KBS Rust Prevention Flow Chart
KBS Klean Full Directions
RustBlast Full Directions
RustSeal Full Directions
RustSeal Tech Data Sheet
RustSeal Chemical Resistance
KBS Instructional Videos
Order KBS Klean
Order RustBlast
Order RustSeal
The KBS 3 Step System preps and seals rusty metal in three stages: degrease with KBS Klean, etch and dissolve rust with RustBlast, then brush or spray two coats of RustSeal at 2 mils each. Apply RustSeal between 55 and 82 degrees F. Metal treated with RustBlast should be coated within 7 days.
Why Surface Preparation Matters:
Step #1: Clean with KBS Klean:
KBS Klean Dilution Ratios
Step #2: Etch with RustBlast:
Step #3: Seal with RustSeal:
Topcoating and UV Exposure:
RustSeal is not intended as a final finish on surfaces in constant direct sunlight. Prolonged UV exposure will cosmetically alter its color and sheen, although its rust protection does not degrade. In areas that are not exposed to direct sunlight, such as the underside of a car, RustSeal both seals the metal and serves as a good-looking final finish.
A clear topcoat does not solve UV exposure. DiamondFinish Clear and KBS MAXX Clear let UV pass through to the RustSeal underneath. For sun-exposed work, topcoat with an opaque, UV-stable coating: BlackTop, KBS Top Coater, or KBS MAXX.
There are three ways to topcoat RustSeal so the coatings bond and fuse together:
- Apply the topcoat once the final coat of RustSeal is dry to the touch, usually 3 to 6 hours depending on temperature and humidity.
- Let the final coat fully cure for at least 24 hours, scuff with 320 grit, then apply the topcoat.
- Let the final coat fully cure for at least 24 hours, dust with Fusion Self-Etching Primer, let it cure 30 minutes, then apply the topcoat.
Clean Up and Storage:
Use KBS #1 Thinner or lacquer thinner for immediate clean up, including the spray gun. RustSeal has to be cleaned up before it dries, because no solvent removes it once it has cured. Always wear protective gloves. If RustSeal contacts skin, remove it immediately with #1 Thinner or lacquer thinner followed by soap and water. Once it stains skin, only time removes it.
Store all KBS products in a cool, dry place. Unopened product is good for roughly 2 years from the manufacture date, and an opened can averages about 6 months. To extend storage life, keep the can groove clean, use plastic wrap between the lid and the rim, and spray KBS Paint Saver into the can before sealing it: 2 seconds for quarts or less, 4 seconds for gallons.
Technical Data:
Frequently Asked Questions About Prepping Rusty Metal
Still have questions about prepping or sealing rusty metal? Our technical team is ready to help.
