How to Brush Metallic Paint Without Streaks
Metallic colors look best sprayed, but they brush well with the right method. Learn why metallic flake streaks and how to brush KBS metallic colors smoothly.
Read More
How to Repair a Dusting Concrete Floor Before Applying a Long-Lasting Coating
A dusting concrete floor will peel any coating you put on it. Learn how to test, grind, repair and coat it with KBS RustSeal and KBS MAXX for a floor that lasts.
Read More
How to Seal a Rusted Galvanized Stock Tank (Even a Duck Pond) So It Stops Leaking for Good
A rusted galvanized stock tank doesn't need to be replaced. Learn how to clean, etch, and permanently seal it with KBS Klean, RustBlast, RustSeal, and BlackTop.
Read More
How to Protect a Battery Tray from Rust, Corrosion & Battery Acid
Neutralize battery acid, remove corrosion, and coat battery trays with KBS RustSeal for long-lasting, acid-resistant rust protection. Step-by-step guide.
Read More
How to Fix Hidden Rust in Rocker Panels, Cab Corners, and Body Seams
Rust behind rocker panels and cab corners is often worse than it looks. Learn how to inspect, repair, and permanently stop hidden rust with KBS RustSeal.
Read More
