How to Restore Rusty Metal Patio Furniture and Keep Rust from Coming Back
How to restore rusty wrought iron patio furniture with KBS Klean, RustBlast, RustSeal and a UV stable KBS Top Coater finish that keeps rust from coming back.
Read More
How to Paint a Motorcycle Gas Tank With KBS MAXX and MAXX Clear
{ "@context": "https://schema.org", "@type": "BlogPosting", "@id": "https://kbs-coatings.com/261022-paint-motorcycle-tank#article", "headline": "How to Paint a Motorcycle Gas Tank With KBS MAXX and MAXX Clear", "description":
Read More
How to Remove Rust from a Tractor Fuel Tank and Prevent Future Rust
A rusty tractor fuel tank doesn't always need replacing. Learn how to remove corrosion, prepare the interior, and seal the tank for long-lasting protection.
Read More
How to Paint an Aluminum Jon Boat for a Durable, Long-Lasting Finish
Learn how to properly prepare and paint an aluminum Jon boat to promote strong adhesion and help prevent peeling, flaking, and premature paint failure.
Read More
How to Mix and Apply 2K Paint: It's Easier Than You Think
To mix 2K paint, measure the paint and hardener at the labeled ratio, mix thoroughly and apply it within its pot life. This guide walks through every step using KBS MAXX, a 3:1 2K topcoat.
Read More
Rubberized Undercoating: Why It Traps Rust and How to Apply It So It Does Not
Rubberized undercoating does not cause rust. It traps rust under one condition: sprayed over metal that is not clean, dry and already sealed. Here is the fix.
Read More
How to Paint a Motorcycle Exhaust to Prevent Peeling, Flaking and Rust
Learn how to paint a motorcycle exhaust to help prevent rust, peeling, flaking, and burn-off with proper surface prep, high-temp paint, and heat curing.
Read More
How to Paint a Rusty Farm Plow Without Sandblasting
How to paint a rusty farm plow without sandblasting: remove loose rust, prep the metal, seal it with RustSeal, and add a durable UV-stable KBS MAXX topcoat.
Read More
How to Restore an Engine Bay Without Removing the Engine
Restore your engine bay without removing the engine. Learn how to remove rust, prep metal, and apply durable coatings for long-lasting protection.
Read More
How to Brush Metallic Paint Without Streaks
Metallic colors look best sprayed, but they brush well with the right method. Learn why metallic flake streaks and how to brush KBS metallic colors smoothly.
Read More
How to Repair a Dusting Concrete Floor Before Applying a Long-Lasting Coating
A dusting concrete floor will peel any coating you put on it. Learn how to test, grind, repair and coat it with KBS RustSeal and KBS MAXX for a floor that lasts.
Read More
How to Seal a Rusted Galvanized Stock Tank (Even a Duck Pond) So It Stops Leaking for Good
A rusted galvanized stock tank doesn't need to be replaced. Learn how to clean, etch, and permanently seal it with KBS Klean, RustBlast, RustSeal, and BlackTop.
Read More
How to Protect a Battery Tray from Rust, Corrosion & Battery Acid
Neutralize battery acid, remove corrosion, and coat battery trays with KBS RustSeal for long-lasting, acid-resistant rust protection. Step-by-step guide.
Read More
How to Fix Hidden Rust in Rocker Panels, Cab Corners, and Body Seams
Rust behind rocker panels and cab corners is often worse than it looks. Learn how to inspect, repair, and permanently stop hidden rust with KBS RustSeal.
Read More
How to Prevent Mower Deck Rust
Stop mower deck rust with the KBS Coatings 3-Step System. Learn how to remove rust, prep bare metal, and apply RustSeal for lasting corrosion protection.
Read More
How to Get Any KBS MAXX Color in the Finish You Want
KBS MAXX colors don't lock you into a sheen. Topcoat any matte color with KBS MAXX Clear (Gloss), or any gloss color with Clear (Satin) or Clear (Flat) to get exactly the finish you want.
Read More
How to Repair Trailer Frame Rust So It Doesn't Come Back
Learn how to repair trailer frame rust so it doesn't return. Clean, treat, and seal with KBS Klean, RustBlast, and RustSeal for long-term rust prevention.
Read More
How to Handle Single-Component Moisture-Cured Urethane Coatings: Induction Time, Stirring Intervals, and Skinning Prevention
KBS MCU coatings like RustSeal, BlackTop, and DiamondFinish Clear need zero induction time. Learn correct stirring intervals, how to handle skinning, and pro tips for best results.
Read More
Best Clear Coat for Outdoor Metal Art: Prep & Application Guide
Find the best clear coat for metal and learn how to prep bare or rusted metal for a durable, UV-stable finish with KBS Klean and DiamondFinish Clear.
Read More
How to Clear Coat Taxidermy with DiamondFinish Clear
Learn how to clear coat taxidermy with DiamondFinish Clear using an airbrush or spray gun. Crystal clear, durable, UV-resistant protection for mounts.
Read More
How to Apply Bedliner to Your Jeep Floor: Prep, Seal, and Protect
Step-by-step guide: remove carpet, treat rust, and apply KBS Bed Liner to your Jeep floor for a durable, waterproof interior that holds up to real-world use.
Read More
How to Fix Rust on a Truck Frame and Stop Rust for Good
Learn how to fix rust on a truck frame with KBS RustSeal, RustBlast, and Cavity Coater. Step-by-step prep, coating, and cavity protection to stop rust for good.
Read More
How to Fix a Rough, Faded, or Oxidized Water Slide - Restore Speed and Performance
A rough-feeling water slide is usually caused by fading, oxidation, and surface wear breaking down the original gelcoat, creating drag and slowing riders. Restoring a smooth, high-performance surface requires proper cleaning, preparation, and
Read More
How to Paint a Motorcycle Engine So It Doesn't Peel, Flake, or Burn Off
How to paint a motorcycle engine that lasts: degrease with KBS Klean, etch with RustBlast, then coat with Motor Coater, a 500F enamel that needs no primer.
Read More
How to Paint an Axle Housing the Right Way: Prevent Rust and Peeling
Rusty axle housing or peeling paint? Learn how to properly refinish an axle housing to stop rust and prevent paint chipping and peeling. This how-to guide covers cleaning, rust treatment, and coating for durable, long-lasting protection.
Read More
How to Repair & Stop Car Floor Pan Rust | The Ultimate DIY Guide
Fix floor pan rust with or without welding. Learn how to assess damage, choose a repair method, and permanently seal the metal with the KBS 3-Step System.
Read More
How to Reseal a Gas Tank Inside and Out to Stop Rust
Reseal a rusty or new metal gas tank inside and out with KBS Klean, RustBlast, Tank Sealer, and RustSeal. Full step by step directions for a permanent repair.
Read More
Prevent cracking, peeling, and rust on your suspension springs! Learn how to prep and paint coil & leaf springs using the KBS 3-Step System for a long-lasting, flexible finish. Read more→
Read More
KBS RustSeal outperforms Glyptal as an engine internal coating. Seals porous castings, resists oil and fuel, and cures permanently. See how engine builders use it during rebuilds.
Read More
How to Paint Rusty Exhaust Headers So the Finish Won’t Crack, Flake, or Peel
This in-depth guide explains why header paint peels and shows how proper prep, high-temperature coatings, and correct heat curing deliver a durable, long-lasting finish that won’t crack, flake, or burn off under extreme heat. →
Read More
Learn how to paint aluminum wheels for long-lasting adhesion. This guide explains proper prep, application, and durability using KBS MAXX wheel paint.
Read More
What’s the Most Durable Way to Seal Wood Exposed to Heavy Use and Harsh Conditions?
Polyurethane swells and epoxy cracks on wood that takes real abuse. Learn how to seal trailer decks, workbenches and shop floors with KBS RustSeal.
Read More
How to Stop and Prevent Rust on Steel UTV Skid Plates
Steel UTV skid plates rust fast once the coating is gouged. Stop it with KBS RustSeal, then armor the plate with KBS Bed Liner or KBS Bed Renu.
Read More
Seal a wood shed floor against moisture, rot, and pests with KBS MAXX. Step-by-step prep, sealer coat, coat count, cure times, and a non-slip additive method.
Read More
Protect your dock from costly rust damage and corrosion with this step-by-step guide. Learn how to clean, prep, seal, and finish steel and aluminum docks using KBS Klean, RustBlast, RustSeal, and KBS MAXX for lasting durability and a professional finish.
Read More
A Proper Body Repair Method That Keeps Rust from Coming Back
Rust often returns after body repair because corrosion was never fully neutralized. Learn the full KBS rustproofing method: clean, treat, and seal with RustSeal.
Read More
How to Prevent Boat Trailer Rust: A Step-by-Step Guide
Rust not only makes your trailer look bad but can also compromise its structural integrity. This guide will show you how to stop existing rust and prevent future rust on your boat trailer using the KBS Coatings Ultimate Frame Coater Kit.
Read More
How to Stop Rust on a Steel Fence and Make It Look New Again
Learn how to stop rust on a steel fence, choose Rust Converter or RustSeal, prepare the metal correctly, and protect the new finish with a UV-stable topcoat.
Read More
How to Stop Rust on a Car's Undercarriage Before Winter
Protect your vehicle’s underside before winter. Learn how to spot treat rust on frame rails, floor pans, and suspension parts using KBS Rust Converter and RustSeal. →
Read More
How To Properly Open a Paint Can Preventing a Stuck Lid and How To Preserve Paint In The Can
Over the years, one of the most useful tips we give to our customers is how to properly open a paint can so it be sealed correctly. In the video, we show you how to properly open and close a paint can from KBS Coatings.
Read More
How to Seal a Plastic or Polyethylene Fuel Tank
Plastic and polyethylene fuel tanks weep instead of rust. Here's how to patch, clean, primer etch, and seal one so it stops leaking for good.
Read More
How to Clear Coat Over Rust and Preserve the Patina Look
Want to seal rusted metal and lock in that weathered patina look? Learn how to prep and apply KBS DiamondFinish Clear coat over rust for lasting UV protection.
Read More
Do You Need Primer With High Temperature Paint? XTC Primer Explained
Do you need primer for high-temperature paint? XTC bonds directly to prepped metal with no primer, but XTC Primer adds rust protection. Here's when to use it.
Read More
How to Prepare Metal for Painting for a Durable Finish
Properly preparing metal surfaces for painting is essential to get the paint to bond and achieve a durable, professional-looking finish that doesn’t flake or peel. Here we will cover the steps to prepare metal for painting, with a focus on the use of KBS Klean and RustBlast.
Read More
How to Get Paint to Stick to Plastic: Step-by-Step Guide
Painting plastic surfaces can be a daunting task, often resulting in poor adhesion if not done correctly. See how KBS Klean, KBS SEP Self-Etching Primer and KBS FPP Flexible Plastics primer are used to prepare plastic for excellent adhesion of top coats.
Read More
Using Bed Liner on Rocker Panels, Doors, And Fenders for Protection
Off road truck, SUV, and Jeep body panels can be damaged by rocks, tree branches and other debris. Applying KBS Bed Liner on rocker panels, doors, fenders, and other body panels is an effective way to avoid this type of damage. See how it’s done.
Read More
Garage Floor Makeover Using RustSeal and KBS MAXX
Street Trucks highly recommends ordering RustSeal and KBS MAXX for any garage floor makeover. Terrific transition from old to new for the garage floor.
Read More
How to Remove Paint from Metal: Stripper, Blasting & Sanding
Compare paint stripper, media blasting, and sanding or wire wheeling to find the best way to remove paint from metal for your project.
Read More
Sealing the inside of an engine block addresses issues related to porosity, corrosion, and lubrication, and enhances to the overall longevity and reliability of the engine. Both KBS RustSeal and KBS Gold Standard Tank Sealer are excellent engine block sealer options. Here is how they are used.
Read More
The primary purpose of RustSeal, cold galvanizing compounds, and zinc rich coatings is to prevent rust. RustSeal prevents rust and corrosion in a very different way than zinc coatings. So, which is the best rust preventive coating?
Read More
