Rust Prevention Paint: Stop Rust with RustSeal, Rust Converter and Frame Coater Kits
Rust prevention paint seals rusted steel against the moisture and oxygen that feed rust. KBS RustSeal is a single-component, moisture-cured coating that goes over tightly adhered rust and cures non-porous; a quart covers about 50 square feet in two coats. The Frame Coater Kit adds KBS Klean and RustBlast, and KBS Rust Converter treats rust from a 12 oz aerosol.
Which Rust Prevention Product Do I Need?
| Your job | Choose | What you get |
| Prep products on hand, any size job | RustSeal | 8 oz to 5 gallons; a quart covers about 50 sq ft in 2 coats |
| Rust spots to treat fast from a can | KBS Rust Converter | 12 oz aerosol, up to 20 sq ft per can |
| Car or truck frame, about 50 sq ft | Frame Coater Kit | A quart each of KBS Klean, RustBlast and RustSeal |
| Full underbody, up to 100 sq ft | Large Frame Coater Kit | Quart of KBS Klean, gallon of RustBlast, 2 quarts of RustSeal |
| Try the system on a part first, up to 12.5 sq ft | System Sampler Kit | 8 oz each of KBS Klean, RustBlast and RustSeal |
| Big jobs, up to 200 sq ft | Stop Rust Gallon Kit | Gallon-size 3-step system for 2 coats over 200 sq ft |
| Frame that also needs a UV-stable finish coat | All-In-One Chassis Kit | The 3-step system plus a pint of BlackTop, about 50 sq ft |
Rust inside frame rails and doors? The Ultimate Frame Coater Kit adds Cavity Coater and the Cavity Wand. Kit finder | Directions | Ask an expert
Watch the RustSeal durability and flexibility test
$22.00
(460)
$18.00
(22)
$72.00
(158)
$126.00
(39)
$27.00
(133)
$200.00
(2)
(8)
$72.00
(2)
$162.00
(9)
$102.00
(61)
$177.00
(45)
$80.00
(27)
$63.00
(11)
$137.00
(30)
$117.00
(4)
$135.00
(2)
$60.00
(13)
$162.00
(1)
$60.00
(2)
