What is KBS Chrome Spray Paint?
KBS Chrome Spray Paint is a one-component (1K) aerosol topcoat that gives metal a chrome look and refreshes worn chrome surfaces. The high solids formula does not run or sag, one can coats up to 30 sq. ft. in one coat, and the cured paint withstands temperatures up to 300°F.
30 Sq. Ft.
Per can, one coat
1 to 2 Hours
Average recoat time
KBS Chrome Spray Paint is an exterior paint for creating a chrome look on bumpers, wheels, trim, tools and household fixtures. It goes on bare metal, and for the best performance it goes over RustSeal. The professional fan pattern spray head lays down an even coat, and the high solids formula hides well and gives at least twice the coverage of conventional spray paints.
For gloss depth and durability, clear coat the finish with DiamondFinish Clear.
Watch How to Apply KBS Top Coater Aerosol
KBS Chrome Spray Paint goes on clean, dry bare metal, and for the best result it goes over RustSeal that was applied to rusty or rust-prone metal. It also refreshes worn chrome surfaces. Prime chrome with KBS Fusion SEP first, then topcoat after 1 hour.
- Bare metal: Clean the part with KBS Klean, let it dry, then spray. Avoid solvent-based cleaners, which leave invisible residues that can affect adhesion.
- Over RustSeal: Spray the chrome paint on RustSeal that is between 3 and 8 hours old with no other prep. Outside that window, lightly scuff with 320 grit, then clean and dry the surface.
- Existing chrome: KBS Fusion SEP self-etching primer bonds to chrome. Topcoat it with KBS Top Coater Aerosol after 1 hour.
KBS Chrome Spray Paint is a very high solids aerosol paint that does not run or sag and gives at least twice the coverage of conventional spray paints. The cured coating is hard yet flexible, withstands temperatures up to 300°F, and can be clear coated with DiamondFinish Clear.
- Easy Chrome Look: Spray it on to refresh a chrome surface or create a chrome look on metal.
- Hard Yet Flexible: The cured coating is rock hard but still flexible.
- Excellent Adhesion: It bonds to bare metal and to RustSeal.
- Professional Fan Pattern Spray Head: The spray head gives an even, controlled coat.
- High Solids Formula: Excellent hiding qualities, with no runs or sags.
- Fast Drying: Average recoat time is 1 to 2 hours, depending on humidity.
- Does Not Fade: The coating holds its color.
- Excellent Durability: A hard, flexible film for exterior parts.
- Heat Resistant to 300°F: Handles engine compartments and surfaces next to the exhaust. It is not an exhaust coating.
KBS Chrome Spray Paint is used on automotive bumpers, trim and wheels, on industrial tools, molds and equipment parts, and on household faucets, handles and lighting fixtures. Each part needs clean, dry metal and thin coats for the best chrome look.
- Automotive
- Bumpers, trim, wheels and other parts.
- Industrial
- Hydraulic cylinders, molds, tools and equipment parts.
- Aerospace
- Landing gear, engine parts and structural components.
- Household
- Faucets, handles and lighting fixtures.
One can of KBS Chrome Spray Paint covers up to 30 sq. ft. in one coat on a prepared surface. Expect up to 50% less coverage on rough or sandblasted surfaces,. Spray thin coats and plan a can for each part.
KBS Chrome Spray Paint Coverage
| Surface | Coverage per Can, One Coat |
| Smooth, prepared surface | Up to 30 sq. ft. |
| Rough or sandblasted surface | Up to 50% less |
Recoat timing: Recoat once the first coat is dry to the touch, usually 1 to 2 hours depending on humidity. Apply consecutive coats within 24 hours.
Pro Tip: Apply thin coats rather than heavy ones. If the paint runs or sags, the coat is too heavy or the can is too close. Hold the can 8 to 10 inches from the surface.
Chrome spray paint alone is enough for clean, rust-free parts. Over RustSeal, KBS Chrome Spray Paint finishes metal that already has rust or will face weather, because RustSeal seals the rust and the chrome paint becomes the finish coat.
Chrome Spray Paint Alone Compared With Chrome Spray Paint Over RustSeal
| | Chrome Paint Alone | Chrome Paint Over RustSeal |
| Best for | Clean bare metal | Rusty or rust-prone metal |
| Prep | Clean with KBS Klean, dry | Seal with RustSeal, then spray in 3 to 8 hours |
| Rust control | Chrome paint is the finish | RustSeal stops rust and prevents its return |
| Heat resistance | Up to 300°F | Up to 300°F |
| Steps | One product | Two products |
Chrome paint alone is the better choice when the metal is clean, has no rust and needs only a quick refresh, since it skips the RustSeal step.
Clear coat the finished chrome look to add gloss depth and durability.
- Step 1: Prep the metal
- Clean with KBS Klean. On rusty metal, seal it with RustSeal first.
- Step 2: Spray the chrome paint
- Apply one or two thin coats for automotive parts, and two to three thin coats for marine or industrial parts.
- Step 3: Clear coat
- Finish with DiamondFinish Clear for depth of gloss and durability.
Shop DiamondFinish Clear
Have questions before you buy? Find answers to the most common chrome spray paint questions below, or
order KBS Chrome Spray Paint now.
KBS Chrome Spray Paint gives metal a chrome look and refreshes worn chrome surfaces. It is a spray paint rather than chrome plating, so apply thin coats to clean, dry metal for the best result, then clear coat with DiamondFinish Clear for depth of gloss.
Yes, when the surface is prepped and the paint goes on in thin coats. KBS Chrome Spray Paint is a high solids aerosol with excellent adhesion that does not run or sag, and it bonds to bare metal and to RustSeal. Clean the metal with KBS Klean first and let it dry.
The best chrome spray paint suits the part and the conditions: it covers well, resists the heat the part sees and takes a clear coat. KBS Chrome Spray Paint covers up to 30 sq. ft. per can, withstands up to 300F, is high solids so it does not run or sag, and can be clear coated with DiamondFinish Clear.
For metal, KBS Chrome Spray Paint goes on bare metal and performs best over RustSeal, which seals rusty metal before the chrome paint goes on. Clean the surface with KBS Klean, spray thin coats, and add a DiamondFinish Clear top coat for depth of gloss and durability.
Apply one or two thin covering coats for general automotive parts. For marine or industrial parts, apply a minimum of two to three thin covering coats. Thin coats work better than heavy ones, which can run or sag.
Recoat once the first coat is dry to the touch. Average recoat time is 1 to 2 hours depending on humidity, and consecutive coats should go on within 24 hours. The KBS Top Coater Aerosol directions say full cure is usually reached within 24 hours.
Yes. KBS Chrome Spray Paint is designed to be clear coated with DiamondFinish Clear, which adds depth of gloss and durability. DiamondFinish Clear is the finish clear coat. DiamondFinish Clear 1K Aerosol sets the paint. If you use only the aerosol, 5 to 9 coats (each coat is 4 passes) is needed only when durability is key, and the cure is at least 7 days with airflow.
Yes, it withstands temperatures up to 300F, which handles engine compartments and surfaces next to the exhaust that are not connected to it. It is not an exhaust coating. For surfaces that run from 500F to 1500F, use XTC High Temperature Coating.
Yes. Clean the chrome with KBS Klean and let it dry, prime it with KBS Fusion SEP self-etching primer, which bonds to chrome, then apply KBS Chrome Spray Paint after 1 hour.
Clean up overspray right away with KBS #1 Thinner or lacquer thinner, and wear protective gloves to avoid skin contact and temporary staining. To clear the spray head after use, turn the can upside down and spray for 3 seconds.
