Printer Friendly Tank Sealer Tank Sealer Instructional Videos Tank Sealer Flow Chart Tank Sealer Chemical Resistance Order Tank Sealer Kits
Technical Information & Specifications
Type of coating: Single Component Moisture Curing Polymeric Isocyanate.
Colors: Silver
Gloss: 80%.
Solids: 76%.
Flash Point: 103°F (40°C)
Viscosity: at 77°F (25°C)   320cps
VOC: Not more than 250g/l
Minimum Recommended Dry film thickness: 3 mils (75um).
Coverage: On porous surfaces like rust and corrosion approximately 100 sq. ft. per quart or 400 sq. ft. per gallon (9.5m 2 per liter) at 2 mils (50um) thickness. Coverage will vary depending on surface profile, application method and film thickness.
Average Dry Times at 77°F (25°C) at 50% humidity (inside enclosed tank with minimal air flow): Touch dry 4-6 hours. Full cure after 96 hrs.
Pot life: Pot life will depend on local humidity conditions and the length of time the coating is exposed to moisture. Though providing the can is resealed well and only opened for limited periods at a time the average life is approximately 1-2 months.
Solvent: Use only KBS #1 Thinner. The use of other solvents can cause premature coating failure and or lost of adhesion.
General appearance and Characteristics: Smooth ceramic like finish with very high levels of flexibility and toughness. Strong resistance to impact, high temperature, abrasion and common aggressive chemicals including; Acids, Alkalis, Salts, Minerals, Solvents, Fuels and Hydraulic fluids.
Storage Requirements: Store in cool dry conditions away from direct sun light 41-95°F (5-35°C)
Container Availability: 8oz (236mls) Pint (475mls) Quart (946mls) Gallon (3.78L) 5 Gallon (18.9L) Drum 55 Gallon (208L)
Performance Characteristics: Salt water resistance ASTM B-117 at 95°F (35°C) at 5% salt water for 2000 hrs: No noticeable change.
Results of contact spot testing of Gold Standard Tank Sealer with various common materials.
Gold Standard Tank Sealer applied to steel Q panels at 4 mil (100um) film thickness and placed in continuous contact with the following materials for 168 Hr (7days).
Product
Time
Result
Sodium Hydroxide 10%
168Hr
Some discoloration, coating intact
Sulphuric Acid 20%
168Hr
Hydrochloric Acid 40%
168Hr
Phosphoric Acid 20%
168Hr
Ammonium Chloride (Fertilizer)
168Hr
Brake fluid
168Hr
MEK ( Strong Solvent)
168Hr
93 octane Fuel
168Hr
Xylene
168Hr
Hydraulic fluid
168Hr
Diesel Fuel
168Hr
