Spray Guns and Sprayers for KBS Coatings
Match the KBS product to the gun before you buy: RustSeal, BlackTop, DiamondFinish Clear and most KBS liquid coatings spray through the KBS HVLP Spray Gun with a 1.4mm tip, build primers and KBS Top Coater need the same gun with the 1.8mm tip, small parts and detail work run on the 1.0mm KBS HVLP Mini Spray Gun, and undercoatings, cavity waxes and bed liner need the Schutz Underseal Spray Gun instead of an HVLP gun.
Which Spray Gun Do I Need for My KBS Product?
Every sprayable KBS coating is listed below with the gun it is meant to go on and the tip size that applies. Generic coating types are at the bottom for paint you did not buy from KBS.
| Product | Recommended Applicator | Tip Size |
| Liquid Coatings, HVLP Spray Gun | ||
| RustSeal | KBS HVLP Spray Gun, or KBS HVLP Mini Spray Gun for small parts | 1.4mm, or 1.0mm Mini |
| BlackTop | KBS HVLP Spray Gun, or KBS HVLP Mini Spray Gun for small parts | 1.4mm, or 1.0mm Mini |
| DiamondFinish Clear | KBS HVLP Mini Spray Gun for small parts, KBS HVLP Spray Gun for panels | 1.0mm Mini, or 1.4mm |
| KBS MAXX | KBS HVLP Spray Gun, or KBS HVLP Mini Spray Gun for small parts | 1.4mm, or 1.0mm Mini |
| KBS MAXX Clear | KBS HVLP Mini Spray Gun for small parts, KBS HVLP Spray Gun for panels | 1.0mm Mini, or 1.4mm |
| KBS Top Coater | KBS HVLP Spray Gun, 1.8mm tip | 1.8mm |
| Motor Coater Engine Paint | KBS HVLP Spray Gun, or KBS HVLP Mini Spray Gun for small parts | 1.4mm, or 1.0mm Mini |
| XTC Xtreme Temperature Coating | KBS HVLP Spray Gun, or KBS HVLP Mini Spray Gun for small parts | 1.4mm, or 1.0mm Mini |
| XTC Zinc Rich Primer | KBS HVLP Spray Gun, or KBS HVLP Mini Spray Gun for small parts | 1.4mm, or 1.0mm Mini |
| XTC Clear | KBS HVLP Spray Gun, or KBS HVLP Mini Spray Gun for small parts | 1.4mm, or 1.0mm Mini |
| KBS Fusion SEP Self-Etching Primer | KBS HVLP Mini Spray Gun, or KBS HVLP Spray Gun | 1.0mm Mini, or 1.4mm |
| KBS 2K DTM Build Primer | KBS HVLP Spray Gun, 1.8mm tip | 1.8mm |
| Undercoating, Cavity Wax and Bed Liner | ||
| KBS Bed Liner | Schutz Underseal Spray Gun, or roll on | No tip selection |
| KBS UnderCoat Solvent Based Asphalt | Schutz Underseal Spray Gun | No tip selection |
| KBS UnderCoat Water Based Asphalt | Schutz Underseal Spray Gun | No tip selection |
| KBS UnderCoat Solvent Based Rubberized | Schutz Underseal Spray Gun | No tip selection |
| Cavity Coater | Schutz Underseal Spray Gun with the 48-inch 360-degree wand | No tip selection |
| Generic Coating Types | ||
| Basecoat or single stage automotive paint | KBS HVLP Spray Gun | 1.4mm |
| 2K clear coat | KBS HVLP Spray Gun, or Mini for small parts | 1.4mm, or 1.0mm Mini |
| Build primer, primer surfacer or sealer | KBS HVLP Spray Gun, 1.8mm tip | 1.8mm |
| Self-etching primer | KBS HVLP Mini Spray Gun | 1.0mm |
| Chassis, frame or suspension paint | KBS HVLP Spray Gun | 1.4mm |
| High heat header or exhaust paint | KBS HVLP Spray Gun | 1.4mm |
| Truck bed liner | Schutz Underseal Spray Gun | No tip selection |
| Undercoating or rubberized coating | Schutz Underseal Spray Gun | No tip selection |
| Cavity wax | Schutz Underseal Spray Gun with the 48-inch 360-degree wand | No tip selection |
| Small touch-up areas, any KBS liquid coating | Preval Sprayer Kit, no compressor needed | No tip selection |
Three things apply no matter which gun you use: reduce only with KBS #1 Thinner and never lacquer thinner, strain the paint through a 100 micron filter before it goes in the cup, and fit a Dry Air Spray Gun Filter at the gun inlet so downstream moisture does not cause fisheye. Full pressure, fan and technique settings are covered in the guide below.
