Rust Prevention & Chassis Coating Kits
Compare every KBS rust prevention kit side by side. Whether you need a sampler for a small repair or a full frame-off restoration kit, find the right system for your project size and budget.
Small Repair or Test
Fixing a spot repair, patching a rocker panel, or trying KBS for the first time? Start with a sampler kit — covers up to 25 sq ft.
Shop Sampler Kits
Frame, Suspension, or Trunk
Coating a full frame, suspension, axle, or trunk floor? Mid-size kits cover 50 sq ft — enough for most single-vehicle projects.
Shop Mid-Size Kits
Full Frame-Off Restoration
Doing a complete frame-off on a car, truck, or Jeep? Large kits cover 100–200 sq ft with professional-grade rust protection.
Shop Large Kits
Not sure which kit to choose? Every kit below is built around KBS RustSeal — our flagship rust preventive coating. Kits with "Surface Prep" include KBS Klean and RustBlast for a complete 3-step system. Kits with "Top Coat" add BlackTop chassis paint for a UV-stable, finished look.
Yes = Included No = Not included XX sq ft = Coverage area
Sampler & Small Kits (12.5–25 sq ft)
Kit Name Surface Prep Coverage Top Coat Inside-Out Rust Protection Gloves & Brushes Epoxy Putty
System Sampler Kit Yes 12.5 sq ft No No Yes No
Ultimate System Sampler Kit Yes 12.5 sq ft No Yes Yes No
All-In-One System Sampler Kit Yes 12.5 sq ft Yes No Yes No
Motorcycle Frame Coater Kit Yes 12.5 sq ft No No Yes No
Large System Sampler Kit Yes 25 sq ft No No Yes No
Mid-Size Kits (50 sq ft)
Frame Coater Kit Yes 50 sq ft No No Yes No
Ultimate Frame Coater Kit Yes 50 sq ft No Yes Yes No
All-In-One Kit Yes 50 sq ft Yes No Yes No
All-In-One Chassis Coater Kit Yes 50 sq ft Yes No Yes No
4PAK No 50 sq ft No No No No
Trunk & Floorpan Repair Kit Yes 50 sq ft No No Yes Yes
Large Kits (100–200 sq ft)
Large Frame Coater Kit Yes 100 sq ft No No Yes No
Large All-In-One Kit Yes 100 sq ft Yes No Yes No
Large All-In-One Chassis Coater Kit Yes 100 sq ft Yes No Yes No
4 Quart Special No 200 sq ft No No No No
Coverage12.5 sq ft
Surface PrepYes
Top CoatNo
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage12.5 sq ft
Surface PrepYes
Top CoatNo
Inside-OutYes
Gloves & BrushesYes
Epoxy PuttyNo
Coverage12.5 sq ft
Surface PrepYes
Top CoatYes
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage12.5 sq ft
Surface PrepYes
Top CoatNo
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage25 sq ft
Surface PrepYes
Top CoatNo
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage50 sq ft
Surface PrepYes
Top CoatNo
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage50 sq ft
Surface PrepYes
Top CoatNo
Inside-OutYes
Gloves & BrushesYes
Epoxy PuttyNo
Coverage50 sq ft
Surface PrepYes
Top CoatYes
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage50 sq ft
Surface PrepYes
Top CoatYes
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage50 sq ft
Surface PrepNo
Top CoatNo
Inside-OutNo
Gloves & BrushesNo
Epoxy PuttyNo
Coverage50 sq ft
Surface PrepYes
Top CoatNo
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyYes
Coverage100 sq ft
Surface PrepYes
Top CoatNo
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage100 sq ft
Surface PrepYes
Top CoatYes
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage100 sq ft
Surface PrepYes
Top CoatYes
Inside-OutNo
Gloves & BrushesYes
Epoxy PuttyNo
Coverage200 sq ft
Surface PrepNo
Top CoatNo
Inside-OutNo
Gloves & BrushesNo
Epoxy PuttyNo
What's Included in a KBS Rust Prevention Kit?
Every KBS chassis coating kit is built around RustSeal, a one-part, moisture-cure rust preventive coating that forms a tough, non-porous barrier against rust, chemicals, and UV exposure. Most kits include full surface prep — KBS Klean degreaser and RustBlast rust remover — so you can clean, etch, and coat in a single system.
"All-In-One" and "Chassis Coater" kits add BlackTop chassis paint as a UV-stable top coat, giving your frame or undercarriage a finished, factory-quality appearance. For projects involving enclosed frame rails or box sections, look for kits with "Inside-Out Rust Protection" — these include Cavity Coater that penetrates and protects areas you can't reach with a brush.
How to Choose the Right Kit Size
12.5 sq ft (Sampler Kits): Ideal for motorcycle frames, spot repairs, test areas, rocker panels, and small brackets. A great way to try the KBS system before committing to a larger project.
50 sq ft (Mid-Size Kits): Covers a standard car or truck frame, suspension components, axle housings, trunk floors, or floor pans with two coats of RustSeal.
100–200 sq ft (Large Kits): Designed for full frame-off restorations, complete underbody coating, or larger vehicles like full-size trucks, Jeeps, and SUVs.
Need help choosing? Call us at (219) 263-0073 or send us a message. Our team will recommend the right kit for your vehicle and project scope.
