KBS Fuel Tank Sealer System Removes Rust and Restores the Inside of Your Tank to Like New
To remove rust from a fuel tank, clean it with KBS Klean, dissolve the rust with RustBlast, then seal the inside with Gold Standard Tank Sealer. Steps, kit sizes by tank capacity, cure time and answers to common questions.
The Motorcycle Frame Coater Kit Has Everything Needed to Remove Rust and Prevent Rust In The Future
When restoring a motorcycle, refinishing the frame is a time-consuming process. If the frame is rusty you can count on spending additional time on preparation. Further, once prep is completed, extra care must be taken to ensure further rusting is prevented. KBS Coatings addresses this with the Motorcycle Frame Coater Kit, which is specifically engineered to be user-friendly, reduce labor time and provide a great looking, long-lasting and durable rust preventative finish.
RustSeal Rust Prevention Formulation Keeps KBS Coatings as the Leader of the Pack
At KBS Coatings, superior product performance and user friendliness are our top priorities. KBS Coatings has the best products for rust prevention and we continually look for ways to improve upon them as well as provide features not offered by other manufacturers. For example, RustSeal, which is a high-tech rust prevention coating that uses premium quality materials for state-of-the-art performance, has been continually improved upon by listening to our customers. We learned what they wanted with this type of coating: Quick and easy application, smooth rich deep colors, excellent bonding of the coating to the surface and color variety. Thanks to our on-staff paint chemists, we were able to engineer these qualities into RustSeal.
RustSeal is quick and easy to apply. This is due to the paint “flowing out” well. Flow is the degree to which the wet film of a coating material can flow out during and after application to produce a uniform smooth surface. This is especially important for those times a paint brush needs to be used, such as when painting a car frame while it is attached to the vehicle. Competitors’ coatings often require continually going back to re-brush areas of wet paint to get proper coverage and smooth out brush marks. Because RustSeal has superior flow characteristics it provides great hide and coverage on each coat without the need for frequent re-brushing. So, RustSeal saves you time. Users say the finish resembles the incredible look of a powder coat.
To achieve this, RustSeal is formulated with a blend of solvents. Fast evaporating solvents allow the paint to start to cure quickly and adhere well to the prepped surface locking out water and air and avoiding oxidation (rust and corrosion). In addition to the fast evaporating solvents, slow evaporating solvents remain longer and allow brush marks to flow out giving a beautiful uniform finish. Hi-Tech additives are included to release gases in the paint so micro bubbles don’t form and compromise the appearance of the coating.
Availability of a wide variety of colors also differentiates RustSeal from competing corrosion treatments. Other manufacturers typically provide their products only in gloss black, semi-gloss black, silver, and gray. RustSeal is available in ten colors: Gloss Black, Satin Black, Silver, Grey, Off-White, Oxide Red, Green, Cat Yellow, Safety Blue and Galvanized Steel.
Coating stability, after the can has been opened, is another important aspect of our paint formulation. Once the can is opened the paint is exposed to ambient moisture in the air which can be absorbed into the paint. For RustSeal, moisture is the catalyst the activates bonding of the paint to the prepped surface. If a significant amount of moisture collects in the stored paint, the shelf life is diminished. While storing RustSeal according to the directions is always best, RustSeal’s formulation includes additives that convert accumulated ambient moisture to a gas which then evaporates out of the coating resulting in extended shelf life for RustSeal.
By listening to our customers’ needs, utilizing on-staff paint chemists and controlling the manufacturing process by producing RustSeal in house, KBS Coatings has developed a unique and user-friendly rust prevention coating with superior performance, flexibility, toughness and incredible impact resistance. RustSeal is the most permanent cost-effective solution for stopping rust and corrosion anyplace where it is a problem: home, automotive, industry, fleet, farm and more.
To learn more about RustSeal from KBS Coatings, click HERE.
