KBS MAXX Clear: 2K UV Resistant Urethane Clear Coat for Metal, Wood, Aluminum, and Fiberglass
25 Reviews +Write a Review
KBS MAXX Clear is a two-component (2K), permanently UV resistant urethane clear coat that bonds direct to ferrous metal, galvanized steel, aluminum, fiberglass, and exterior wood with no primers or additives required. KBS MAXX Clear is the most chemically resistant clear coat KBS makes, rated Excellent against 10% hydrochloric acid, 10% acetic acid, 10% sodium hydroxide, lubricating and cutting oils, and water immersion, and it reaches 2H pencil hardness at 72 hours with 160 inch-pounds of impact resistance and 1,000 hours of QUV 313B UV testing. Available in High Gloss (90 to 95%), Satin (45 to 55%), and Flat (5 to 15%); apply by brush, roller, or spray.
Quart: $68 | Gallon: $226 | 5 Gallons: $1081
Price: $68.00
KBS MAXX Clear Loading...
