Complete Tank Sealer Directions
Tank Sealer Tech Data Sheet
Tank Sealer Chemical Resistance
Avoid Common Tank Sealer Mistakes
Tank Sealer How-To Guide
Tank Sealer Questions and Answers
Sealing a Plastic Tank Instead
KBS Instructional Videos
Order a Tank Sealer Kit
The KBS 3-Step Tank Sealing System restores a fuel tank in three steps: KBS Klean cleans and degreases, RustBlast removes rust and leaves a zinc phosphate etch, and Gold Standard Tank Sealer coats the inside in a single pour. Apply between 55 and 82 degrees F and allow 96 hours to cure before adding fuel.
Why Tank Sealing Takes Three Steps:
KBS Coatings products are designed to work as a complete system. Gold Standard Tank Sealer gives superior rust protection and sealing when it goes over a tank that has been cleaned with KBS Klean and prepped with RustBlast. Used together, the three products stop rust, seal the tank permanently, and keep rust from returning.
Each product does one job, and each job sets up the next. KBS Klean cleans the surface thoroughly, and RustBlast etches the metal to leave an anchor pattern. Together they give Tank Sealer lasting adhesion, and the cleaner the tank, the stronger that adhesion. This page is an overview of how the system works. For every detail, read the complete Tank Sealer Directions or follow the Tank Sealer Flow Chart.
Step 1: Clean with KBS Klean
Step 2: Prep with RustBlast
Step 3: Seal with Tank Sealer
Curing and Refueling:
Allow 96 hours for maximum cure before refilling the tank with fuel. Leave the tank openings open so air can reach the coating. Do not put the tank in direct sunlight or near a heat source to speed things up: heating the tank does not speed curing and may hinder adhesion. Test the tank with water before adding fuel. Once cured, a properly coated tank is rated for operating temperatures up to 600 degrees F.
Plastic, Fiberglass, and Previously Sealed Tanks:
Plastic Tanks
Hard plastic and polyethylene tanks need Fusion SEP in place of RustBlast, because Tank Sealer alone will not bond to plastic. The Plastic Tank Sealer Kit includes KBS Klean, Fusion SEP, and Tank Sealer. Follow the Plastic Tank Sealer Directions.
Fiberglass Tanks
Fiberglass tanks use the same three steps with one change in Step 2: RustBlast contact is limited to 2 minutes. See Fiberglass Tanks in the directions.
Tanks with an Old Sealer or Liner
Any previous coating has to be fully stripped before Step 1. KBS Strip removes old sealers, and the Cycle Tank Sealer PLUS kits include a quart of it. See Remove an Old Tank Liner Before Sealing.
Tanks Already Cleaned with Vinegar
Vinegar is not a substitute for the prep steps. A tank cleaned with vinegar still goes through the full 3-step system, starting with KBS Klean.
Which Tank Sealer Kit Do I Need?
Every KBS metal tank sealer kit includes all three steps in one box. Pick the kit by the size of your tank:
3-Step Quick Reference:
Frequently Asked Questions About the 3-Step Tank Sealing System
Still have questions about the 3-Step Tank Sealing System? Our technical team is ready to help.
More Tank Sealer questions and answers: Tank Sealer Questions
Get Instant Answers from the KBS Support Desk Contact Us for Technical AssistanceInstructional & How-To Videos
Watch more tank sealing videos on the KBS Instructional Videos page.
