KBS UnderCoat Solvent Asphalt: Sound Deadening Asphalt Based Undercoating That Dries to Touch in 60 Minutes
15 Reviews +Write a Review
KBS UnderCoat Solvent Asphalt is a solvent based asphalt undercoating that seals wheel wells, frames, gas tanks, and floor pans against road salt and moisture while reducing road noise and vibration. It dries to the touch in 60 minutes, reaches full cure in 2 to 4 hours, and covers 100 to 120 square feet per gallon. KBS UnderCoat Solvent Asphalt bonds to bare metal, painted surfaces, fiberglass, and cured RustSeal without a separate primer. Choose the rubberized formula if the underside will be painted: asphalt typically bleeds through a topcoat.
Aerosol: $13 | Aerosol Case (12): $130
Quart: $23 | Gallon: $67 | 5 Gal Pail: $280
Price: $13.00
KBS UnderCoat - Solvent-Based Asphalt
KBS UnderCoat - Solvent-Based Asphalt Loading...
