What is KBS Top Coater Galvanized Aerosol?
KBS Top Coater Galvanized Aerosol is a high-solids, single-component aerosol coating that applies a durable, flat galvanized finish and rust protection directly from a 12 oz. spray can, with no mixing and no spray gun required. One can covers up to 30 square feet per coat, more than twice the coverage of conventional aerosol spray paints, and the formula is 100% UV stable so the finish will not fade or chalk in direct sunlight.
30 sq. ft.
Coverage per 12 oz. Can
100% UV Stable
Will Not Fade or Chalk
When your job calls for aerosol convenience and a galvanized appearance, touch-ups on galvanized fencing, structural steel repairs, farm equipment, or any bare metal that needs quick protection, KBS Top Coater Galvanized delivers professional results without the complexity of two-part coatings or spray equipment. Apply it directly to clean bare metal for fast standalone protection, or use it as the finish coat over KBS RustSeal for a complete two-stage corrosion protection system.
KBS Top Coater Galvanized is made in the USA. Satisfaction guaranteed!
Why Choose KBS Top Coater Galvanized?
- Aerosol convenience, no mixing, no gun
- 12 oz. can covers up to 30 sq. ft. per coat
- 100% UV stable, no fading, no chalking
- Works standalone or over RustSeal
- Galvanized finish for authentic industrial look
KBS Top Coater Galvanized Aerosol works best on galvanized metal touch-ups, bare steel and iron, farm and agricultural equipment, automotive frames and underbody components, structural steel, above-waterline marine hardware, industrial machinery, and electrical conduit. It restores a matching galvanized appearance on damaged factory-galvanized surfaces and adds standalone rust protection on clean bare metal.
- Galvanized Metal Touch-Ups — Repairs scratches, chips, and worn areas on existing galvanized fencing, conduit, gutters, and structural steel while maintaining a matching galvanized appearance.
- Bare Steel and Iron — Applied directly to clean bare metal, KBS Top Coater Galvanized forms a durable protective film that guards against rust and corrosion. For maximum protection, apply over KBS RustSeal.
- Farm and Agricultural Equipment — Protects implements, trailers, livestock panels, grain bins, and outbuilding metal from the harsh combination of outdoor exposure, moisture, and fertilizer contact.
- Automotive Frames and Underbody — Ideal for frame rails, brackets, suspension components, and underbody sheet metal where a factory-galvanized appearance is desired.
- Structural Steel and Ironwork — Suitable for I-beams, angle iron, gates, railings, and architectural metalwork that needs long-lasting corrosion protection without a color topcoat.
- Marine Hardware (Above Waterline) — Boat trailers, dock hardware, mooring cleats, and above-waterline marine fittings that need protection in saltwater-adjacent environments. Not recommended for constant submersion.
- Industrial Equipment and Machinery — Coats machinery housings, storage racks, conveyor frames, and shop equipment where a durable flat galvanized finish is required.
- Electrical Conduit and Junction Boxes — Restores the galvanized finish on metal electrical conduit, enclosures, and utility components exposed to weather.
Can KBS Top Coater Galvanized Go Over Existing Rust?
KBS Top Coater Galvanized can be applied over sound, tightly adhered rust once all loose, flaking, and scaling rust has been removed with a wire wheel and the surface degreased with KBS Klean. Pitted or actively flaking metal needs KBS RustSeal underneath first, since Top Coater Galvanized is a finish coat, not a rust-sealing barrier on its own.
KBS Top Coater Galvanized Aerosol delivers at least twice the coverage of conventional aerosol spray paints, up to 30 sq. ft. per 12 oz. can, in a 100% UV-stable formula that will not fade or chalk. Its high-viscosity, no-run formula supports vertical application and a fast 5 minute touch-dry time, so equipment goes back into service the same day.
- High-Solids Formula: KBS Top Coater Galvanized delivers at least twice the coverage of conventional aerosol spray paints, a 12 oz. can covers up to 30 sq. ft. in one coat. More protection per can, less waste, fewer trips to restock.
- 100% UV Stable: The formula is engineered to resist fading and chalking under continuous direct sunlight. Unlike many zinc-based aerosols that dull or mottle over time, the galvanized finish stays consistent, even on south-facing outdoor surfaces.
- No Runs, No Sags: The high-viscosity formula holds its position on vertical surfaces without dripping or running, even when applying the generous coats needed for proper coverage.
- Aerosol Convenience: No mixing, no pot life to worry about, no spray gun to clean. Shake, spray, and the surface is protected. KBS Top Coater Galvanized is the answer when rust protection is needed fast without setting up spray equipment.
- Fast Dry Time: Touch dry in about 5 minutes and ready to topcoat or recoat in 20 minutes under typical conditions. Apply all coats within 24 hours of each other. Full cure in 24 hours, so the job finishes and equipment returns to service quickly.
- Authentic Galvanized Appearance: The flat galvanized finish blends seamlessly with factory-galvanized surfaces, making it ideal for touch-up repairs on existing galvanized structures without a visible patch.
- System Compatible: Works as a standalone coating on clean bare metal, or as the finish coat over KBS RustSeal for a complete two-stage corrosion protection system.
- Wide Application Window: Apply in temperatures from 50 to 90 degrees F (10 to 32 degrees C) in humidity up to 70%. Suitable for year-round application in most North American climates.
- Made in the USA: KBS Top Coater Galvanized Aerosol is manufactured at KBS Coatings' facility in Valparaiso, IN. Every can ships direct from the factory, so the product is fresh and the purchase supports American manufacturing.
KBS Top Coater Galvanized bonds to bare ferrous metal (steel and iron) and to bare aluminum after proper cleaning and scuffing. It is used across structural and architectural steel, automotive and restoration components, agricultural equipment, industrial machinery, above-waterline marine hardware, and electrical or utility infrastructure. It is not intended for plastic, wood, or masonry surfaces.
- Structural and Architectural Steel
- Bridges, I-beams, angle iron, column bases, rebar, building frames, stairs, and walkways. Provides a professional galvanized finish that blends with hot-dipped galvanized structural elements.
- Automotive and Restoration
- Frame rails, crossmembers, floor pan flanges, door hinges, suspension brackets, and underbody sheet metal. Used as a standalone protective coat or as the final finish over KBS RustSeal in a restoration build.
- Agricultural and Farm Equipment
- Tractor implements, grain bins, livestock panels, hay wagons, trailers, and outbuilding metalwork. Withstands outdoor exposure, moisture, and the corrosive environment around fertilizers and animal waste.
- Industrial Machinery and Equipment
- Machine frames, conveyor systems, storage racking, shop equipment, tool carts, and utility enclosures. Provides a low-sheen, professional-grade finish without color that blends into industrial environments.
- Boat trailers, dock hardware, lifting rings, mooring hardware, and any above-waterline marine metalwork exposed to saltwater spray and UV. Not intended for constant-immersion applications; use KBS RustSeal for submerged components.
- Electrical, Utility, and Infrastructure
- Electrical conduit, junction boxes, utility poles, meter bases, signage hardware, and chain-link fencing. Restores galvanized finish on metal components exposed to weather and UV without requiring a topcoat.
Is KBS Top Coater Galvanized Safe for Aluminum, Plastic, or Wood?
KBS Top Coater Galvanized bonds to bare aluminum once it is cleaned with KBS Klean and lightly scuffed with 320-grit sandpaper. It is not formulated for plastic, wood, or masonry, and applying it to those substrates is not recommended.
One 12 oz. can of KBS Top Coater Galvanized covers up to 30 square feet per coat. General automotive and outdoor jobs typically need 1 to 2 thin coats, while marine or industrial applications with prolonged moisture exposure need 2 to 3 thin coats for maximum film build.
Coverage varies based on surface texture, porosity, and application technique. Rough or porous surfaces absorb more coating and reduce yield. Apply thin coats and build to full coverage rather than attempting heavy single-coat application.
| Can Size |
Typical Coverage (1 Coat) |
Recommended Coats |
| 12 oz. Aerosol |
Up to 30 sq. ft. |
1 to 2 coats general; 2 to 3 coats marine/industrial |
Recoat window: Apply consecutive coats once the prior coat is dry to touch, about 20 minutes. For best adhesion between coats, apply all coats within 24 hours of each other. Full cure is reached in 24 hours.
Pro Tip: Shake the can for at least one full minute after hearing the mixing ball rattle, then shake again for 10 seconds every 1 to 2 minutes during application. Hold the can 8 to 10 inches from the surface and use overlapping side-to-side strokes. When finished, invert the can and spray for 3 seconds to clear the nozzle for future use.
KBS Top Coater Galvanized differs from standard cold galvanizing compound in how it protects metal: standard cold galvanizing compound relies on 90 to 95% zinc content as a sacrificial anode that corrodes in place of the steel until the zinc is depleted, while KBS Top Coater Galvanized uses a high-solids, UV-stable formula that delivers a durable galvanized-look finish coat without a finite protective lifespan tied to zinc consumption.
| | KBS Top Coater Galvanized | Standard Cold Galvanizing Compound |
| Protection mechanism | High-solids UV-stable finish coat | Sacrificial zinc anode (90 to 95% zinc) |
| UV stability | 100% UV stable, will not fade or chalk | Varies, many zinc-rich aerosols dull and mottle in sunlight |
| Coverage per 12 oz. can | Up to 30 sq. ft. per coat | Typically less than half that per can |
| Application equipment | Aerosol can only, no mixing or gun | Aerosol or brush/roller depending on product |
| Full cure time | 24 hours | Varies by manufacturer |
Standard cold galvanizing compound can be the better choice when a spec calls specifically for a minimum percent-zinc content by weight, since KBS Top Coater Galvanized is not formulated as a high-zinc sacrificial coating.
KBS Top Coater Galvanized Aerosol is an excellent standalone rust protection coating for clean bare metal. For a surface that has seen severe corrosion, will be exposed to constant moisture, or needs lifetime protection, apply it over KBS RustSeal for the most effective rust defense system available.
- Step 1 — KBS Klean
- Removes grease, oil, wax, and surface contaminants. A clean surface is the foundation of coating adhesion.
- Step 2 — RustBlast (if needed)
- Converts and removes rust, etches bare metal, and leaves a zinc phosphate surface profile for superior coating adhesion.
- Step 3 — RustSeal
- Moisture-cured, high-solids rust preventive barrier. Forms a permanent, non-porous bond to metal, stopping rust permanently, not sacrificially.
- Step 4 — KBS Top Coater Galvanized Aerosol
- Applied over cured RustSeal (3 to 8 hours) for a UV-stable, galvanized finish that protects the RustSeal layer from UV degradation and delivers the final industrial appearance.
Learn About RustSeal →
Top Coater Aerosol Application Directions
Step-by-step directions for surface prep, spray technique, recoat windows, and cleanup for KBS Top Coater Aerosol.
Read Directions →
Cold Galvanizing Compounds vs. RustSeal: Which Is Better?
A head-to-head breakdown of how zinc-based sacrificial coatings compare against RustSeal's permanent barrier approach across surface prep, longevity, and performance.
What's the Best Rust Preventive Coating?
Compares rust prevention approaches and explains when to use RustSeal, zinc coatings, or a combination for the right application.
How to Prepare Metal Using KBS Klean and RustBlast
Proper surface prep is the single biggest factor in coating adhesion and longevity. Learn how KBS Klean and RustBlast work together before any topcoat application.
KBS RustSeal — Permanent Rust Prevention Coating
RustSeal is KBS Coatings' flagship rust prevention product. Learn why it outperforms zinc-based coatings for long-term protection on tanks, frames, and severely corroded surfaces.
Shop RustSeal →
How to Stop and Prevent Rust on Your Boat Trailer
Boat trailers live in the worst corrosion environment possible. This guide covers the right products and process for protecting trailers from saltwater and road salt.
Have questions before you buy? Find answers to the most common KBS Top Coater Galvanized questions below, or
order now and get it shipped same day.
KBS Top Coater Galvanized Aerosol is a high-solids aerosol coating that delivers a durable, flat galvanized finish with rust protection in a convenient spray can, with no mixing, no spray gun, and no special equipment required. While traditional cold galvanizing compounds rely on 90 to 95% zinc content as a sacrificial anode (meaning the zinc corrodes so the base metal doesn't), KBS Top Coater Galvanized uses a premium high-solids formula that won't run or sag and delivers at least twice the coverage of conventional aerosol spray paints, up to 30 sq. ft. per 12 oz. can. It is also 100% UV stable, so unlike many zinc-based aerosols that dull and mottle in sunlight, the galvanized finish stays consistent over time.
Yes, over sound rust. Wire wheel, sand, or scrape off every bit of loose, flaking, and scaling rust first, then degrease the surface with KBS Klean and let it dry completely. Tightly adhered rust that will not come off with a wire wheel is an acceptable substrate. Avoid solvent-based cleaners, which leave an invisible residue that interferes with adhesion. If the metal is still pitted, scaly, or actively flaking after wire wheeling, the corrosion has gone too deep for a topcoat to fix. Coat it with RustSeal first, which is formulated to bond to light surface rust and seal it, then apply KBS Top Coater Galvanized over the cured RustSeal as the final UV-stable finish coat.
For general automotive and outdoor applications, 1 to 2 thin coats is typically sufficient. For marine or industrial applications with prolonged moisture exposure, apply a minimum of 2 to 3 thin coats for maximum film build. The recoat window opens about 20 minutes after the prior coat, longer with heavy coats or cool, humid conditions. For best adhesion between coats, apply all coats consecutively within 24 hours of each other. Full cure is reached in 24 hours. Always apply thin coats rather than one heavy coat; if the paint runs or sags, the coat is too heavy or the can is too close to the surface.
Apply KBS Top Coater Galvanized Aerosol in temperatures between 50 and 90 degrees F (10 to 32 degrees C). Humidity should be 70% relative humidity or lower. Applying in high humidity can affect cure time and adhesion. Avoid application in direct hot sun where the metal surface itself may be significantly hotter than ambient air temperature, as this can cause the coating to flash-dry before it flows out properly. Early morning application in summer often produces the best results.
Start by shaking the can for at least one full minute after you hear the mixing ball rattle inside; this is critical for proper atomization. Hold the can 8 to 10 inches from the surface. Press the valve all the way down and use overlapping side-to-side strokes, releasing the valve at the end of each pass. Shake the can for about 10 seconds every 1 to 2 minutes during application. Apply thin, even coats; multiple thin coats build better than one heavy coat. If clogging develops, turn the spray tip a quarter turn. When finished, invert the can and spray for 3 seconds to clear the nozzle for future use.
Yes, galvanized touch-up is one of the primary applications for this product. When hot-dipped galvanized fencing, conduit, gutters, or structural steel gets scratched, welded, or cut, the zinc layer is damaged and bare steel is exposed. KBS Top Coater Galvanized Aerosol restores the protective coating and galvanized appearance with a spray can, no spray equipment needed. Clean the area thoroughly to remove all rust and contaminants, then apply 1 to 2 thin coats. The flat galvanized finish blends closely with factory hot-dipped galvanized surfaces.
KBS Top Coater Galvanized Aerosol is formulated primarily for application on ferrous metal (steel and iron) and can also be applied to bare aluminum. It is not intended for plastic, wood, or masonry surfaces. For best adhesion on aluminum, clean the surface thoroughly with KBS Klean and lightly scuff with 320-grit sandpaper before application. If you are unsure about a specific substrate, contact our technical team at kbs-coatings.com/contact-us before proceeding.
Clean up any overspray or wet coating immediately with KBS #1 Thinner or standard lacquer thinner. Always wear protective gloves during cleanup to avoid skin contact and temporary staining. Once the coating has cured, mechanical removal (sanding or scraping) is the only option; solvent cleanup will not remove fully cured Top Coater. For the spray tip, the best preventive measure is to invert the can and spray for 3 seconds after each use to clear the nozzle valve before storage.
One 12 oz. can of KBS Top Coater Galvanized covers up to 30 square feet per coat, more than twice the coverage of conventional aerosol spray paints. Actual yield depends on surface texture and application technique; rough or porous surfaces absorb more product and reduce coverage. For a full breakdown by can size and job type, see the Coverage & Yield Guide above.
No additional topcoat or clear coat is required. KBS Top Coater Galvanized is a finish coat in itself; the flat galvanized sheen is the final appearance. Because the formula is 100% UV stable, it won't fade or chalk in sunlight, so it does not need a UV-protective clear coat the way some zinc-based coatings do. Allow 24 hours of full cure before putting the coated surface back into service or exposing it to water or abrasion. If you applied KBS Top Coater Galvanized over freshly cured KBS RustSeal, your surface now has a complete two-stage corrosion protection system requiring no further coating.
