Clear Coat for Bare Metal: 1K, 2K, Aerosol and High Heat Formulas
A clear coat for metal is a transparent topcoat that seals bare or painted metal against moisture. KBS DiamondFinish Clear is a 1K urethane that goes direct to metal with no primer and covers 400 sq. ft. per gallon at 2 mils. KBS MAXX Clear adds 2K satin and flat finishes, and XTC Clear handles heat to 1200°F.
Which Clear Coat Do I Need?
Pick by the finish you want and how hot the part runs.
| Your job | Choose | What you get |
| High gloss finish on bare metal, wood, fiberglass or cured paint | DiamondFinish Clear | 1K, no hardener, brush or spray, 7H pencil hardness at 7 days |
| Small parts, lures, or setting paint from a spray can | DiamondFinish Clear 1K Aerosol | Gloss or Satin, up to 35 sq. ft. per can, no yellowing to 250°F |
| Satin or flat finish, or the toughest chemical resistance | KBS MAXX Clear | 2K, 3 to 1 mix, High Gloss, Satin or Flat, 450 sq. ft. per gallon |
| Headers, grills, smokers and stoves running above 500°F | XTC Clear | Silicone clear to 1200°F, heat cured at 350°F |
| Prep and clear coat from one box | Clear Coat 1K Quart Kit | DiamondFinish Clear, KBS Klean and KBS #1 Thinner for up to 100 sq. ft. |
Still deciding? DiamondFinish Clear directions | DiamondFinish Clear FAQs | Ask an expert
Watch: the best clear coat for metal, and why clear coats fail
$25.00
(384)
$25.00
(47)
$68.00
(25)
$24.00
(4)
$85.00
(4)
$27.00
(10)
$250.00
(1)
