KBS Top Coater Galvanized Aerosol: Professional Cold Galvanizing Rust Protection in a Can
KBS Coatings is proud to announce the arrival of KBS Top Coater Galvanized Aerosol — a high-solids cold galvanizing spray that brings professional-grade rust protection to any job site, farm, shop, or garage in a convenient 12 oz. can. No mixing. No spray gun. No special equipment. Just shake, spray, and protect.
If you've ever needed to touch up a galvanized fence panel, protect bare steel on a trailer frame, or restore the finish on a piece of farm equipment before the season starts, you know how frustrating typical aerosol spray paints can be: thin coverage, runs on vertical surfaces, and a finish that dulls and chalks in the sun within a season. KBS Top Coater Galvanized Aerosol was built to solve every one of those problems.
Now available — ships same day from our factory in Valparaiso, IN. Get professional galvanized rust protection without the spray gun setup.
Order Now — $24.00 Pair It with RustSeal
What Is KBS Top Coater Galvanized Aerosol?
KBS Top Coater Galvanized Aerosol is a high-solids, single-component aerosol coating that applies a durable, flat galvanized finish to bare metal surfaces. Unlike conventional cold galvanizing compounds that rely heavily on sacrificial zinc content, this formula is engineered for two distinct advantages that matter in the real world: superior coverage and long-term UV stability.
One 12 oz. can covers up to 30 square feet per coat — more than twice the coverage of standard aerosol spray paints. The formula holds its position on vertical surfaces without running or sagging, so you can apply the generous, even coats needed for real protection without chasing drips. Full cure is reached in just 24 hours, so equipment can go right back into service.
KBS Top Coater Galvanized is made at KBS Coatings' manufacturing facility in Valparaiso, IN, and ships factory direct — same day, in most cases. Every can is manufactured under strict quality controls, so you get the freshest product possible.
Key Features and Advantages
Twice the Coverage of Conventional Aerosols. The high-solids formula delivers up to 30 sq. ft. per 12 oz. can in a single coat. That means fewer cans, less waste, and real savings on larger jobs like fence sections, trailer frames, or structural ironwork. Conventional aerosol spray paints typically yield 8 to 15 sq. ft. per can at the same application rate.
100% UV Stable. One of the most common complaints about zinc-based aerosol sprays is that they dull, yellow, and mottle after a few months of outdoor exposure. KBS Top Coater Galvanized uses a formula engineered to resist fading and chalking under continuous direct sunlight. South-facing surfaces, outdoor fencing, and equipment stored in the open will hold their galvanized appearance season after season.
No Runs, No Sags. The high-viscosity formula stays where you put it on vertical surfaces, even when applying the full coats needed for proper coverage. This is a significant practical advantage over thinner aerosol formulas that require extremely light passes to avoid runs, which in turn forces multiple thin coats and increases application time.
No Equipment Required. No mixing, no pot life to worry about, no spray gun to disassemble and clean. Shake the can, spray, and you're done. KBS Top Coater Galvanized is purpose-built for jobs where setup time and equipment availability are a constraint.
Fast Turnaround. Touch dry in 1 to 2 hours. Recoat within 24 hours for additional build. Full cure in 24 hours. Equipment can go back in service quickly rather than sitting idle waiting for a slow-curing two-part coating to fully harden.
Authentic Galvanized Appearance. The flat finish blends seamlessly with factory-galvanized surfaces, making it the right call for touch-up repairs on existing galvanized structures where a visible patch would be unacceptable. Fence panels, conduit, structural steel, and gutters all benefit from a repair that matches rather than contrasts.
Wide Application Window. Apply in temperatures from 50 to 90 degrees F with up to 70% relative humidity. That covers most working conditions across North American climates year-round without the environmental restrictions that come with some two-part coatings.
Made in the USA. Every can of KBS Top Coater Galvanized Aerosol is manufactured in Valparaiso, IN. Your purchase supports American manufacturing and ships direct from the factory.
  • 12 oz. aerosol can — covers up to 30 sq. ft. per coat
  • 100% UV stable — no fading, no chalking
  • Touch dry 1 to 2 hours | Full cure 24 hours
  • No mixing, no spray gun required
  • Made in the USA | Factory direct shipping
$24.00 $30.00 Save 20%
Add to Cart
Factory direct. Same-day shipping.
View full product details →
Where KBS Top Coater Galvanized Aerosol Works Best
This coating was designed to cover a wide range of metal protection jobs where aerosol convenience and a galvanized finish are both required. Here is where it performs best.
Galvanized Metal Touch-Ups
Scratches, chips, and worn areas on existing galvanized fencing, conduit, gutters, and structural steel are the most straightforward application. When the damaged area needs to match the surrounding factory-galvanized surface, KBS Top Coater Galvanized blends in rather than standing out. This is especially valuable on visible structures like entry gates, security fencing, and architectural metalwork where a visible repair is not acceptable.
Automotive Frames and Underbody
Frame rails, floor pan flanges, suspension brackets, crossmembers, and underbody sheet metal often receive a galvanized finish from the factory. When that finish is cut, welded, or corroded, KBS Top Coater Galvanized restores the protective coating and matching appearance. For maximum protection on heavily corroded automotive underbody surfaces, use it as the finish coat over KBS RustSeal in the two-stage system described below.
Farm and Agricultural Equipment
Tractors, grain bins, livestock panels, hay wagons, implement frames, and outbuilding metalwork are constantly exposed to the harshest combination of conditions: UV, moisture, fertilizer residue, and animal waste. The UV stability and durable film of KBS Top Coater Galvanized make it a reliable choice for seasonal equipment prep and in-season touch-up work.
Structural Steel and Ironwork
I-beams, angle iron, column bases, railings, stairs, walkways, and architectural gates benefit from a galvanized finish that provides long-term corrosion protection without a color topcoat. KBS Top Coater Galvanized delivers a professional, low-sheen finish that blends with hot-dipped galvanized structural elements and holds up to outdoor exposure without UV degradation.
Marine Hardware (Above Waterline)
Boat trailers, dock hardware, lifting rings, mooring cleats, and any above-waterline marine hardware exposed to saltwater spray and UV are a strong fit for this product. Note: KBS Top Coater Galvanized is designed for above-waterline protection and is not recommended for constant-immersion applications. For submerged or immersion applications, use KBS RustSeal.
Industrial Equipment and Machinery
Machine frames, conveyor systems, storage racking, shop equipment, and tool carts that need a durable, low-sheen finish without color are a natural application. The professional flat galvanized finish blends into industrial environments without the distraction of a color topcoat.
Electrical Conduit and Utility Hardware
Metal electrical conduit, junction boxes, utility poles, meter bases, and chain-link fencing that have lost their galvanized finish due to weathering or physical damage can be restored quickly and without equipment. The coating holds up to outdoor UV exposure without chalking, making it suitable for infrastructure hardware that is not regularly inspected or maintained.
How KBS Top Coater Galvanized Compares to Standard Cold Galvanizing Sprays
Most cold galvanizing aerosols on the market are formulated around zinc content as the primary selling point, typically 90 to 95% pure zinc in the dried film. The zinc works as a sacrificial anode, meaning it corrodes in place of the base metal. That chemistry has real value in the right context, but it comes with limitations: many zinc-heavy aerosols are thin, low-solids formulas that run on vertical surfaces, require many coats to build adequate film thickness, and dull or chalk significantly after prolonged UV exposure.
KBS Top Coater Galvanized takes a different approach. The high-solids formula prioritizes film build, UV stability, and application performance over raw zinc percentage. The result is a coating that covers more square footage per can, holds its position on vertical surfaces, and maintains its galvanized appearance long-term in outdoor conditions. For applications where the galvanized finish is purely functional and UV exposure is limited, either approach works. For jobs where the finish is visible and outdoor conditions are ongoing, the UV-stable formula delivers a better long-term result.
Build a Complete Rust Protection System
Use KBS Top Coater Galvanized as a standalone coating on bare metal, or stack it with RustSeal for maximum protection on heavily corroded or high-exposure surfaces.
Step 1: KBS Klean
Removes grease, oil, and surface contaminants before coating.
Step 2: RustSeal
Moisture-cured rust barrier. Stops rust permanently, not sacrificially.
Step 3: Top Coater Galvanized
UV-stable galvanized finish coat over cured RustSeal.
The Two-Stage System: RustSeal Plus KBS Top Coater Galvanized
KBS Top Coater Galvanized Aerosol is effective as a standalone coating on clean bare metal for most applications. But when the surface has seen significant corrosion, will be exposed to constant moisture, or is part of a structural system where coating failure is not an option, the two-stage system delivers a materially higher level of protection.
The system works as follows:
  1. KBS Klean removes grease, oil, wax, and road film. Applied to bare or painted metal before any other step, it ensures subsequent coatings bond to metal rather than contamination. Learn more about KBS Klean.
  2. RustBlast (if active rust is present) converts and removes rust, etches the metal surface, and deposits a zinc phosphate surface profile that gives subsequent coatings a mechanical anchor to grip. Learn more about RustBlast.
  3. KBS RustSeal is applied to the clean, prepped surface. RustSeal is a single-component, moisture-cured rust prevention coating that bonds permanently to metal and encapsulates light surface rust. It forms a non-porous barrier that stops rust by denying moisture and oxygen access to the metal surface. RustSeal cures to a rock-hard, ceramic-like film and does not require reapplication once properly cured. Learn more about RustSeal.
  4. KBS Top Coater Galvanized Aerosol is applied over cured RustSeal (after a 3 to 8 hour cure window) as the UV-stable finish coat. RustSeal without a topcoat will degrade under prolonged UV exposure. KBS Top Coater Galvanized provides the UV protection the system needs while delivering the galvanized appearance the project requires.
This four-step process is the most complete rust defense system available for metal surfaces that need long-term protection and a galvanized finish. It is particularly well suited to trailer frames, automotive underbodies, structural metalwork, and any surface that will live outdoors for years without regular maintenance.
Application Tips and Coverage Guide
KBS Top Coater Galvanized Aerosol is straightforward to apply, but a few technique details make a significant difference in results.
Surface prep is the most important step. KBS Top Coater Galvanized requires a clean, bare metal surface for direct application. Any grease, oil, or wax on the surface will cause adhesion failure. Use KBS Klean to degrease the surface before application.
Shake thoroughly before and during use. Shake the can for a full minute after hearing the mixing ball begin to rattle. Re-shake for 10 seconds every 1 to 2 minutes during application to maintain consistent film properties.
Hold the can 8 to 10 inches from the surface. Use overlapping side-to-side strokes and keep the can in motion. The high-solids formula covers well at this distance without runs or orange peel texture.
Apply multiple thin coats rather than one heavy coat. On rough, porous, or heavily textured surfaces, apply two to three coats for full coverage, allowing each coat to become touch dry (1 to 2 hours) before recoating. All recoat applications should be completed within 24 hours for best inter-coat adhesion.
Clear the nozzle after each use. Invert the can and spray for 3 seconds to clear the nozzle. This prevents tip clogging and ensures the can is ready for its next use.
Can Size Typical Coverage (1 Coat) Recommended Coats Application Temp
12 oz. Aerosol Up to 30 sq. ft. 1 to 2 (general); 2 to 3 (marine/industrial) 50 to 90°F | Up to 70% RH
Order Now — Same-Day Shipping from Valparaiso, IN
KBS Top Coater Galvanized Aerosol is in stock and shipping same day from our factory in Valparaiso, IN. Orders placed before our daily cutoff ship the same business day. KBS Coatings stands behind every product with a satisfaction guarantee: if something is not right, we will make it right.
Have questions before you order? Our technical team is available by phone, text, and live chat to help you choose the right product and system for your project.
Ready to Protect Your Metal with KBS Top Coater Galvanized?
Factory direct. Same-day shipping. Satisfaction guaranteed or we'll make it right.
Order KBS Top Coater Galvanized — $24.00 Shop RustSeal for Maximum Protection
Questions? Call (219) 263-0073 or text (219) 531-7797. Real people, real answers.
