The RustSeal Calculator works out how much RustSeal, KBS Klean, and RustBlast a metal project needs, plus Cavity Coater and a topcoat if you want them. One gallon of RustSeal covers about 200 sq ft with two coats, and a half-ton pickup frame takes one Large Frame Coater Kit.
Build Your RustSeal Package
Pick your project and we will put together everything the job takes: KBS Klean, RustBlast, and RustSeal, plus Cavity Coater and a topcoat if you want them. One click adds it all to your cart.
Metal condition
Add extras (optional)
Shop RustSeal, the Frame Coater Kit, and the Large Frame Coater Kit.
RustSeal Coverage at a Glance
200 sq ft
Per Gallon at 2 Coats
50 sq ft
Per Quart at 2 Coats
2 Coats
Minimum, 3 if Wet Daily
100 sq ft
Half-Ton Pickup Frame
How the Calculator Works
  • Coats: Two thin coats of RustSeal, about 2 mils each, is the minimum, and the right build under a topcoat. Metal that is wet every day, such as marine metal or the inside of a water tank, gets 3 coats of RustSeal, or 2 coats plus a topcoat.
  • Coverage: One quart of RustSeal covers about 50 sq ft with two coats, and one gallon covers about 200 sq ft.
  • Rough metal: Rough or heavily pitted metal soaks up more RustSeal. The calculator plans on up to 30% less coverage, and a third coat may be needed.
  • Freshly sandblasted metal: Metal blasted with fresh sand, not recycled, and handled only with gloves needs no KBS Klean or RustBlast, so the calculator leaves them out. Recycled sand, bead, soda, or plastic media blasting still needs both.
  • Previously coated metal: Over a coating in good shape, scuff with 400 grit if the finish is glossy and wash with KBS Klean. The full RustBlast step is skipped: jobs up to about 100 sq ft still use a frame kit, and larger jobs get 8 oz of RustBlast for bare or rusty spots instead of the full amount.
  • Prep: One quart each of KBS Klean and RustBlast for every 50 sq ft. Frames and equipment are dirty by nature, so very greasy metal may need more KBS Klean.
  • Kits first: When the job fits a kit, the calculator uses it: the Frame Coater Kit for about 50 sq ft and the Large Frame Coater Kit for about 100 sq ft.
  • Inside the rails: Cavity Coater sprayed through a Cavity Wand: one aerosol for a car or small frame, two for a half-ton pickup or full-size SUV, and three for a 3/4 or 1 ton pickup. For equipment, marine metal, and other projects with enclosed tubing or box sections, you choose how many aerosols; one covers about 125 sq ft of inside surface.
  • Topcoat: RustSeal needs no topcoat where sunlight never reaches, such as under a vehicle. Any part the sun hits, such as a fence, equipment, or a building, gets one coat of BlackTop or KBS MAXX, the most durable choices, or KBS Top Coater.
  • Fences: Pick the fence type and enter its length and height, and the calculator counts both sides. Chain link counts as solid on one face plus the top rail and posts, straight-picket ornamental iron as its length times height, ornate scrollwork at one and a half times that, a solid steel panel at twice that, and pipe rail by the length of each rail plus the posts. Spraying chain link adds 25% more RustSeal for spray that passes through the mesh.
  • Your project: For anything other than a frame or fence, measure the metal you are coating in square feet, length times width for each flat area.
  • Full cans: The calculator rounds up to full cans, so most jobs have some RustSeal left for touch-ups.
What to Order for Common Frames and Trailers
These amounts are for smooth or lightly rusted metal, two coats of RustSeal, with no Cavity Coater or topcoat.
What to order to coat a frame with two coats of RustSeal
JobMetal areaWhat to order
Compact or midsize car frame50 sq ft1 Frame Coater Kit
Full-size car or compact pickup frame75 sq ft1 Large Frame Coater Kit
Half-ton pickup or full-size SUV frame100 sq ft1 Large Frame Coater Kit
3/4 or 1 ton pickup frame125 sq ft1 gallon each of RustSeal, KBS Klean, and RustBlast
Half-ton pickup, full underbody200 sq ft1 gallon each of RustSeal, KBS Klean, and RustBlast
Utility trailer frame, 6 x 12 to 7 x 1475 sq ft1 Large Frame Coater Kit
Tandem axle trailer frame, 7 x 16 to 7 x 18125 sq ft1 gallon each of RustSeal, KBS Klean, and RustBlast
Car hauler frame, 8.5 x 20200 sq ft1 gallon each of RustSeal, KBS Klean, and RustBlast
How Much RustSeal for a Fence
The calculator counts both sides of a fence from its type, length, and height. The table shows what 100 ft of 4 ft fence takes on smooth or lightly rusted metal, two coats, before KBS Klean, RustBlast, or a topcoat. Fences sit in the sun, so plan on a coat of BlackTop or KBS MAXX over the RustSeal.
RustSeal for 100 ft of 4 ft fence, both sides, two coats
Fence typeMetal areaRustSeal to order
Chain link, brushed or rolled500 sq ft2 gallons plus 2 quarts
Chain link, sprayed500 sq ft3 gallons plus 1 pint
Ornamental iron, straight pickets400 sq ft2 gallons
Ornate iron with scrollwork600 sq ft3 gallons
Solid steel panel800 sq ft4 gallons
Pipe rail, 3 rails and 11 posts344 sq ft2 gallons
How to Measure Your Project
  • Vehicle and trailer frames: pick your vehicle or trailer. The calculator already knows the square feet of metal in a typical frame.
  • Fences: measure the length and height of the run. The calculator counts both sides for you.
  • Everything else: add up length times width for each flat area you are coating, on every side you are coating. For pipe and round posts, count about 1 sq ft for every foot of length.
Step-by-Step RustSeal Guides
The calculator tells you what to order. These guides show how to clean, prep, and coat the metal.
Truck Frame Guide Trailer Frame Guide Steel Fence Guide Mower Deck Guide Stock Tank Guide RustSeal Directions Cavity Coater Directions
Frequently Asked Questions About How Much RustSeal You Need
Two thin coats of RustSeal, about 2 mils each, for most jobs, and two coats is also the right build under a topcoat. Metal that is wet every day, such as marine metal or the inside of a water tank, gets three coats when it has no topcoat.
Yes. BlackTop, KBS MAXX, and KBS Top Coater all go over RustSeal. Apply the topcoat when the last coat of RustSeal is 3 to 8 hours old with no other prep, or let it cure 24 hours and scuff it with 320 grit first. Clear coats such as DiamondFinish Clear and KBS MAXX Clear do not go over RustSeal.
About 50 sq ft with two coats. A pint covers about 25 sq ft, a gallon about 200 sq ft, and a 5 gallon pail about 1,000 sq ft. Rough or heavily pitted metal takes up to 30% more.
A half-ton pickup frame is about 100 sq ft of metal, which one Large Frame Coater Kit covers with two coats. A compact pickup frame is about 75 sq ft and a 3/4 or 1 ton frame about 125 sq ft. Frame and suspension adds about 25%, and a full underbody is about double the frame.
Not where sunlight never reaches, such as a frame under a vehicle. RustSeal's rust protection does not break down in sunlight, but its color and sheen chalk and fade, so any part the sun hits gets a coat of BlackTop or KBS MAXX, the most durable choices, or KBS Top Coater.
Not on metal freshly blasted with fresh sand and handled only with gloves: blow off the dust and apply RustSeal. Recycled sand, bead, soda, and plastic media blasting still need KBS Klean and RustBlast. Sandblasting does not change how far RustSeal goes.
For RustSeal, count both sides of the fence. Chain link counts as its length times its height plus about 1 sq ft per foot for the top rail and posts, so 100 ft of 4 ft chain link is about 500 sq ft, or 2 gallons plus 2 quarts of RustSeal at two coats. Straight-picket ornamental iron counts as length times height, and ornate scrollwork as one and a half times that.
Yes, over paint that is still sound. Scuff glossy paint with 400 grit; flat or matte paint needs only a KBS Klean wash. Treat any bare or rusty spots with RustBlast before you coat.
More RustSeal questions and answers: RustSeal FAQs
Still have questions about RustSeal? Our technical team is ready to help.
Order RustSeal: Stop Rust and Prevent Its Return
