Trailer Floor Coating: How to Seal a Plywood Trailer Floor With KBS MAXX
The best trailer floor coating for a plywood or wood deck is a two-component moisture-cured polyurethane such as KBS MAXX. Seal the clean, dry wood with a thinned first coat, sand it, roll on two or three full coats, and let it cure 7 days before you load the trailer.
Trailer Floor Coating at a Glance
Coating a Plywood Trailer Floor With KBS MAXX at a Glance
ProductsKBS Klean, KBS MAXX, KBS #1 Thinner
Coats1 thinned seal coat, then at least 2 full coats (3 is better)
Mix ratio3 parts base to 1 part activator; 30 minute pot life
Application temperature45 to 110°F surface, at least 5°F above the dew point
Recoat window30 minutes to 3 days, no scuffing
Ready to load7 day full cure
CoverageAbout 450 sq ft per gallon per coat at 2 mils; less on the seal coat over bare wood
Why Coat a Plywood Trailer Floor?
A plywood trailer floor needs a coating because bare wood absorbs water from rain, wet tires, and road spray, then swells, rots, and delaminates. KBS MAXX seals the wood against that moisture and puts a hard film on top that takes cargo abrasion, oil drips, and the scraping of equipment rolling on and off the ramp.
Enclosed cargo trailers, open utility trailers, car haulers, and landscape trailers all fail the same way. Water gets into the plywood at the seams, the ramp door, and the edges, and the floor goes soft long before the frame wears out. Coating a new deck before its first load, or a sound older deck before it starts to soften, costs less than tearing out and replacing the floor.
What Is the Best Coating for a Trailer Floor?
The best coating for a wood trailer floor is one that bonds to plywood, seals out water, and stays hard under heavy loads. KBS MAXX is a two-component moisture-cured polyurethane that does all three: it seals the wood fibers with a thinned first coat, cures to a film rated at 160 inch-pounds of direct and indirect impact resistance (the same impact energy as a 4-pound hammer dropped from 40 inches), and is permanently UV stable.
KBS MAXX also handles what a working trailer floor sees:
  • Rated Excellent against lubricating and cutting oils, and passes JP-5 jet fuel at 70°F for 7 days, so drips from mowers, ATVs, and generators wipe up instead of soaking in.
  • Permanently UV stable, so the floor near an open ramp door or on an open utility trailer holds its color and gloss.
  • Brush, roll, or spray application, and 25+ standard colors. KBS MAXX Clear is the option if you want to keep the look of the wood.
This is the same process KBS customers use on wood shed floors. One customer coated a 200 sq ft tongue and groove OSB shed floor with KBS MAXX in Blue Mayhem:
Customer shed floor of tongue and groove OSB coated with KBS MAXX in Blue Mayhem, high gloss finish
A 200 sq ft OSB shed floor coated with KBS MAXX Blue Mayhem. A trailer deck gets the same seal coat and full coats.
How Much KBS MAXX Do You Need?
KBS MAXX covers about 450 sq ft per gallon per coat at 2 mils, and a quart covers about 110 sq ft per coat. Bare wood soaks up the thinned seal coat, so plan on up to 50% less coverage for that first coat. A 6 x 12 cargo trailer floor takes about one gallon for the seal coat plus two full coats.
KBS MAXX for a seal coat plus two full coats, by trailer size
Trailer floorFloor areaWhat to order
5 x 8 ft40 sq ft2 quarts
6 x 12 ft72 sq ft1 gallon
7 x 14 ft98 sq ft1 gallon
8.5 x 20 ft170 sq ft2 gallons
These numbers use the nominal deck size, count the seal coat at half coverage, and assume two full coats. The same orders also cover a third full coat, which gives the floor the best protection, on every size except the 7 x 14, which needs one more quart. KBS MAXX also comes in a 5 gallon size for large decks.
What You Need
  • KBS Klean: cleans dirt, grease, and oil out of the wood before coating
  • NuMetal Epoxy Putty (optional): fills knots, voids, and dings in the face of the plywood; skip it if the deck surface is sound
  • Flexible, non-silicone exterior sealant for the seams between plywood sheets
  • KBS MAXX: the seal coat and the full coats (comes with its MAXX Activator)
  • KBS #1 Thinner: thins the seal coat 30 to 50% and the rolling coats about 5%
  • KBS Paint Mixing Cup: measures the 3 to 1 mix and the thinner
  • KBS Hurricane Paint Mixer: mixes the high-solids MAXX base thoroughly before you add the activator
  • KBS Poly Paint Brush for cutting in edges and corners, plus a high-density foam roller for the field
  • 280 to 320 grit sandpaper
  • Chemical-resistant gloves, safety glasses, and a well-ventilated work area; open both doors of an enclosed trailer and keep air moving
How to Prep a Trailer Floor for Coating
Prep a trailer floor by re-fastening loose sheets, filling defects and seams, washing the wood with KBS Klean, and letting it dry 24 to 48 hours. KBS MAXX bonds well to clean, dry wood, and no coating holds on a deck that is dirty or damp.
Step 1: Empty and Inspect the Deck
Clear everything out of the trailer and walk the whole floor. Re-fasten any loose sheets. KBS MAXX flexes with the wood, so the normal flex of a trailer floor is no problem. Remove loose or flaking paint. Sand rough wood smooth. Smooth, clean wood does not need sanding before the seal coat. A pressure-treated deck is fine to coat once it has dried out thoroughly; prep it the same way as any raw, unsealed wood.
Step 2: Fill Defects and Seams
Fill knots, voids, and dings in the face of the plywood with NuMetal Epoxy Putty, which bonds to wood and cures steel-hard in about 12 hours at 75°F. Keep NuMetal out of the seams between sheets, because those seams move. Fill them with a flexible, non-silicone exterior sealant instead, and let it cure fully before coating.
Step 3: Clean the Wood With KBS Klean
Mix 1 part KBS Klean with 25 parts water, scrub the deck with a stiff brush, and rinse with clean water. Pay extra attention to oil and grease spots where equipment has been parked. Full mixing rates are on the KBS Klean directions page.
Step 4: Let the Wood Dry Completely
Let the washed deck dry 24 to 48 hours, depending on temperature and airflow. To check, tape down a small piece of plastic sheeting. If condensation forms under it, the wood needs more time.
How to Apply KBS MAXX to a Trailer Floor
Apply KBS MAXX to a trailer floor in two stages: a seal coat thinned 30 to 50% with KBS #1 Thinner, then at least two full coats after a 24 hour cure and a light sanding. Work when the surface is between 45 and 110°F and at least 5°F above the dew point, and mix only what you can apply in 30 minutes.
Step 5: Mix and Apply the Seal Coat
  • Mix the KBS MAXX base thoroughly with the KBS Hurricane Paint Mixer or a mixing blade on a variable speed drill.
  • In a KBS Paint Mixing Cup, measure 3 parts mixed base and add 1 part MAXX Activator. Mix thoroughly.
  • Thin the mixed KBS MAXX 30 to 50% with KBS #1 Thinner or xylene. Never use lacquer thinner as a reducer.
  • Cut in the edges with a poly brush, then roll one covering coat over the deck so it soaks into the wood.
  • Let the seal coat cure 24 hours.
If you can reach the edges of the plywood or the underside of the deck, seal those too. Every exposed face of the wood is a path for water.
Step 6: Sand the Raised Grain
The seal coat raises the wood grain. Sand the floor smooth with 280 to 320 grit sandpaper, then sweep and vacuum up all the dust.
Step 7: Roll On the Full Coats
Mix KBS MAXX at 3 to 1 and thin it about 5% with KBS #1 Thinner for rolling. Apply at least two full coats with a high-density foam roller; three full coats give a trailer floor the best protection. Roll a section and move on, without over-rolling. Recoat anywhere from 30 minutes to 3 days with no scuffing. Past 3 days, scuffing is not required, but the surface has to be completely clean before the next coat.
At 77°F and about 70% relative humidity, KBS MAXX is dry to the touch in about 30 minutes, through dry in 1 to 2 hours, and hard in 3 to 4 hours, so all the full coats fit in one day. Cool or damp weather slows every one of those times.
Step 8: Let It Cure Before Loading
Let the last coat cure 7 days before you load the trailer. Walking on the floor after it is hard is fine, but hold off on cargo, equipment, and ratchet straps until the full cure is done. Complete mixing and application details are on the KBS MAXX directions page, and answers to other common questions are in the KBS MAXX FAQs.
How to Make a Trailer Floor Non-Slip
To make a KBS MAXX trailer floor non-slip, stir a dry traction additive into the mixed coating for the final coat. A gloss floor gets slick when it is wet or muddy, which matters on a ramp door and anywhere you walk equipment in and out.
  • Use fine silica sand, polypropylene anti-skid beads, or micronized aluminum oxide. The additive must be completely dry.
  • KBS publishes no ratio for traction additives in KBS MAXX. Test your mix on a scrap board first.
  • Stir the additive in gently, apply right away, and stir often while rolling to keep it suspended.
  • More grit means more traction but a floor that is harder to sweep. You can limit it to the ramp and the first few feet inside the door.
KBS MAXX 2K polyurethane topcoat in quart and gallon cans with MAXX Activator
Seals the plywood and builds the hard, oil-resistant floor
Shop KBS MAXX
KBS Klean water based cleaner and degreaser in gallon, quart, and 8 oz bottles
Washes dirt and oil out of the deck before coating
Shop KBS Klean
KBS #1 Thinner in gallon, quart, and 8 oz bottles
Thins the seal coat so it soaks into the wood
Shop KBS #1 Thinner
What About the Trailer Frame and Roof?
A coated floor lasts longest on a trailer whose steel frame is not rusting underneath it. Stop frame rust with RustSeal, using the step-by-step process in our trailer rust guide, ideally before or along with the floor job.
KBS MAXX also bonds directly to aluminum with no primer, so it works on a bare aluminum enclosed trailer roof that sits outside. Scuff the aluminum with 600 grit sandpaper, wash it with KBS Klean, let it dry completely, and apply two coats. Because KBS MAXX is permanently UV stable, the roof holds its color in full sun.
Frequently Asked Questions About Trailer Floor Coating
What to put on a wood trailer floor?
Put a two-component moisture-cured polyurethane such as KBS MAXX on a wood trailer floor. KBS MAXX bonds to plywood and solid wood, seals out the moisture that swells and rots a deck, and cures to a hard film rated at 160 inch-pounds of impact resistance, the same impact energy as a 4-pound hammer dropped from 40 inches. Seal the wood with a thinned first coat, then roll on two or three full coats.
How much to refloor a trailer?
The cost to refloor a trailer depends on its size, the wood you choose, and local labor rates, so get a quote from a trailer shop in your area. If the deck is still solid, coating it costs only the coating and a weekend of work. If you do put in new plywood, sealing it with KBS MAXX before the first load protects that investment.
How many coats of KBS MAXX does a trailer floor need?
A trailer floor needs one thinned seal coat of KBS MAXX, then at least two full coats. Three full coats is better. Thin the seal coat 30 to 50% with KBS #1 Thinner, let it cure 24 hours, sand with 280 to 320 grit, then apply the full coats anywhere from 30 minutes to 3 days apart.
How long before you can load a coated trailer floor?
Wait 7 days after the last coat of KBS MAXX before you load the trailer. KBS MAXX is hard in 3 to 4 hours at 77°F and about 70% relative humidity, which is fine for walking on, but it needs the full 7 day cure before it takes cargo, equipment, or tie-down hardware. Cool or damp weather slows the cure.
Can you coat a pressure-treated plywood trailer floor?
Yes, as long as the pressure-treated plywood has dried out thoroughly. Treat it like raw, unsealed wood: clean it with KBS Klean, confirm it is dry with the taped plastic sheet test, then apply a seal coat of KBS MAXX thinned 30 to 50% with KBS #1 Thinner, sand, and roll on the full coats.
Can you coat over an old painted trailer floor?
Yes, if the old paint is well bonded. Remove any loose or flaking paint, scuff the remaining finish, and clean it with KBS Klean. KBS MAXX goes over sound, well adhered paint. Strip or sand off any coating that is peeling, then treat that bare wood like new wood with a thinned seal coat.
What do you put in the seams between plywood sheets?
Fill the seams between plywood sheets with a flexible, non-silicone exterior sealant and let it cure fully before you coat. KBS MAXX goes right over it. Do not use silicone, and do not fill the seams with a hard filler such as epoxy putty, because the sheets move. Save NuMetal Epoxy Putty for knots, voids, and dings in the face of the plywood.
Can a trailer floor coating be non-slip?
Yes. Stir a dry traction additive, such as fine silica sand, polypropylene anti-skid beads, or micronized aluminum oxide, into the mixed KBS MAXX for the final coat. KBS publishes no additive ratio, so test the mix on a scrap board first, stir often while you roll, and keep in mind that more grit makes the floor harder to sweep.
Protect the Deck Before the First Load
A plywood trailer floor costs far more to replace than to protect. Coat it before the first load on a new trailer, or as soon as an older deck starts to stain and soak up water. The job takes one weekend of work: KBS Klean, a thinned KBS MAXX seal coat, two or three full coats, then 7 days of cure before you load it.
Related guides: How to protect a wood shed floor with KBS MAXX, how to stop trailer rust, how to prevent rust on a boat trailer, or browse all KBS application guides.
