Gold Standard Tank Sealer covers about 100 square feet per quart at 2 mils, so one KBS kit seals most tanks: an 8 oz can for tanks up to 5 gallons, a pint up to 12 gallons, a quart up to 25 gallons, 2 quarts up to 50 gallons, and a gallon up to 100 gallons.
Tank Sealer Quantity at a Glance
100 sq ft
Per Quart at 2 Mils
400 sq ft
Per Gallon at 2 Mils
Up to 100 Gal
Sealed by One Kit
96 Hours
Full Cure Before Fuel
Tank Sealer Kit by Tank Size:
Use this guide to decide which Tank Sealer Kit to order, or how much KBS Klean, RustBlast and Gold Standard Tank Sealer to buy for a larger tank. Every kit includes all three steps of the KBS 3-Step Tank Sealing System, plus nitrile gloves, a stir stick and instructions.
Tank Size
Kit
What Is in the Kit
Up to 5 gallons
Quart of KBS Klean, quart of RustBlast, 8 oz Gold Standard Tank Sealer
Up to 5 gallons, old liner
Everything in the Cycle Kit plus a quart of KBS Strip
5 to 12 gallons
Quart of KBS Klean, quart of RustBlast, pint of Gold Standard Tank Sealer
5 to 12 gallons, old liner
Everything in the Large Cycle Kit plus a quart of KBS Strip
12 to 25 gallons
Half gallon of KBS Klean, quart of RustBlast, quart of Gold Standard Tank Sealer
25 to 50 gallons
Gallon of KBS Klean, gallon of RustBlast, 2 quarts of Gold Standard Tank Sealer
50 to 100 gallons
Gallon of KBS Klean, gallon of RustBlast, gallon of Gold Standard Tank Sealer
KBS Cycle Tank Sealer Kit, up to 5 gallons
Up to 5 gallons
Shop This Kit
KBS Cycle Tank Sealer PLUS Kit, up to 5 gallons, old liner
Shop This Kit
KBS Large Cycle Tank Sealer Kit, 5 to 12 gallons
5 to 12 gallons
Shop This Kit
KBS Large Cycle Tank Sealer PLUS Kit, 5 to 12 gallons, old liner
Shop This Kit
KBS Auto Fuel Tank Sealer Kit, 12 to 25 gallons
12 to 25 gallons
Shop This Kit
KBS Tank Sealer Kit for 25 to 50 Gallon Tanks, 25 to 50 gallons
25 to 50 gallons
Shop This Kit
Tanks Over 50 Gallons:
For tanks over 50 gallons, order the individual products in gallon and quart cans. A 50 to 100 gallon tank can also be sealed with the KBS Tank Sealer System in the 50-100 Gal size, which packs the same three gallons in one kit. Order these amounts:
Tank Size
50 to 100 gallons
1 Gallon
1 Gallon
1 Gallon
100 to 125 gallons
2 Gallons
2 Gallons
1 Gallon + 1 Quart
125 to 150 gallons
2 Gallons
2 Gallons
1 Gallon + 2 Quarts
150 to 200 gallons
2 Gallons
2 Gallons
2 Gallons
Larger than 200 gallons? Please give us a call at (219) 263-0073 and we will help you order the correct quantity.
Shop KBS Klean | Shop RustBlast | Shop Gold Standard Tank Sealer
Tank Sealer Coverage:
On porous surfaces like rust and corrosion, Gold Standard Tank Sealer covers approximately 100 sq. ft. per quart or 400 sq. ft. per gallon (9.5 m2 per liter) at 2 mils (50um) thickness. Coverage will vary depending on surface profile, application method and film thickness.
Because coverage is measured in square feet, the tank's interior surface area, not how many gallons of fuel it holds, is what sets the amount you need. The Tank Sealer Directions call for pouring in the entire can, coating every surface and draining the excess.
Please keep in mind that these are just guidelines. Coverage will vary based on application, condition of tank, substrate of tank, and other factors.
Tanks With an Old Liner:
Tank Sealer bonds to a bare surface prepped with KBS Klean and RustBlast, so a previous liner or sealer has to come out first with KBS Strip. For tanks up to 12 gallons, the Cycle Tank Sealer PLUS Kit and Large Cycle Tank Sealer PLUS Kit add a quart of KBS Strip to the standard kit. For larger tanks, see removing an old tank liner or call us for a quantity.
Which Tanks This Guide Covers:
This guide is for most tanks, including gas tanks, diesel tanks, fiberglass tanks, tractor gas tanks, oil tanks, utility tanks and non-potable water tanks. Gold Standard Tank Sealer may be used on steel, aluminum, and fiberglass tanks.
Plastic and polyethylene tanks are different: they need Fusion SEP first, because Tank Sealer alone will not bond to plastic. Use the Plastic Tank Sealer Kit instead of the kits above.
Frequently Asked Questions About How Much Tank Sealer You Need
A car or truck tank up to 25 gallons takes one quart of Gold Standard Tank Sealer. The Auto Fuel Tank Sealer Kit includes that quart plus a half gallon of KBS Klean and a quart of RustBlast. A tank from 25 to 50 gallons takes 2 quarts, which come in the Tank Sealer Kit for 25 to 50 Gallon Tanks.
A motorcycle tank up to 5 gallons takes an 8 oz can of Gold Standard Tank Sealer, which comes in the Cycle Tank Sealer Kit. A tank from 5 to 12 gallons takes a pint, which comes in the Large Cycle Tank Sealer Kit. If the tank has an old liner, choose the PLUS version of either kit, which adds a quart of KBS Strip.
On porous surfaces like rust and corrosion, Gold Standard Tank Sealer covers approximately 100 sq. ft. per quart or 400 sq. ft. per gallon at 2 mils thickness. Coverage will vary depending on surface profile, application method and film thickness. The published figures are in the Tank Sealer Technical Data Sheet.
Yes, a single appropriately sized Tank Sealer Kit can seal multiple tanks. Prep both tanks first; KBS Klean and RustBlast can be poured from one tank to the next. Then pour a portion of the Tank Sealer from the can into each tank. Never drain Tank Sealer from one tank into another. Once it has been drained out of a tank it is no longer good. The details are in Can I Split Tank Sealer Between Tanks?.
No. Plastic and polyethylene tanks need Fusion SEP first, because Tank Sealer alone will not bond to plastic. Use the Plastic Tank Sealer Kit and follow the Plastic Tank Sealer Directions.
Allow 96 hours for Tank Sealer to reach maximum cure before adding fuel. Leave the tank openings open so air can reach the coating, keep the tank out of direct sunlight and away from heat, and test the tank with water before refilling it with fuel.
Still have questions about how much Tank Sealer to order? Our technical team is ready to help.
More Tank Sealer questions and answers: Tank Sealer Questions
Instructional & How-To Videos
Simple Steps to Seal a Gas Tank with the KBS Tank Sealer System
Watch more tank sealing videos on the KBS Instructional Videos page.
Shop Tank Sealer Kits: All 3 Steps in One Box
