The Engine Coating System
Trusted by Truck Builders
As featured in Street Trucks Magazine, the KBS Motor Coater Kit is a complete prep-and-coat system that delivers a durable, professional engine finish, one that won't blister, flake, crack, or peel. Everything you need is included.
Read the full feature at Street Trucks Magazine.
Shop the Motor Coater KitThe Complete Engine Prep & Coating System
Stop fighting peeling, flaking engine paint. The Motor Coater Kit gives you every product needed, in the right order, for a finish that holds up to heat, oil, and years of daily driving.
Engine paint fails for three reasons: poor surface prep, the wrong paint for high temperatures, and improper application. The KBS Motor Coater Kit eliminates all three. It bundles a professional-grade cleaner, a rust remover and metal etch, a high-temperature engine enamel, and thinner for spray applications, everything needed to go from greasy bare metal to a showroom-quality finish.
Motor Coater Engine Enamel applies by brush, roller, or spray gun, self-levels to eliminate brush marks, and air-cures completely within seven days with no heat cycling required. With proper prep, the finish resists oil, gas, chemicals, and temperatures up to 500°F.
- Kit Includes: KBS Klean, RustBlast, Motor Coater Engine Enamel, KBS #1 Thinner
- Temperature Rating: Withstands heat up to 500°F
- Colors: 42 rich, deep colors that meet OEM standards
- Application: Brush, roller, or spray equipment
- Cure Time: Handle after 2 to 4 hours; full hardness in 7 days
- Primer Needed: No. RustBlast etches the surface for direct adhesion
Prep Right. Coat Once. Done for Good.
The Motor Coater Kit is built around a proven sequence. Each step works with the next, so your finish bonds deeper and lasts longer than any rattle-can approach.
Degrease with KBS Klean
Mix KBS Klean with hot water and scrub away grease, oil, and grime. This concentrated, water-based cleaner leaves zero residue, so nothing stands between your metal and the coating.
Etch & Rust-Treat with RustBlast
Apply RustBlast to dissolve remaining rust, neutralize corrosion, and chemically etch the metal surface. No need to chase every rust spot. RustBlast handles it and creates the ideal bonding profile for Motor Coater.
Coat with Motor Coater Engine Enamel
Apply Motor Coater by brush, roller, or spray gun. Its self-leveling formula eliminates brush marks and delivers a smooth, professional finish. One full coat covers completely. A second coat can be applied within 30 minutes or after 7 days.
Engine Blocks & Heads
The most popular use. Motor Coater is formulated specifically for the heat cycles, oil drips, and under-hood environment your engine lives in every day.
Transmissions & Differentials
Match your trans and diff to your engine bay finish. Motor Coater bonds to cast iron and aluminum alike for a consistent, professional look under the hood.
Brake Calipers
Motor Coater's high-temp resistance and strong adhesion make it an ideal choice for calipers, whether you're going factory correct or adding a pop of custom color.
Alternators, Brackets & Accessories
Detail every inch of your engine bay. Motor Coater works on all metal components, giving your entire build a cohesive, show-ready appearance.
Other KBS Products for Your Truck Build
From frames and undercarriages to fuel tanks and headers, KBS has a coating for every part of your build that demands professional-grade protection.
The foundation of any serious truck build. RustSeal permanently stops rust on frames, floor pans, brackets, and body metal. It seals over existing rust and bonds directly to bare metal. No primer needed.
Shop RustSeal
UV-stable chassis paint built specifically for frames, undercarriages, and suspension components. BlackTop holds its deep black finish even after years of sun, road salt, and moisture exposure.
Shop BlackTop
XTC Xtreme Temp Coating
When your headers and exhaust see temperatures Motor Coater isn't rated for, reach for XTC. Formulated to withstand up to 1,500°F, it's the coating for headers, manifolds, and mufflers.
Shop XTC
Gas Tank Sealer Kit
Restore a rusty or leaking fuel tank without replacing it. The three-step Gas Tank Sealer Kit cleans, treats, and permanently seals steel and fiberglass tanks, compatible with all fuels including ethanol blends.
Shop Tank Sealer KitMotor Coater FAQ
New to KBS Motor Coater? Here are the answers to the questions we hear most from truck builders.
