How to Paint a Tractor That Stays Painted
To paint a tractor that stays painted, remove loose rust and failing paint, clean with KBS Klean, etch bare metal with RustBlast, seal it with two coats of RustSeal, then topcoat with KBS MAXX, a UV-stable 2K urethane tractor paint.
This guide follows a rusty, weathered tractor hood from bare-metal prep to a glossy 2K finish. It also covers brushing versus spraying and the tractor colors KBS MAXX comes in: John Deere® Classic Green, John Deere® Ag Yellow, John Deere® Industrial Yellow, and New Cat® Yellow.
Painting a Tractor at a Glance
Products, in orderKBS Klean, RustBlast, RustSeal, KBS MAXX
RustBlast dwell30 minutes on light rust, 40 to 60 minutes on moderate rust, 1 to 2 hours on heavy rust, kept wet
RustSeal2 thin coats, about 2 mils each, 2 to 6 hours apart, applied at 55 to 82°F
Topcoat timingKBS MAXX directly over RustSeal 3 to 8 hours old, or after 24 hours with a 320 grit scuff or a Fusion SEP dust coat
KBS MAXX mix3 parts Base to 1 part Activator; mix only what you can apply in 30 minutes
KBS MAXX application45 to 110°F, at least 5°F above the dew point, 1.5 to 2.0 mils per coat, recoat in 30 minutes to 3 days
Full cureKBS MAXX: usually at least 7 days
Salt spray (ASTM B117)2,000 hours for 2 coats of RustSeal plus 1 coat of KBS MAXX
What Should You Check Before Repainting a Tractor?
Before repainting a tractor, check the old paint and the metal under it to decide what comes off and what can stay. Look for peeling, cracking, blistering, and chipped paint, and for rust around seams, edges, mounting points, and anywhere water sits.
You do not have to strip all the old paint. Paint that is firmly bonded and in good condition can stay after proper prep. Loose, flaking, or failing paint has to come off, because new paint can only hold as well as the layer under it.
Check rusted areas for pitting, thin metal, or rust that has eaten through. Deep corrosion or structural damage needs repair before you paint. On an older tractor, also look for past repairs and thick layers of old paint.
Man in nitrile gloves inspecting peeling paint and rust on a green tractor hood set on sawhorses
Check seams, edges, and mounting points first: that is where tractor rust starts.
What You Need to Paint a Tractor
Painting a tractor takes four KBS coatings used in order, KBS Klean, RustBlast, RustSeal, and KBS MAXX, plus basic sanding tools, mixing and spraying equipment, and proper protective gear.
Rust Removal and Surface Prep
  • Wire brushes and a wire wheel
  • Sandpaper and sanding discs in several grits, including 320 grit
  • Dual-action sander or sanding block
  • Paint scraper
  • Scotch-Brite pads
  • Clean rags, sponges, and scrub brushes
  • Spray bottles and rinse water
  • Masking tape and plastic sheeting
KBS Coatings Products
  • KBS Klean: removes grease, oil, and dirt so the coatings can bond
  • RustBlast: removes residual surface rust and etches the metal
  • RustSeal: seals the metal against moisture and stops rust from coming back
  • KBS Fusion SEP Self-Etching Primer (optional): skip it when you topcoat RustSeal within 3 to 8 hours or scuff it with 320 grit
  • KBS MAXX Base and Activator: the UV-stable color coat
  • KBS #1 Thinner (optional): only if your spray gun or roller calls for reduction
Mixing and Painting Equipment
Safety Equipment
Follow the product labels and Safety Data Sheets for every coating and chemical. Spraying two-component urethanes such as KBS MAXX can expose you to isocyanates, so use the respiratory protection and spray-area controls the Safety Data Sheet specifies.
How Do You Remove Rust and Old Paint from a Tractor?
To remove rust and old paint from a tractor, scrape, wire brush, and sand away loose rust and failing paint until you reach a sound surface. With RustSeal, you do not need bare, rust-free metal: tightly bonded rust can stay, but loose, flaky, and scaled rust must go.
Start with a scraper or wire brush on peeling paint. On larger, flatter panels such as the hood and fenders, use a dual-action sander or sanding block, and feather the edges of the sound paint you keep so the new coating blends in.
For rust, use a wire wheel, abrasive disc, or coarse sandpaper. Work seams, mounting holes, and corners carefully, since rust grows there unseen. Small wire brushes and folded sandpaper reach tight spots.
Avoid heavy grinding that thins or warps sheet metal. Once the loose rust and failing paint are gone, the surface is ready to clean and etch.
Man sanding old green paint off a tractor hood with a dual-action sander
A dual-action sander takes failing paint off the hood and feathers the edges of what stays.
How Do You Clean and Prepare Tractor Metal for Painting?
To prepare tractor metal for painting, wash it with KBS Klean to remove grease and dirt, then etch bare and rusted metal with RustBlast, which removes leftover surface rust and leaves a zinc phosphate coating that helps RustSeal bond.
Clean with KBS Klean
Mix 1 part KBS Klean with 5 parts hot water and apply it with a brush, sponge, or spray bottle. Scrub seams, joints, and recesses where grease and grime collect. Rinse well with clean water, then let the surface dry completely. See the KBS Klean directions for dilutions on other jobs.
Man scrubbing a tractor hood grille with a sponge and KBS Klean solution
KBS Klean at 5 parts hot water to 1 part lifts grease out of the grille and seams.
Etch with RustBlast
Apply RustBlast full strength to the exposed metal and keep it wet the whole time: at least 30 minutes on smooth or lightly rusted metal, 40 to 60 minutes on moderate rust, and 1 to 2 hours on heavy rust. Scrub with a Scotch-Brite pad to work it into seams, corners, and pits. Never let RustBlast dry on the surface.
Rinse with clean water before the RustBlast dries. The rinse neutralizes the acid and prevents a heavy zinc phosphate buildup, while leaving the thin zinc phosphate layer that helps RustSeal bond. Let the surface dry completely. The metal is now ready for RustSeal. See the RustBlast directions for full details.
Man scrubbing RustBlast into bare spots on a tractor hood with a green Scotch-Brite pad
Keep RustBlast wet and work it into pits with a Scotch-Brite pad, then rinse once.
How Do You Protect a Tractor from Rust Before Painting?
To protect a tractor from rust before painting, apply two thin coats of RustSeal, about 2 mils each. RustSeal is a moisture-cured rust preventive coating that seals out moisture and air, and encapsulates tightly bonded rust. Two coats of RustSeal under one coat of KBS MAXX reached 2,000 hours of salt spray (ASTM B117).
RustSeal cures hard and stays flexible, so it will not crack, chip, flake, or peel, and it levels out to minimize brush marks. It is not UV stable, though: its color and sheen chalk and fade in direct sun. On a tractor that works outdoors, RustSeal needs an opaque, UV-stable topcoat such as KBS MAXX.
Brush, roll, or spray RustSeal between 55 and 82°F, ideally at 30 to 80% relative humidity, and not in rain or when the surface cannot stay dry. Stir from the bottom of the can; do not shake it. Pour a working amount into a KBS Paint Mixing Cup instead of painting from the can, and store leftovers in a steel can or glass jar, not the cup. Thinning usually is not needed. For spraying, reduce 5 to 10% with KBS #1 Thinner or xylene only if needed; never use lacquer thinner.
Thin coats cure more completely than heavy ones. Apply the second coat when the first is dry to the touch and takes no fingerprint, typically 2 to 6 hours. If more than 8 hours pass, wait a full 24 hours and lightly scuff with 320 grit before recoating. See the RustSeal directions and the RustSeal FAQs for more.
What Is the Best Paint for a Tractor?
The best paint for a tractor is a two-component (2K) urethane such as KBS MAXX over a rust preventive base coat. 2K urethane holds its color and gloss in the sun and resists chemicals, abrasion, and weather better than conventional tractor enamel.
Tractor enamel costs less and is easy to brush, so it suits a quick refresh. Conventional enamels tend to fade, chalk, and lose gloss sooner, though.
KBS MAXX is a single-stage 2K polyurethane, so you get the gloss of a base coat and clear coat in one product. It is permanently UV stable and bonds directly to ferrous metal and aluminum.
What Tractor Paint Colors Are Available?
KBS MAXX comes in four tractor and heavy equipment colors: John Deere® Classic Green, John Deere® Ag Yellow, John Deere® Industrial Yellow, and New Cat® Yellow, along with a full range of other stock colors.
KBS MAXX Tractor and Heavy Equipment Colors
KBS MAXX colorTypical use
John Deere® Classic Green (Gloss)Traditional green John Deere® tractor components
John Deere® Ag Yellow (Gloss)Wheels and other yellow agricultural parts
John Deere® Industrial Yellow (Gloss)Industrial tractors and utility equipment
New Cat® Yellow (Caterpillar® Yellow)Equipment that needs the familiar Caterpillar® yellow
Manufacturers have changed shades over the years, so check the make, model, and year before you paint, especially when you are matching panels you are not repainting.
Chart of KBS MAXX tractor paint colors with swatches for John Deere Ag Yellow, Classic Green, Industrial Yellow, and New Cat Yellow
KBS MAXX tractor and heavy equipment colors.
RustSeal rust preventive coating cans
Seals the prepped metal against rust under the color coat.
Shop RustSeal
KBS MAXX 2K urethane paint cans with MAXX Activator bottles
UV-stable 2K tractor paint in John Deere® and Cat® colors.
Shop KBS MAXX
RustBlast rust remover and metal etch bottles
Removes leftover surface rust and etches the metal for RustSeal.
Shop RustBlast
Is It Better to Brush or Spray Tractor Paint?
Spraying gives a smoother, more even finish on large panels such as hoods and fenders, while brushing is more practical on small parts, brackets, and hard-to-reach areas. KBS MAXX can be brushed, rolled, or sprayed, so most tractor jobs use both.
Spraying needs masking, ventilation, and respiratory protection. A KBS HVLP Spray Gun with the 1.4mm tip sits inside the 1.0 to 1.5mm tip range for KBS MAXX. For brushing, a poly bristle brush lays KBS MAXX down better than natural bristle, and a high-density foam roller works on flat panels.
For this hood, we sprayed KBS MAXX for a smooth, glossy finish.
How Do You Mix and Apply KBS MAXX?
To apply KBS MAXX, prepare the RustSeal surface, mix 3 parts KBS MAXX Base to 1 part Activator, and apply 1.5 to 2.0 mils per coat between 45 and 110°F. Mix only what you can use in 30 minutes, and recoat any time from 30 minutes to 3 days without scuffing.
Prepare the RustSeal for KBS MAXX
Pick one of three ways to get KBS MAXX to bond to RustSeal:
  • Direct method: apply KBS MAXX once the final RustSeal coat is dry to the touch and between 3 and 8 hours old, with no other prep.
  • Scuffing method: let RustSeal cure at least 24 hours, then scuff it with 320 grit sandpaper before applying KBS MAXX.
  • Self-etching primer method: let RustSeal cure at least 24 hours, dust on a light coat of KBS Fusion SEP Self-Etching Primer, and wait at least 30 minutes before applying KBS MAXX.
Mix KBS MAXX
Mix the KBS MAXX Base until it is smooth and uniform; a Hurricane Paint Mixer on a drill does this quickly. In a KBS Paint Mixing Cup, measure 3 parts Base to 1 part Activator and mix thoroughly. KBS MAXX is pre-thinned and ready to apply. If your spray gun calls for reduction, add 5 to 10% KBS #1 Thinner or xylene; for rolling, about 5%. Never reduce KBS MAXX with lacquer thinner.
Mixed KBS MAXX doubles in viscosity in about 30 minutes, so mix only what you can apply in that time and leave the rest unmixed.
Apply KBS MAXX
Work in a well-ventilated area with the respiratory protection and safety gear the Safety Data Sheet specifies. Two-component urethanes can contain isocyanates, which makes respiratory protection especially important when spraying.
Apply KBS MAXX only when the surface is between 45 and 110°F and at least 5°F above the dew point. Brush, roll, or spray 1.5 to 2.0 mils per coat. Recoat any time from 30 minutes to 3 days with no scuffing. Build the finish with properly applied coats instead of one heavy coat, since excess film slows drying and curing.
How Long Does KBS MAXX Take to Cure?
KBS MAXX is dry to the touch in 30 minutes and hard enough to handle in 3 to 4 hours, but full cure usually takes at least 7 days. Wait the full 7 days before hard use or reinstalling tractor parts. Cool temperatures and heavy coats lengthen cure time.
See the KBS MAXX directions and KBS MAXX FAQs for spray settings and more detail.
Painter in a respirator spraying KBS MAXX John Deere Classic Green over a grey tractor hood
KBS MAXX sprayed at 1.5 to 2.0 mils per coat over RustSeal.
How Do You Keep Tractor Paint from Peeling or Rusting Again?
To keep tractor paint from peeling or rusting again, repair chips and scratches as soon as you find them, wash off mud, fertilizer, and road salt regularly, and store the tractor under cover when you can. Even a well-built paint system wears where dirt, chemicals, and impacts hit it every day.
Inspect painted surfaces now and then, especially edges, mounting points, and spots that take regular contact or abrasion. Touch up chips quickly so exposed metal cannot start rust that creeps under the paint around it.
Wash with a mild cleaner and skip abrasive scrubbing that can dull the finish. Clear packed debris out of seams and recesses, where moisture hangs on. Covered storage cuts down on moisture and sun exposure and helps the finish last.
Can You Paint a Car With Tractor Paint?
Yes, if the tractor paint is a 2K urethane such as KBS MAXX. KBS MAXX is a single-stage 2K polyurethane topcoat made for automotive, fleet, agricultural, marine, and industrial refinishing, so the paint that coats a tractor hood also works on a car, truck, or trailer. The prep is the same: clean with KBS Klean, etch bare steel with RustBlast, and seal rusted areas with RustSeal.
How Much Does It Cost to Have a Tractor Painted?
KBS Coatings does not paint tractors, so we cannot quote shop rates. Most of a shop's price is labor for stripping and prep. If you do the work yourself, estimate materials from coverage: RustSeal covers about 200 square feet per gallon at the recommended two coats, and KBS MAXX covers about 450 square feet per gallon per coat at 2 mils.
Is Rustoleum Tractor Paint Any Good?
It works for a quick refresh. Single-component tractor enamel, the type most hardware and farm stores sell, is affordable and easy to brush, but it tends to fade, chalk, and lose gloss sooner in sun and weather. A 2K urethane such as KBS MAXX holds its color and gloss longer and resists chemicals and abrasion better, which matters on a tractor that lives outdoors.
Can You Buy Paint at Tractor Supply?
Yes. Tractor Supply sells tractor paint, and KBS Coatings products are sold through Tractor Supply. Every KBS product, including KBS MAXX in all four tractor colors, also ships direct from kbs-coatings.com.
Can You Use the Same Coating System on Other Farm Equipment?
Yes. KBS Klean, RustBlast, RustSeal, and KBS MAXX work on the properly prepared metal of plows, mower decks, implements, trailers, and other farm equipment. Follow the same order: clean, etch, seal, then topcoat anything that sits in the sun.
Can You Paint a Tractor Outdoors?
Yes, but it is harder to control. Wind carries dust and overspray onto wet paint, and direct sun heats panels unevenly. Choose a sheltered spot, apply RustSeal between 55 and 82 degrees F, and apply KBS MAXX between 45 and 110 degrees F with the surface at least 5 degrees F above the dew point.
RustSeal stops the rust, and KBS MAXX in factory-style tractor colors gives the tractor a high-gloss finish that holds up outdoors. Both are made in the USA. Satisfaction guaranteed.
Finished tractor hood in glossy John Deere Classic Green KBS MAXX on sawhorses
The finished hood: RustSeal under KBS MAXX in John Deere® Classic Green.
Find Your RustSeal Kit Shop RustSeal Only Shop KBS MAXX
Related guides: How to Paint a Rusty Farm Plow Without Sandblasting, How to Prevent Mower Deck Rust, How to Remove Rust from a Tractor Fuel Tank, or browse all KBS application guides.
