The primary purpose of RustSeal, cold galvanizing compounds, and zinc rich coatings is to prevent rust. RustSeal prevents rust and corrosion in a very different way than zinc coatings. So, which is the best rust preventive coating?
Read More
How to Black Out Chrome Trim with Paint: A Permanent Chrome Delete
Black out chrome trim the permanent way. KBS BlackTop over a Fusion SEP dust coat gives a factory satin chrome delete that will not lift or peel like vinyl.
Read More
RustSeal Safety Colors for Industrial Equipment and Floor Markings
Using safety colors for painting industrial equipment and floor markings is done regularly to enhance visibility, identify potential hazards, and promote workplace safety. RustSeal Safety Colors are formulated to do just that and are used to protect both indoor industrial equipment and as floor markings.
Read More
Using Nonconductive Coatings as Part of an EV Conversion
Converting internal combustion engine powered vehicles to electric power is increasing in popularity. Electrical components must be mounted on non-conductive surfaces. You can make metal surfaces nonconductive with nonconductive coatings. See how RustSeal can be used as for this purpose.
Read More
