KBS Coatings has two application flow charts. The RustSeal flow chart shows how to prep and seal rusty steel with the KBS 3-Step System, and the Tank Sealer flow chart shows how to strip, clean, prep, and seal a fuel tank. Open the one that matches your project, or print it for the shop.
RustSeal Flow Chart
RustSeal flow chart: how to stop rust on steel with the KBS 3-Step System
For rusty or new steel: when sandblasted metal can go straight to RustSeal, how KBS Klean and RustBlast come first, how many coats to apply, and when and how to topcoat.
View the RustSeal Flow Chart Print the PDF
Tank Sealer flow chart: how to seal a fuel tank with the KBS 3-step system
For fuel tanks: stripping an old sealer, cleaning with KBS Klean, the right Step 2 prep for steel, aluminum, fiberglass, or hard plastic, sealing, draining, and the 96 hour cure.
View the Tank Sealer Flow Chart Print the PDF
Which Flow Chart Do I Need?
Your Project
Use This Chart
Frame, chassis, trailer, or any rusty steel you want to paint
Inside of a gas, fuel, or oil tank
Hard plastic fuel tank
Tank Sealer Flow Chart, Fusion SEP path
For the full written procedure behind each chart, see the KBS 3 Step System and RustSeal Directions, or the 3-Step Tank Sealing System and Tank Sealer Directions.
These flow charts are general application guidelines. They do not cover every application or environmental situation.
Contact Us for Technical Assistance
