How to Mix and Apply 2K Paint: It's Easier Than You Think
Posted by KBS Coatings on 9/24/2026 to
To mix 2K paint, measure the paint and hardener at the labeled ratio, mix thoroughly and apply it within its pot life. This guide walks through every step using KBS MAXX, a 3:1 2K topcoat.
Rubberized Undercoating: Why It Traps Rust and How to Apply It So It Does Not
Posted by KBS Coatings on 9/14/2026 to
Rubberized undercoating does not cause rust. It traps rust under one condition: sprayed over metal that is not clean, dry and already sealed. Here is the fix.
How to Paint a Motorcycle Exhaust to Prevent Peeling, Flaking and Rust
Posted by KBS Coatings on 9/9/2026 to
Learn how to paint a motorcycle exhaust to help prevent rust, peeling, flaking, and burn-off with proper surface prep, high-temp paint, and heat curing.
