSeal
- Methods: Brush, roll, or spray
- Temperature: 55–82°F, avoid humidity
- Apply 3+ thin coats
- Recoat: 2–6 hours touch dry, within 8 hours
- Cure: Handle after 1 day, full cure 7 days
Top coating for UV stability
Use when exposed to sunlight. Options: KBS BlackTop Chassis Coater, KBS Top Coater. Prepare RustSeal with scuffing or self-etching primer.
Conclusion
Painting coil and leaf springs protects against rust, improves appearance, and extends component life when using proper preparation, flexible coatings, and full curing. Using the KBS 3-step system ensures lasting results.
