How to Prevent Boat Trailer Rust: A Step-by-Step Guide
How to Stop and Prevent Rust on Your Boat Trailer: A Complete Guide
Boat trailers are constantly exposed to wet conditions, outdoor storage, and sometimes even salt water. These elements create the perfect environment for rust and corrosion to develop.
Rust not only makes your trailer look bad but can also compromise its structural integrity. Left unchecked, it can lead to expensive repairs or even the need to replace the trailer.
KBS Coatings Boat Trailer Protection
This guide will show you how to stop existing rust and prevent future rust on your boat trailer using the KBS Coatings Ultimate Frame Coater Kit, which includes KBS Klean, RustBlast, RustSeal and Cavity Coater. KBS Top Coater will be used for the final finish. Following these steps will ensure your trailer stays protected and your investment is preserved.
The KBS Coatings Ultimate Frame Coater Kit and KBS Top Coater provide a comprehensive solution for boat trailer rust prevention and finish restoration. Here’s how they work together:
  1. KBS Klean: Degreases and cleans surfaces, ensuring the trailer is free of contaminants.
  2. RustBlast: Neutralizes existing rust and prevents further oxidation.
  3. RustSeal: Provides a long-lasting, strong, protective barrier against rust and corrosion.
  4. Cavity Coater Aerosol and Spray Wand: Provides self-healing film which offers incredible rust protection in hard-to-reach areas.
  5. Top Coater: Top coats RustSeal for UV protection and a smooth, durable finish.
Using these products streamlines the entire process, making it easier to remove rust from a boat trailer and protect it for years to come.
Applying RustSeal to Trailer
When it comes to removing rust from a boat trailer, the key is to neutralize the existing rust before it spreads. Using the KBS Coatings Ultimate Frame Coater Kit, this process is straightforward:
1. Remove Loose Rust and Paint
  • Use a wire brush, 320 grit sandpaper, or sandblasting.
    Note: Sandblasting offers the fastest and most thorough way to completely remove rust. When sandblasting, RustBlast isn’t needed; RustSeal can be directly applied to newly sandblasted metal surfaces.
  • Lightly scuff any well-adhered original paint with 320-grit sandpaper before proceeding.
Prep and Cleaning
2. Clean the Trailer with KBS Klean
Thoroughly wash all areas of the trailer to be treated using KBS Klean. Clean surfaces allow KBS products to work most effectively.
3. Neutralize Rust with RustBlast
For areas with existing rust and bare metal, RustBlast is applied to etch the metal for best adhesion of RustSeal.
  • Spray on and keep wet for 30 minutes–2 hours depending on the amount of rust.
  • Scrub intermittently with a Scotch Brite pad.
  • Rinse and dry thoroughly.
  • A whitish residue will remain; this prevents flash rust. Do not remove.
  • Complete instructions: https://www.kbs-coatings.com/rustblast-directions
Once rust is neutralized, applying a rust inhibitor is the next step. The KBS Coatings Ultimate Frame Coater Kit contains RustSeal, which is regarded as one of the best rust inhibitors for boat trailers.
RustSeal is a rust preventive coating that provides long-lasting protection. This 1K moisture cured urethane coating is extremely hard, yet flexible, helping to prevent chips, cracks, and peeling.
How to Apply RustSeal
Applying RustSeal
Top coating RustSeal is recommended for surfaces exposed to direct sunlight. KBS Top Coater paint is included for this purpose.
How to Apply Top Coater
Finished Boat Trailer
For hard-to-reach areas such as inside trailer frame rails, Cavity Coater Aerosol is effective. Use the Cavity Spray Wand for complete 360° coverage.
Using Cavity Coater Wand
Summary: Prevent Rust and Save Money
Rust is one of the most common and damaging issues for boat trailers. With proper care and the right products, you can stop existing rust, prevent future rust, and avoid costly repairs or replacements.
Key takeaways:
Investing time and effort in proper care ensures your trailer remains safe, reliable, and looking its best.
Shop the Ultimate Boat Trailer Rust Kit
Fast Shipping & Permanent Protection
