KBS Coatings instructional videos show you exactly how to prep, apply and cure every KBS product from a rusty starting point to a finished, sealed surface. This page collects 82 how-to and demonstration videos organized by product: surface prep and the KBS 3-Step System, RustSeal, Tank Sealer, DiamondFinish Clear, XTC high temperature paint, Motor Coater engine paint, top coats, Cavity Coater, Bed Liner and NuMetal. Every video is free, and most run under six minutes.
Popular searches:
New to KBS? Start with the 3-Step System video below. Nearly every coating failure we troubleshoot on the phone traces back to a prep step that got skipped.
Browse Videos by Product
Getting Started: Prep and the KBS 3-Step System 10
Prep is where a coating job is won or lost. These videos cover degreasing, rust converter and metal etching, paint stripping, priming bare plastic, and the basics of handling KBS paints before a drop ever hits the metal.
3:33
The KBS 3-Step Rust Prevention System: KBS Klean, RustBlast, RustSeal
3:39
How to Prepare Metal for Painting with KBS Klean and RustBlast
15:19
Tips and Tricks for the KBS 3-Step Rust Prevention System
0:23
KBS Strip: Paint Stripper, Paint Remover and Tank Stripper
1:26
How Fusion FPP Flexible Plastics Primer Grips Bare Plastic
3:06
How to Open a Paint Can Without Sticking the Lid
0:48
How to Properly Stir KBS Paints and Coatings
0:35
How to Mix Paint with a Drill: KBS Hurricane Paint Mixer
0:50
How to Use a KBS Paint Spout to Stop Messy Drips
1:34
How to Brush or Roll KBS Coatings
RustSeal Videos 17
RustSeal is the rust preventive paint KBS is known for: a stop-rust chassis and frame paint that seals prepped rust for good. Watch it brushed, sprayed, recoated and put through durability tests.
0:36
RustSeal Durability and Flexibility Demonstration
5:51
Sam Memmolo Shows How to Use RustSeal and Cavity Coater
3:58
How to Spray RustSeal on the Exterior of a Rusty Gas Tank
2:38
How to Apply Another Coat of RustSeal Over Fully Cured RustSeal
4:59
Restoring a Rusty Trailer Door with the 3-Step System and Cavity Coater
3:38
The Many Uses of RustSeal
3:25
Which KBS Products Stop Rust on Which Car Surfaces
4:54
How to Stop Rust on a Truck Frame for Good
6:44
How to Repair Trailer Frame Rust So It Does Not Come Back
5:17
How to Repair and Stop Rust in a Car Floor Pan
5:16
How to Paint Coil Springs and Leaf Springs Without Cracking or Peeling
4:11
How to Prevent Mower Deck Rust
5:08
A Body Repair Method That Keeps Rust From Coming Back
5:12
Using RustSeal to Paint a Gas Tank, Part 1
8:16
Using RustSeal to Paint a Gas Tank, Part 2
2:55
Refinishing a Custom Hand Rail with the KBS 3-Step System
0:56
Refinishing a Rusty Garden Wagon with KBS Coatings
Tank Sealer Videos 8
Sealing a gas tank or fuel tank is a prep-heavy job. These videos walk the full KBS Tank Sealer System, from stripping and etching through the final tank liner coat, on both automotive and motorcycle tanks.
7:34
Simple Steps to Seal a Gas Tank with the KBS Tank Sealer System
3:27
How to Prepare a Fuel Tank for Sealing
5:45
How to Seal a Gas Tank with KBS Tank Sealer
6:37
How to Seal a Metal Fuel Tank Inside and Out
10:44
Sealing a Motorcycle Gas Tank with the KBS Cycle Tank Sealer Kit
13:43
Sealing a Motorcycle Fuel Tank with JP Cycles
3:51
Stacey David of Gearz Seals a Tank with the KBS Tank Sealer System
2:30
The KBS Gas Tank Sealer All-Inclusive Kit
DiamondFinish Clear Videos 12
DiamondFinish Clear is a 1K clear coat that flows out like glass and stays flexible. Watch it over paint, bare metal, patina rust, boat gelcoat, wood and custom work.
0:40
DiamondFinish Clear Durability and Flexibility Demonstration
3:12
The Many Uses of DiamondFinish Clear
0:35
DiamondFinish Clear Lays Out Like Glass
7:16
Best Clear Coat for Metal: Preventing Rust, Peeling and Coating Failure
6:06
How to Clear Coat Over Rust and Preserve the Patina
1:49
How to Open a DiamondFinish Clear Can Without Sticking the Lid
5:06
Reviving Oxidized Fiberglass on a Boat, Part 1
3:44
Reviving Oxidized Fiberglass on a Boat, Part 2
1:06
Restoring Boat Gelcoat with DiamondFinish Clear
0:30
Why Lure Makers Choose DiamondFinish Clear
1:05
Clear Coating a Custom Painted Fire Pit Table
0:52
Adding Gloss and Depth to Custom Artwork with DiamondFinish Clear
XTC High Temperature Coating Videos 7
XTC is high temperature paint built for exhaust headers, manifolds and grills. Prep, spray technique and heat curing are all covered here, plus XTC Clear for added gloss.
3:23
Prepping a Surface for XTC High Temperature Coating
3:24
How to Spray XTC High Temperature Coating
2:00
How to Heat Cure XTC High Temperature Coating
2:41
How to Apply XTC Clear for Added Gloss
6:29
How to Paint Rusty Exhaust Headers So the Finish Will Not Flake
4:17
Motorcycle Exhaust Paint That Preserves and Beautifies
1:06
How to Flush an Aerosol Can for Future Use
Motor Coater Engine Paint Videos 5
Motor Coater is high temp engine paint that also works on brake calipers and engine blocks. These videos show application on engines, calipers and cast surfaces.
Top Coater and BlackTop Videos 6
One-part top coat paints you can brush, roll or spray, including BlackTop chassis paint. Watch application technique and see how KBS Top Coater and BlackTop compare.
2:02
How to Apply KBS Top Coater Aerosol
2:14
KBS Top Coater vs KBS BlackTop: Which 1K Top Coat to Use
2:47
BlackTop Single Stage 1K Chassis Coating
2:46
Restoring and Painting a Primed Toolbox with KBS Top Coater
4:08
4:57
How to Paint an Axle Housing Without Peeling or Rust
Cavity Coater Videos 5
Frame rails, rocker panels, cab corners and battery trays rust from the inside out. Cavity Coater is a cavity wax and internal undercoating that reaches where a brush cannot.
Bed Liner and Bed Renu Videos 3
Textured, durable bed liner coatings for truck beds, tailgates, bumpers and floors.
NuMetal Epoxy Putty Videos 4
NuMetal is a steel-reinforced epoxy putty for filling, rebuilding and repairing metal. The steering wheel repair series is the classic demonstration.
Shop, Home and Marine Projects 5
KBS coatings are not just for chassis work. Concrete garage floors, wood, docks and boats all get coated too.
Need more than a video?
Browse the written application guides →
Browse product directions and TDS sheets →
Ask Our Tech Support Team →Frequently Asked Questions: KBS Instructional Videos
For rusted or contaminated metal, yes. KBS Klean degreases, RustBlast etches and neutralizes rust, and RustSeal seals it. Skipping the cleaner leaves oil that blocks adhesion, and skipping RustBlast leaves the surface too smooth for a mechanical bond. On clean, already-etched bare metal you can go straight to RustSeal.
Use the search box at the top of this page. It searches video titles plus a keyword list built from real customer searches, so typing gas tank, truck frame, exhaust, concrete floor or rust converter will pull up the right videos even when those words are not in the video title.
Most run between one and seven minutes. The longest are full project walkthroughs such as the 15-minute 3-Step tips video and the 13-minute motorcycle tank sealing video. Every thumbnail shows its runtime.
Yes. Click any thumbnail and the video opens in a player right here. Nothing loads from YouTube until you click, which keeps the page fast.
Every KBS product has a technical data sheet and written directions on the product directions pages. For longer project walkthroughs, see the KBS Restoration Center application guides.
Apply between 60 and 90 degrees F with humidity under 70 percent for most KBS products. RustSeal actually uses ambient moisture to cure, so normal humidity helps it. Very cold or very humid conditions slow cure time and can affect flow out.
The KBS YouTube channel has more than 180 videos, and our tech support team has coached thousands of projects that never made it to video. Tell us what you are coating and we will give you the exact process.
Still Not Sure Which Product You Need?
Our tech support team has been answering coating questions from restorers, fabricators and DIYers out of Valparaiso, Indiana for over 40 years. Tell us what you are coating and we will tell you exactly what to buy and how to apply it.
Talk to Tech Support → Shop All KBS Products Subscribe on YouTube
