Cavity Wax Provides Rust Protection in Hard-to-Reach Areas
Posted by KBS Coatings on 3/18/2022 to
Cavity wax is a soft, self-healing rust preventive that creeps into seams and welds. Here's where to use it and how to spray it inside frames, rockers and doors.
Categories
Recent Posts
Archives
- November 2026
- October 2026
- September 2026
- August 2026
- July 2026
- June 2026
- May 2026
- April 2026
- March 2026
- February 2026
- January 2026
- December 2025
- November 2025
- October 2025
- September 2025
- July 2025
- June 2025
- March 2025
- February 2025
- January 2025
- November 2024
- February 2024
- January 2024
- October 2023
- September 2023
- August 2023
- July 2023
- June 2023
- February 2023
- January 2023
- December 2022
- November 2022
- October 2022
- August 2022
- July 2022
- March 2022
- January 2022
- September 2021
- August 2021
- June 2021
- May 2021
- March 2021
- January 2021
- June 2020
- May 2020
- April 2020
- March 2020
- February 2020
- December 2019
- April 2019
- March 2019
- February 2019
- October 2018
- March 2017
- October 2015
- April 2013
- March 2012
- February 2012
- July 2011
- December 2010
- December 2009
- October 2009
