Designed to cure KBS Patch when sunlight is not feasible or available.
Order KBS Patch HERE!
The KBS UV Light is a portable, lightweight, handheld UV flashlight containing 51 Ultraviolet LED bulbs for greater area coverage.
The KBS UV Light is powered by 3 AA batteries (not included) and features an aircraft aluminum alloy body and is water resistant. A set of batteries will run the flashlight for 20 hours.
LED: 51
Bulb Type: LED 390 to 395nm
Bulb Life: 10,000 hours
Body Material: Aluminum with O-rings for water resistance
Batteries Required: 3 x AA alkaline batteries
Battery Life: Approximately 20 hours on 3 AA batteries
Switch Type: Push On/Off Button
Weight: 10 oz. (285g) including batteries
Head Diameter: 57mm
Body Diameter: 36mm
Length: 147mm
5.0
