How to Seal a Rusted Galvanized Stock Tank (Even a Duck Pond) So It Stops Leaking for Good
A galvanized stock tank buried in the ground, whether it's watering livestock or, in one customer's case, doubling as a duck pond, takes a beating. Standing water, weather, and years of use eventually wear through the galvanizing and let rust take hold. The good news: a tank doesn't need to be replaced just because it's rusting, or even if it has a few small holes. Cleaned, etched, sealed, patched, and topcoated with the right products in the right order, it can go back into service for years. This guide walks through the exact process, using KBS Klean, RustBlast, RustSeal, and BlackTop, based on a real customer question about sealing a 2-foot-deep, 10-foot-wide open-top galvanized tank.
Why Galvanized Stock Tanks Rust
Galvanizing is a zinc coating that protects the underlying steel, but it isn't permanent. Constant water contact, especially in a buried tank with a drain fitting, along with scrubbing, cleaning, and general wear will eventually break down the zinc layer. Once that happens, the bare steel underneath is exposed and starts to corrode. A tank used as a duck pond has it even worse: constant standing water, organic waste, and regular cleaning to remove algae and muck all accelerate the process. The fix isn't a temporary patch. It's removing the surface contamination and rust, creating a surface the new coating can actually bond to, and then sealing it with a system built to handle permanent water exposure.
Supplies You'll Need
This job uses the KBS 3-Step Rust Prevention System, plus a UV-stable topcoat for a tank that lives outdoors:
  • KBS Klean - cleaner and degreaser, Step 1
  • RustBlast - rust remover, metal etch, and zinc phosphate pre-primer, Step 2
  • RustSeal - rust encapsulating coating, Step 3
  • BlackTop - UV-stable topcoat for lasting color and gloss outdoors, Step 5
If the tank has any actual holes, not just surface rust, you'll also need a patch product for Step 4, applied after RustSeal and before BlackTop (optional, only if needed):
For a tank this size (roughly 140 sq. ft. of interior surface for a 10-ft round, 2-ft deep tank, floor plus walls), plan on at least a gallon of RustBlast, a gallon of RustSeal for two coats, and a gallon of BlackTop, and add a second gallon of RustSeal only if you skip BlackTop and put all three coats down in RustSeal. RustSeal and BlackTop each cover about 400 sq. ft. per gallon at 2 mils per coat, so three coats of RustSeal on 140 sq. ft. runs just over one gallon.
Step-by-Step: Sealing the Tank
Step 1: Drain and Clean with KBS Klean
Drain the tank completely and remove any standing muck, algae, or debris. Scrub the interior with KBS Klean, a concentrated, water-based degreaser that cuts through grime, algae, and biological residue without leaving behind a film that would interfere with adhesion. Rinse thoroughly and let the tank dry completely before moving to the next step.
Step 2: Etch with RustBlast
RustBlast removes any remaining rust and etches the galvanized surface, leaving a zinc phosphate layer that gives RustSeal something to grip. Apply it full strength by brush or sprayer and keep the surface wet the whole time, re-applying as needed: at least 30 minutes on light rust, 40 to 60 minutes on moderate rust, and 1 to 2 hours on heavy rust. Rinse with water before the RustBlast dries. The rinse neutralizes the acid and keeps a heavy zinc phosphate layer from building up. Then let the tank dry completely.
Step 3: Seal with RustSeal
Apply RustSeal in thin, even coats. Two coats is the minimum on most jobs. A tank that holds water is immersion service, and immersion calls for a minimum of three thin coats in total. That can be three coats of RustSeal, or two coats of RustSeal topcoated with BlackTop. RustSeal is regularly used to seal tanks that hold water, including tanks running hot water just below steam. Work at 55F or warmer and under 80% relative humidity. Recoat when each coat is dry to the touch and takes no fingerprint, typically 2 to 6 hours depending on temperature and humidity. If more than 8 hours pass, wait a full 24 hours and scuff with 320 grit or a green Scotch-Brite pad before the next coat.
Step 4: Patch Any Holes Over the Sealed Surface
If the tank has actually rusted through anywhere, whether it's a pinhole or a small hole around the drain fitting, patch it now, after RustSeal rather than before. Patching over a surface that's already cleaned, etched, and sealed gives the patch a stable, corrosion-free base to bond to instead of raw rusted metal. Two KBS products handle this depending on the repair: KBS NuMetal Epoxy Putty is a two-part epoxy putty that mixes like clay, sticks to damp surfaces and cures fully underwater, which makes it a good fit for pinholes or irregular gaps on a tank you can't fully dry out. Apply NuMetal within 6 hours of the last RustSeal coat curing with no scuffing, or over RustSeal that has cured 24 hours and been scuffed with 320 grit. It can be sanded and painted after a 12 hour cure. For a cleaner puncture or a larger area, KBS Patch is a UV-activated, fiberglass-reinforced polyester patch that makes a watertight seal on metal and is used on water tanks and drain pipes. Let the RustSeal cure 24 hours and scuff it with 300 grit first. KBS Patch presses on over the hole and cures in 3 to 5 minutes in direct sun, 30 to 50 minutes on a cloudy day, or 10 to 20 minutes under the KBS UV Light, and it can be sanded and painted 1 hour after it cures. Sand either repair smooth so BlackTop goes on evenly over the RustSeal and the patch.
Step 5: Topcoat Everything with BlackTop
Because this tank sits outdoors and cures in direct sunlight, finish by coating the entire interior, RustSeal and any patched areas alike, with BlackTop. RustSeal alone isn't intended as a final UV-exposed finish; repeated sun exposure will fade or dull its color over time, even though the rust protection underneath holds up. BlackTop is formulated specifically for permanent UV stability with no chalking or fading, and over two coats of RustSeal it reaches 2,000 hours of ASTM B117 salt spray, double the 1,000 hours BlackTop reaches on its own. With no holes to patch, BlackTop goes straight over RustSeal that is 3 to 8 hours old with no other prep. If patching took the RustSeal past 8 hours, let it cure 24 hours and scuff it with 320 grit or a green Scotch-Brite pad first. Apply BlackTop at about 2 mils per coat so that RustSeal and BlackTop together total at least three coats, recoat once a coat is dry to the touch and before 24 hours, and give the final coat its 48 hour full cure. Coating over the patched areas too ties the whole interior together in one uniform, UV-stable finish.
Brush, Roller, or Sprayer?
Both RustSeal and BlackTop can be brushed, rolled, or sprayed. For a tank interior like this, with a flat floor, curved walls, and a drain fitting to work around, a lot of KBS customers use a combination: a roller for the large flat areas and a brush to cut in around the drain and any seams. If you'd rather spray for a faster, more even finish on the open interior surfaces, the KBS HVLP Spray Gun handles both products well with a 1.4 mm tip at 25 to 35 PSI. Keep the gun moving in overlapping passes to avoid runs on vertical surfaces.
How to seal a hole in a metal water tank?
Seal the metal first, then fill the hole. Clean the tank with KBS Klean, etch it with RustBlast, rinse, and apply thin coats of RustSeal. Fill pinholes and irregular gaps with KBS NuMetal Epoxy Putty, which sticks to damp surfaces and cures fully underwater, or cover a clean puncture with KBS Patch, a UV-activated fiberglass patch, once the RustSeal has cured 24 hours and been scuffed with 300 grit. Topcoat the whole interior with BlackTop after the repair cures.
What is the best sealant for galvanized metal?
For a galvanized tank that holds water, KBS uses a coating system instead of a caulk. Clean with KBS Klean, then etch with RustBlast, which works on galvanized metal and leaves a zinc phosphate layer that RustSeal grips. For immersion, apply at least three thin coats in total: three coats of RustSeal, or two of RustSeal topcoated with BlackTop. Use BlackTop wherever the tank sits in the sun, because RustSeal fades in sunlight and BlackTop is UV stable.
Can a rusted galvanized stock tank be sealed instead of replaced?
In most cases, yes, even if it has rusted through in a few spots. Clean it with KBS Klean, etch it with RustBlast, and seal it with RustSeal first. Then patch any holes over that sealed surface with KBS NuMetal Epoxy Putty or KBS Patch, a fiberglass repair patch made for watertight repairs on tanks and pipes, and finish by topcoating the whole interior, patches included, with BlackTop. Together that gives you a durable, waterproof interior that can hold up for years.
Is RustSeal safe for a tank that holds water and animals, like a duck pond?
Yes, once the coatings are fully cured. KBS products are non-toxic once fully cured, and RustSeal is regularly used to seal tanks that hold water. RustSeal is fully cured 24 hours after its final coat and BlackTop 48 hours after its final coat, so wait out the BlackTop cure before refilling the tank or letting animals back in.
Do I need to topcoat RustSeal if the tank will sit outside in direct sun?
Yes. RustSeal is not intended as a final UV-exposed finish. Prolonged direct sunlight will cause cosmetic fading or dulling over time, though it will not affect the rust protection underneath. For a tank that sits outside, topcoat with BlackTop, which is specifically formulated for permanent UV stability with zero chalking or fading.
Can RustSeal and BlackTop be applied by brush instead of spraying?
Yes. Both RustSeal and BlackTop can be applied by brush, roller, or sprayer. For a project like a stock tank interior with corners, seams, and a drain fitting, a brush or roller often gives better control than a sprayer, though an HVLP spray gun works well for the flat interior walls and floor.
How long will RustSeal and BlackTop hold up on a tank exposed to constant water and weather?
Applied correctly over a properly cleaned and etched surface, this system is built for long-term, constant exposure. RustSeal followed by BlackTop has been salt spray tested to 2,000 hours (ASTM B117), and RustSeal will not crack, chip, flake, or peel. It gets stronger with repeated exposure to moisture.
Conclusion
A rusted galvanized stock tank, even one that's been buried in the ground and used as a duck pond for years, is usually a candidate for sealing rather than replacing. Clean it with KBS Klean, etch it with RustBlast, seal it with RustSeal, patch any actual holes over that sealed surface, and finish with BlackTop over the whole interior for a UV-stable exterior that won't fade or peel in the sun. Done right, the tank goes back into service with a permanent, chemical- and water-resistant interior built to last.
