RustSeal comes in 11 colors: Gloss Black, Satin Black, Grey, Off-White, Silver, Galvanized, Safety Blue, Cat Yellow, Oxide Red, Safety Green and Safety Yellow. Every color gives the same rust protection, because the resin does the sealing and the pigment only adds color. Choose by look, sheen and whether the part sits in the sun.
RustSeal Colors at a Glance
11 Colors
Same Rust Protection in Every Color
Gloss to Matte
Sheen Varies by Color
8 oz to 5 Gal
Can Sizes, Most Colors
UV Topcoat
Needed in Direct Sun
RustSeal Color Chart:
Color
Sheen
Best For
Gloss Black
Gloss, 85 to 95%
Frames, chassis, restoration
Satin Black
Satin, 65 to 75%
OEM-look chassis and underbody
Grey
Gloss, 80 to 90%
Steel, concrete, block, floors
Off-White
Gloss, 80 to 90%
Primer under light topcoats
Silver
Gloss, 80 to 90%
Bare-steel look, workplace metal
Galvanized
Matte, about 30%
Galvanized look on steel
Safety Blue
Gloss, 80 to 90%
Industrial equipment
Cat Yellow
Gloss, 80 to 90%
Heavy equipment
Oxide Red
Matte, 65 to 75%
Industrial steel
Safety Green
Gloss, 80 to 90%
Safety Yellow
Gloss, 80 to 90%
Safety marking, equipment
Black, Grey and White
RustSeal Gloss Black color swatch
GLOSS BLACK (Gloss, 85 to 95%): A rich black with a long-lasting wet shine. A popular choice for every kind of automotive restoration, including frames and chassis.
RustSeal Satin Black color swatch
SATIN BLACK (Satin, 65 to 75%): A rich black with a low-luster, uniform sheen that compares to OEM finishes. Use it when you want the original look of a hard, semi-gloss chassis finish. Satin Black is a satin, not a flat.
RustSeal Grey color swatch
GREY (Gloss, 80 to 90%): A medium grey that cures to a smooth, very hard finish. Seals and protects steel, concrete, cinder block, warehouse floors, plywood and more.
RustSeal Off-White color swatch
OFF-WHITE (Gloss, 80 to 90%): A tough white metal primer. The right RustSeal to use under light colored topcoats.
Industrial Colors
The industrial colors carry high concentrations of solidifying metal flake and/or micronized iron oxide for extreme abrasion, corrosion and impact performance.
RustSeal Silver color swatch
SILVER (Gloss, 80 to 90%): A hard silver metallic finish made for workplace protection. Use it to reproduce the look of bare steel. Like all metallic colors, it looks best sprayed.
RustSeal Galvanized color swatch
GALVANIZED (Matte, about 30%): Reproduces the look of an industrial galvanized matte finish. An outstanding maintenance finish that will not crack, peel or blister. Spray it for the most even metallic look.
RustSeal Safety Blue color swatch
SAFETY BLUE (Gloss, 80 to 90%): A brilliant safety blue with micronized corrosion barrier pigments, made for industrial equipment maintenance.
RustSeal Cat Yellow color swatch
CAT YELLOW (Gloss, 80 to 90%): The yellow recognized on any work site as Cat Yellow, with micronized corrosion barrier pigments. Made for heavy vehicle and equipment maintenance.
RustSeal Oxide Red color swatch
OXIDE RED (Matte, 65 to 75%): A deep matte iron red with high hide and coverage, used in many kinds of industrial applications to cut the maintenance cost of rust and corrosion.
RustSeal Safety Green color swatch
SAFETY GREEN (Gloss, 80 to 90%): A rich green gloss with high levels of micronized corrosion barrier pigments for high hide and coverage. It will not crack, peel or blister.
RustSeal Safety Yellow color swatch
SAFETY YELLOW (Gloss, 80 to 90%): A bright safety yellow in a gloss finish, sold in quarts, gallons and 5 gallon pails.
How to Choose a RustSeal Color:
  • Frames, chassis and undercarriage: Gloss Black for shine, Satin Black for an OEM look. Out of direct sun, RustSeal works as the final finish on its own.
  • Under a light colored topcoat: Off-White.
  • Heavy and industrial equipment: Cat Yellow, Safety Blue, Safety Green, Safety Yellow or Oxide Red.
  • A bare steel or galvanized look: Silver or Galvanized. Metallic colors look best sprayed; see the Paint Spraying Guidelines.
  • Concrete, cinder block and floors: Grey. See sealing concrete with RustSeal.
  • Anything in direct sun: pick any color, then topcoat it with an opaque, UV-stable topcoat. For exterior trim, grilles and chrome-delete parts, use BlackTop instead of RustSeal.
Does Color Change Rust Protection?
No. Customers often ask whether colors need porous pigments that let moisture through the coating. A little paint chemistry answers it. Paint is a combination of solvents, resins and pigments. The choice of resin decides whether a coating is porous, and the pigments, fully encapsulated in that resin, only provide color. Pigments do not decide porosity, and resins do not decide color.
Some pigments are porous. Black carbon is the most porous of all. Once that carbon is encapsulated in the correct resin, though, the result is a non-porous coating, and the same holds for less porous pigments. That is why every RustSeal color seals out moisture the same way.
RustSeal Sheen Levels:
Gloss Black cures to 85 to 95 percent sheen, and the other gloss colors to 80 to 90 percent. Satin Black and Oxide Red cure to 65 to 75 percent, and Galvanized to roughly 30 percent. Satin Black is a true satin, not a flat, so it has some sheen by design.
For a flatter finish, reduce RustSeal up to 20 percent with KBS #1 Thinner or Xylene. Mix the can thoroughly, apply thin coats, and wait for the full 24 hour cure before you judge the sheen. If Satin Black comes out glossier than expected, read Why Is RustSeal Satin Black Too Glossy?
RustSeal Colors in Direct Sunlight:
RustSeal is not UV stable. Its rust protection does not break down in sunlight, but every color will chalk and fade over time. On any part that sits in direct sun, topcoat RustSeal with an opaque, UV-stable topcoat: BlackTop for frames and chassis, KBS Top Coater, or KBS MAXX.
A clear coat does not solve this. DiamondFinish Clear and KBS MAXX Clear let UV pass through to the RustSeal underneath, which still fades. For bonding methods and timing, see Can I Top Coat RustSeal?
Sizes, Blending and Custom Colors:
Every RustSeal color comes in quart, gallon and 5 gallon pail sizes, and every color except Safety Yellow also comes in 8 oz and pint cans. Look up any color and size in the KBS Part Number Lookup.
RustSeal is not custom color matched. You can blend stock RustSeal colors with each other, with no minimum. Mix enough for the whole job in one batch so every coat matches.
Order RustSeal: Choose From 11 Colors
Frequently Asked Questions About RustSeal Colors
RustSeal comes in 11 colors: Gloss Black, Satin Black, Grey, Off-White, Silver, Galvanized, Safety Blue, Cat Yellow, Oxide Red, Safety Green and Safety Yellow. Every color is sold in quart, gallon and 5 gallon sizes, and every color except Safety Yellow also comes in 8 oz and pint cans.
With RustSeal, no color protects better than another. The resin, not the pigment, is what seals out moisture, so every color gives the same rust protection. Pick the color for the look: Gloss Black or Satin Black for frames and chassis, Off-White under light topcoats, and the industrial colors for equipment.
No. Paint is a mix of solvents, resins and pigments. The resin decides whether a coating is porous, and the pigment only provides color. Some pigments are porous, black carbon most of all, but once they are fully encapsulated in the right resin the cured coating is non-porous. That holds for every RustSeal color.
Yes. RustSeal is not UV stable. Its rust protection holds up in sunlight, but the color and sheen will chalk and fade. On parts that sit in direct sun, topcoat RustSeal with an opaque, UV-stable topcoat such as BlackTop, KBS Top Coater or KBS MAXX. A clear coat will not stop the fading.
No. RustSeal is not custom matched; custom color matching is offered only for Motor Coater, KBS MAXX and XTC. You can blend stock RustSeal colors with each other. Mix enough for the whole job in one batch so the color stays consistent.
Usually because the can was not mixed well enough. The matting agents settle during storage and have to be stirred back into suspension. Heavy coats and judging the sheen before the full 24 hour cure also make Satin Black look glossier. See Why Is RustSeal Satin Black Too Glossy?.
Use Off-White under light colored topcoats. Whatever color you use, the topcoat over RustSeal must be opaque and UV stable wherever it sees direct sun. For bonding windows and methods, see Can I Top Coat RustSeal?.
Still have questions about RustSeal colors? Our technical team is ready to help.
More RustSeal questions and answers: RustSeal Questions
RustSeal in Action
The Many Uses of RustSeal For Stopping Rust and Preventing Rust
Watch more RustSeal videos on the KBS Instructional Videos page.
Order RustSeal: Choose From 11 Colors Shop RustSeal Kits
