How to Fix a Rough, Faded, or Oxidized Water Slide: Restore Speed and Performance
Why Your Water Slide Feels Rough: Fading, Oxidation, and How to Fix Surface Wear
A rough-feeling water slide is usually caused by fading, oxidation, and surface wear breaking down the original gelcoat, creating drag and slowing riders. Restoring a smooth, high-performance surface requires proper cleaning, preparation, and applying a durable coating that seals and smooths the slide for consistent speed and long-term protection.
Why Water Slides Fade, Oxidize, and Wear Over Time
Waterslides are most often made of fiberglass with a gelcoat applied to the flume (sliding surface) to provide a smooth, low-friction finish while protecting the fiberglass from water, chlorine, UV exposure, and abrasion.
Over time, UV exposure breaks down the gelcoat, accelerating oxidation and leading to fading, chalking, and surface degradation. Continuous water flow, rider traffic, and exposure to chlorine, cleaners, sunscreen, and other chemicals further accelerate wear.
What Causes a Water Slide to Feel Rough?
As the gelcoat oxidizes, it becomes porous, causing the surface to micro-pit and erode, allowing contaminants to become embedded and resulting in the loss of the original smooth, sealed finish.
How Surface Degradation Affects Slide Performance and Appearance
Water slide surface degradation and loss of finish smoothness increase friction, slowing ride speeds and creating inconsistent performance from one run to the next. As the gelcoat breaks down, appearance also suffers, with fading, dulling, and a chalky surface.
Can a Worn or Faded Water Slide Be Restored?
Water slide restoration is possible when the fiberglass structure remains sound and damage is limited to the surface. Faded, oxidized, or worn gelcoat can typically be restored with a coating, while deep cracks, delamination, or structural damage require more extensive repair before coating.
What Type of Coating Works Best on Water Slides?
Polyurethane coatings are most commonly used to restore a smooth, low-friction surface on waterslide flumes and tubes because they form a durable, protective layer that resists wear and maintains performance.
These coatings are designed to withstand common forms of gelcoat degradation, including fading, oxidation, and surface wear caused by UV radiation, water, abrasion, and chemical exposure.
Why Polyurethane Performs Better for Water Slide Maintenance
- UV stability: Polyurethane coatings are UV stable because their chemical structure resists UV breakdown, and they're often enhanced with stabilizers that help reduce UV damage and prevent oxidation, extending the coating's lifespan.
- Gloss retention: Gloss retention in polyurethane coatings comes from resistance to UV breakdown and oxidation, which prevents surface chalking and micro-roughness, maintaining a high-gloss, slick surface over time.
- Smooth, sealed surface: Polyurethane coatings form a continuous, non-porous film that seals the surface and fills tiny imperfections. This creates an even, low-friction barrier that reduces drag, keeps contaminants out, and helps maintain consistent ride speed and performance.
- Durability: Polyurethane coatings form a tough, flexible film that resists abrasion from riders, constant water flow, and exposure to chlorine and other chemicals. This helps the surface hold up over time, reducing wear and extending the life of the slide while maintaining performance.
Ready to restore your water slide?
KBS MAXX delivers a smooth, UV-stable, high-gloss finish that protects fiberglass and gelcoat for years.
Shop KBS MAXX NowWhy KBS MAXX Is a Strong Choice for Water Slide Restoration
KBS MAXX is a strong choice for water slide restoration, maintenance, and protection because it combines durability, ease of use, and long-term performance. This single-stage, two-component (2K) moisture-cured polyurethane coating features low VOCs and HAPs, excellent adhesion, and superb opacity.
Its high-solids formulation delivers a smooth, glossy, attractive finish, while permanent UV stability ensures consistent performance in demanding environments. KBS MAXX and its Medium Activator mix easily to create a pre-thinned coating ready for spray, roller, or brush application.
- Moisture-cured urethane: As a 2-component moisture-cured polyurethane, KBS MAXX cures strongly in humid conditions, forming a strong, crosslinked film that delivers a durable, well-adhered coating resistant to abrasion, water exposure, and chemicals.
- UV stability: Permanent UV resistance enables KBS MAXX to maintain consistent performance in harsh sunlight and weather without degradation.
- High-gloss, smooth finish: KBS MAXX's superior resistance to UV breakdown and oxidation prevents surface chalking and micro-roughness for excellent gloss retention.
- Flexible, durable film: Advanced Linked Coatings Technology creates a finish that's hard yet flexible, allowing KBS MAXX to withstand heavy rider traffic, impacts, and abrasion without cracking, chipping, or peeling.
- Advanced chemical resistance: KBS MAXX protects water slide surfaces from chlorine, cleaners, sunscreen, and body oils, preventing breakdown, staining, and premature wear while maintaining a smooth, durable, low-friction finish.
- Application versatility: KBS MAXX can be applied by brush, roller, or spray equipment and features excellent flow-out for a smooth finish with no brush marks.
- Fast curing: The 2K moisture-cured polyurethane formulation of KBS MAXX enables faster cure times, allowing the slide to be returned to service with minimal downtime.
The Right Way to Fix Water Slide Surface Wear
Proper water slide restoration follows a structured process that ensures strong coating adhesion and long-term performance. Skipping or combining steps often leads to premature failure. The process includes four key preparation stages before coating:
- Cleaning
- Mechanical abrasion
- Surface evaluation
- Preparing for coating
These steps provide a general framework. The process below walks through each step in detail to ensure proper surface preparation and coating application.
How to Prepare and Apply KBS MAXX on a Water Slide
Step 1: Clean the Surface Thoroughly
Remove all surface contamination with KBS Klean, a concentrated cleaner that removes dirt, oils, and other contaminants without leaving adhesion-hindering residue.
- Mix 1 part KBS Klean with 5 parts hot water
- Scrub with a sponge or bristle brush
- Rinse and dry thoroughly
Full instructions for KBS Klean, including recommended dilution rates, can be found HERE.
Step 2: Mechanically Abrade the Surface
- Sand gelcoat with 120 to 220 grit to remove oxidation and chalking
- Create a uniform, dull/matte surface (no glossy areas)
- Use orbital sanding on open areas, hand sanding for curves and seams
- Avoid sanding into fiberglass or leaving deep scratches
Step 3: Inspect and Address Surface Issues
- Check for problem areas: Look for cracks, chips, deep wear, or exposed fiberglass that could affect performance or coating adhesion
- Identify uneven wear: High-traffic zones may have more erosion, pitting, or roughness that needs extra attention
- Address minor defects: Smooth out rough spots and feather edges so the surface is consistent before coating
- Ensure structural soundness: The surface should be solid and stable; coatings are not a fix for underlying structural issues
- If repairs are needed: KBS offers KBS NuMetal Epoxy Putty and KBS Patch to fill and repair damaged areas
Step 4: Final Cleaning
Repeat Step 1 using KBS Klean to remove all sanding dust and residue before applying the coating.
Step 5: Apply KBS MAXX
How to Mix KBS MAXX
Proper mixing ensures chemical balance and optimal curing.
- Begin by thoroughly mixing KBS MAXX Base, stirring upward from the bottom of the can or using a mechanical mixer (e.g., KBS Hurricane Paint Mixer)
- Once fully mixed, measure 3 parts MAXX Base and 1 part MAXX Activator into a clean container
- Mix thoroughly until the consistency is uniform
- Mixed MAXX Base and Activator doubles in viscosity in 30 minutes
This 3:1 ratio activates the curing process, producing a coating that resists impacts, chemicals, UV damage, and abrasion.
KBS MAXX Base and MAXX Activator are pre-thinned and ready to spray, but you can also add KBS #1 Thinner or xylene as needed.
Application Tips
- Apply between 45 and 110°F, staying at least 5°F above the dew point. Avoid extreme heat, cold, or wet conditions
- Apply a minimum of three thin, even coats
- Multiple thin coats provide better adhesion and durability than a few thick ones
- Avoid puddling and pooling
- Recoat time window: after 30 minutes and up to 3 days
Step 6: Allow Proper Cure Time
Allow KBS MAXX to fully cure before placing the slide into service.
Cure Times (at 77°F, 70% relative humidity):
- Dry to the touch: ~30 minutes
- Fully dry: 1 to 2 hours
- Hard cure: 3 to 4 hours
- Full cure: 7 days
Full instructions for KBS MAXX can be found HERE.
Clear vs. Colored Coatings for Water Slides
KBS MAXX is available in 23 rich, opaque, UV-stable colors that shield gelcoat and fiberglass from UV exposure, protecting the surface from fading, oxidation, and degradation.
KBS MAXX Clear is offered in three sheens and is typically used when the existing surface is in good condition and preserving its original color and appearance is important, while still restoring smoothness and protection.
Not sure which color to choose?
Browse all 23 KBS MAXX colors, or go with MAXX Clear to preserve the original look of your slide.
View KBS MAXX Colors Shop MAXX ClearWhen Should You Recoat a Water Slide?
If you notice these conditions, the waterslide is ready for refinishing:
- Loss of gloss, dull spots
- Fading, whitening, oxidation
- Increased surface friction and drag
Why Timing Matters
Recoating early, when fading, oxidation, and loss of gloss first appear, helps restore smoothness and protect the surface before wear becomes more severe. Waiting too long increases surface damage, making restoration more difficult, costly, and less effective.
Key Takeaways: Fixing Rough, Faded, and Worn Water Slides
- Fading, oxidation, and wear are the root cause
- Roughness and slow speed are symptoms
- Smooth, glossy surfaces increase rider speed
- Proper surface preparation before coating is critical
- Polyurethane restores both appearance and function
Restore Smoothness, Speed, and Protection to Your Water Slide
A rough, faded, or oxidized water slide indicates the gelcoat has broken down and surface wear is affecting performance and appearance. With proper preparation using KBS Klean and a durable coating like KBS MAXX, you can restore smoothness, improve ride speed, protect the surface, and get long-lasting results.
Get the Products You Need
KBS Klean + KBS MAXX: everything you need for a professional water slide restoration.
Shop KBS MAXX Shop KBS Klean
