High Temperature Paint for Headers, Manifolds, and Grills
KBS Coatings offers time tested and proven coatings for your engine exhausts, smokers, grills, radiators, bbq, headers, wood stoves, pellet stoves, and so much more.
XTC is a high temperature/heat resistant coating formulated specifically to protect metal surfaces operating at temperatures from 500° to 1500° F. With proper preparation, XTC provides outstanding adhesion, film integrity, weathering, and thermal shock-resistance throughout this entire temperature range, and is guaranteed not to burn off! XTC is available in many great colors.
XTC Silicone Zinc Rich Primer prevents corrosion of metal surfaces exposed to high heat, high humidity, condensation and salt air. XTC Silicone Zinc Rich Primer functions much like galvanizing as it locks itself to bare metal surfaces leaving a perfect primed surface for top coating. XTC Silicone Zinc Rich Primer can be used alone as a finish paint. XTC Silicone Zinc Rich Primer withstands temps in excess of 1200F.
XTC Clear is a high temperature and heat resistant coating formulated specifically to protect metal surfaces operating at temperatures above 500F. XTC Clear provides outstanding adhesion, film integrity, weathering, and thermal shock-resistance and will not burn off!
The Rotor Restoration Kit restored those rusted rotors or calipers that you can see through custom wheels. The Restoration Kit is all-inclusive giving you everything needed to clean, prep, prime, and coat those rusted rotor or caliper eyesores and bring them back to a showroom appearance. Detailed directions give you professional looking results.
| Product | Max Temp | Best For |
| XTC Xtreme Temperature Coating | 1500°F | Headers, exhaust manifolds, BBQ grills, wood/pellet stoves |
| XTC Silicone Zinc Rich Primer | 1200°F | Bare steel corrosion protection, use alone or top-coated |
| XTC Clear | 500°F+ | Adds gloss over bare metal or over a colored XTC finish without changing the color |
| Rotor Restoration Kit | N/A | Rusted rotors/calipers visible through custom wheels |
Not sure which high temp coating you need? Our team can help you match the product to your project.
Contact Our Tech Team
