The KBS MAXX Calculator works out how much KBS MAXX or KBS MAXX Clear, KBS Klean, RustBlast, and KBS #1 Thinner a job needs on wood, steel, aluminum, galvanized steel, fiberglass, concrete, or a painted surface. A gallon kit covers about 450 sq ft per coat, and most surfaces get two coats.
Build Your KBS MAXX Package
Pick the surface and enter its size, and we will put together the KBS MAXX, prep, and thinner the job takes. One click adds it all to your cart.
Shop KBS MAXX, KBS MAXX Clear, and KBS Klean.
KBS MAXX Directions
KBS MAXX FAQs
Concrete Floor Guide
Trailer and Shed Floor Calculator
RustSeal Calculator
Order KBS MAXX
How the Calculator Works
- Coverage: KBS MAXX and KBS MAXX Clear cover about 450 sq ft per gallon kit per coat, about 110 sq ft per quart kit, and about 2,250 sq ft per 5 gallon kit.
- Coats: Two coats on most surfaces, and three where the surface is wet every day or below the waterline, swimming pools included.
- Bare wood: a seal coat thinned 30 to 50% with KBS #1 Thinner, counted at half coverage because it soaks in, then two full coats.
- Concrete: a first coat thinned 25% with KBS #1 Thinner, counted at 30% less coverage, then one full coat (two if wet daily).
- Bare steel: pick KBS MAXX directly, with KBS Klean and RustBlast, or RustSeal under KBS MAXX for the longest protection. Rusty steel goes to the RustSeal Calculator.
- KBS Klean: 1 quart per 200 sq ft on a relatively clean surface, 1 quart per 50 sq ft on a really dirty or greasy one.
- KBS MAXX Clear: works the same way on every surface except over RustSeal, where it does not go.
- Full kits: the calculator rounds up to full kits. Each kit holds the KBS MAXX base and its activator, mixed 3 to 1.
Prep and Coats by Surface
Every surface starts with a KBS Klean wash. This is what each one needs on top of that.
| Surface | Prep | Coats of KBS MAXX |
| Bare wood or plywood | KBS Klean wash; thin the seal coat 30 to 50%, sand 280 to 320 grit | Seal coat plus 2 full coats |
| Bare steel, KBS MAXX direct | KBS Klean and RustBlast | 2, or 3 if wet daily |
| Bare steel, RustSeal build | KBS Klean, RustBlast, 2 coats of RustSeal | 1 |
| Rusty steel | Use the RustSeal Calculator | 1 over RustSeal |
| Aluminum or galvanized steel | KBS Klean wash | 2, or 3 if wet daily |
| Fiberglass | KBS Klean wash | 2, or 3 if wet daily |
| Concrete | KBS Klean wash; new concrete cured 60 days and etched; first coat thinned 25% | 2, or 3 if wet daily |
| Previously painted, sound | Scuff 400 grit if glossy, KBS Klean wash | 2, or 3 if wet daily |
How Much KBS MAXX for Common Jobs
These amounts come from the calculator, before KBS Klean, RustBlast, or thinner.
| Job | Area and coats | KBS MAXX to order |
| Aluminum trailer sides | 100 sq ft, 2 coats | 2 quart kits |
| Galvanized fence panels | 150 sq ft, 2 coats | 1 gallon kit |
| Fiberglass boat hull, below the waterline | 200 sq ft, 3 coats | 1 gallon kit plus 2 quart kits |
| One-car garage floor, concrete | 400 sq ft, thinned first coat plus 1 full coat | 2 gallon kits plus 1 quart kit |
| Painted steel shed or building | 500 sq ft, 2 coats | 2 gallon kits plus 1 quart kit |
| Concrete pool | 800 sq ft, thinned first coat plus 2 full coats | 1 five gallon kit, 1 gallon kit, and 1 quart kit |
How to Measure Your Surface
Not sure of the square feet? Click Help me measure under the square feet box in the calculator. Pick the shape, enter your measurements in feet, and it fills in the square feet for you. This is the math it uses:
- Flat areas: length times width for each floor, wall, panel, or deck, added together. Count both sides of anything you coat on both sides. A one-car garage floor of 16 x 25 ft is 400 sq ft.
- Walls of a building or room: add the length and width, double it, and multiply by the wall height. Take off about 20 sq ft for each door.
- Boat hull below the waterline: length times beam times 0.75, or times 0.85 for a flat-bottom boat such as a jon boat or pontoon. A 20 ft boat with an 8 ft beam is about 120 sq ft.
- Swimming pool: the floor plus the walls. For a rectangular pool, that is length times width, plus 2 times the length plus width, times the average depth. A 32 x 16 ft pool that averages 5 ft deep is about 992 sq ft.
- Round tank, pipe, or cylinder: 3.14 times the diameter times the length. Add the ends if you coat them.
For trailer and shed floors, the Trailer and Shed Floor Paint Calculator works from length and width.
Step-by-Step Guides
The calculator tells you what to order. These guides show how to prep and apply KBS MAXX.
Frequently Asked Questions About How Much KBS MAXX You Need
Divide the square feet by 450 for each coat. A gallon kit of KBS MAXX covers about 450 sq ft per coat, or about 225 sq ft at the usual two coats. A quart kit covers about 110 sq ft per coat and a 5 gallon kit about 2,250. Bare wood and bare concrete take more on the first coat.
Two coats on most surfaces. Surfaces that are wet every day or below the waterline, swimming pools included, get three. A wood floor gets a thinned seal coat plus two full coats. Over RustSeal, one coat of KBS MAXX goes on top of two coats of RustSeal.
For KBS MAXX, a 2K polyurethane, plan on about 450 sq ft per gallon for each coat. A 400 sq ft concrete floor with a thinned first coat and one full coat takes 2 gallons plus 1 quart of KBS MAXX.
Wash it well with KBS Klean. New concrete needs at least 60 days to cure and an etch with muriatic acid first. Thin the first coat 25% with KBS #1 Thinner so it soaks into the bare concrete.
Yes. Wash the surface well with KBS Klean, then apply KBS MAXX. Use two coats, or three where the surface is wet every day or below the waterline.
For the longest protection, yes. Two coats of KBS MAXX alone tested to 1,000 hours of salt spray, and two coats of RustSeal plus one coat of KBS MAXX tested to 2,000 hours. Rusty steel always gets RustSeal first.
No. KBS MAXX Clear does not go over RustSeal. Use pigmented KBS MAXX, BlackTop, or KBS Top Coater over RustSeal.
Only the first coat on bare wood, thinned 30 to 50%, and on bare concrete, thinned 25%. Everywhere else KBS MAXX does not have to be thinned, but many people like to thin it with KBS #1 Thinner.
For a boat hull below the waterline, multiply the length by the beam by 0.75, or by 0.85 for a flat-bottom boat: a 20 ft boat with an 8 ft beam is about 120 sq ft. For a rectangular pool, add the floor (length times width) to the walls (2 times the length plus width, times the average depth): a 32 x 16 ft pool that averages 5 ft deep is about 992 sq ft. The Help me measure button in the calculator does this math for you.
More KBS MAXX questions and answers: KBS MAXX FAQs
Still have questions about KBS MAXX? Our technical team is ready to help.
