How to Prevent Mower Deck Rust
To prevent mower deck rust, clear off grass buildup and loose rust, prep the steel, and seal it with a durable mower deck coating. This guide shows the KBS 3-Step System on a rusted deck: KBS Klean to degrease, KBS RustBlast to etch, and KBS RustSeal to seal out moisture.
Mower Deck Rust Prevention at a Glance
ProductsKBS Klean, RustBlast, RustSeal
KBS Klean dilution1 to 1 heavy soil, 5 to 1 moderate, 10 to 1 light; 25 to 1 on aluminum
RustBlast dwellAt least 30 minutes kept wet; 1 to 2 hours on heavy rust; 10 to 20 minutes on aluminum
Application temperature55 to 82°F
CoatsAt least 2 thin coats, about 2 mils each
RecoatDry to the touch, typically 2 to 6 hours; recoat within 8 hours
Full cure24 hours after the final coat
Why Do Mower Decks Rust?
Mower decks rust because moisture sits against the steel for long periods. Rain, dew and wet mowing soak the underside, and grass clippings, dirt and debris pack in and hold that water against the metal while slowing drying. Sand and soil also wear away the factory paint and expose bare steel. Aluminum decks do not rust, but they can still corrode.
Gloved hand pulling packed wet grass clippings from under a mower deck
Packed clippings hold moisture against the steel, which is where mower deck rust starts.
What Problems Can Mower Deck Rust Cause?
Mower deck rust thins the steel, eats holes through the deck, raises repair costs and roughens the underside so grass discharges poorly. The damage grows as rust spreads, so a deck treated early costs far less than one left until it rusts through.
Structural Weakening
As rust consumes the steel, the metal gets thinner and weaker. Areas that collect moisture and debris usually go first, and the lost material leaves the deck easier to bend or crack.
Rust-Through and Holes
Advanced rust eventually penetrates the steel and leaves holes in the deck. Once rust-through starts, the deck deteriorates faster and may need welding, patching or replacement.
Increased Maintenance and Repair Costs
Surface rust is easy to treat; deep corrosion can mean welding, patch panels or a new deck. Stopping rust early costs less than repairing it later.
Reduced Mowing Performance
Rust leaves a rough, uneven surface under the deck. As it builds, it can disrupt airflow beneath the deck and hurt grass discharge and cut quality.
What Is the Best Way to Prevent Mower Deck Rust?
Key steps:
  • Remove loose rust and failed coatings
  • Clean the deck thoroughly
  • Etch and prepare the metal
  • Apply a rust preventive coating
  • Clean and inspect the deck after use
The steps below use the KBS 3-Step Rust Prevention System: clean the metal, etch it, then seal out moisture.
What You Need to Refinish a Rusted Mower Deck
  • KBS Klean: water-based cleaner and degreaser for oil, grease and grass residue
  • KBS RustBlast: rust remover and metal etch that leaves a zinc phosphate coating
  • KBS RustSeal: moisture-cured coating that seals the steel against rust
  • KBS #1 Thinner (optional): only if you spray RustSeal and it needs thinning
  • KBS Paint Mixing Cup: to pour off and brush RustSeal from, so the can stays sealed (store leftover RustSeal in a steel can or glass jar, not the cup)
  • Wire wheel, 320 grit sandpaper or a sandblaster, for loose rust
  • Scrub brush and Scotch-Brite pads, for cleaning and etching
  • Paint brush, roller or spray gun; the KBS HVLP Mini Spray Gun suits a deck this size
  • Chemical-resistant gloves, safety glasses and proper personal protective equipment
KBS Klean, RustSeal and RustBlast containers, the KBS 3-Step System
The KBS 3-Step System: KBS Klean, RustBlast and RustSeal.
1. Remove Existing Rust and Failed Coatings
Remove loose rust, flaking paint and failed coatings before you coat the deck. Rust keeps spreading under a coating applied over it, and loose paint gives the new coating nothing solid to grip, which leads to early peeling and flaking.
For removal, use one of the following:
  • Wire wheel
  • 320 grit sandpaper
  • Sandblasting
If old paint will not come off completely: lightly scuff it with 400 grit sandpaper, then clean with KBS Klean. RustSeal over existing paint gives a durable, moisture-resistant coating, but it may not permanently seal rust the way it does on bare metal.
Light surface rust can stay once it is treated with KBS RustBlast and coated with KBS RustSeal, which saves labor. Newly sandblasted steel (fresh sand, handled only with gloved hands) can take RustSeal directly, with no prep beyond blowing off loose dust.
Removing loose rust from the underside of a mower deck with a wire wheel on an angle grinder
Knock off loose rust and flaking paint with a wire wheel; tight surface rust can stay.
2. Thoroughly Clean the Mower Deck
Clean the deck with KBS Klean after the loose rust is off. Grass residue, dirt, grease and oil keep a coating from bonding, and cleaning also exposes hidden rust that needs treatment. KBS Klean rinses clean, so it leaves no residue to interfere with the next step.
Use KBS Klean as directed:
  • Mix KBS Klean with hot water: 1 to 1 for heavy soil, 5 parts water to 1 for moderate, 10 to 1 for light. Use 25 to 1 on an aluminum deck.
  • Scrub with a bristle brush and Scotch-Brite pad.
  • Rinse with water and let the deck dry completely.
  • Follow the KBS Klean directions.
Scrubbing the underside of a mower deck with KBS Klean and a bristle brush
Scrub with KBS Klean and hot water, then rinse and dry completely.
3. Properly Prepare the Metal Surface
Etch the clean deck with KBS RustBlast so the coating has something to bond to. RustBlast dissolves light rust and oxidation, etches the steel and leaves a thin zinc phosphate coating that helps KBS RustSeal adhere.
Use RustBlast as directed:
  • Spray it on and keep the surface wet: at least 30 minutes on smooth or lightly rusted steel, 40 to 60 minutes on moderate rust, 1 to 2 hours on heavy rust. Reapply so it never dries.
  • On an aluminum deck, 10 to 20 minutes is enough.
  • Scrub now and then with a Scotch-Brite pad.
  • Rinse with water before it dries. The rinse neutralizes the acid and prevents excess zinc phosphate buildup. Then let the deck dry completely.
  • A slight white powder may remain. That thin zinc phosphate coating helps RustSeal adhere and helps prevent flash rust, so leave it.
  • Follow the RustBlast directions.
Working RustBlast into the mower deck steel with a Scotch-Brite pad
Keep RustBlast wet for at least 30 minutes, scrubbing now and then with a Scotch-Brite pad.
4. Apply a Durable Rust Protective Coating
What Is the Best Thing to Coat a Lawn Mower Deck With?
The best coating for a lawn mower deck is a rust preventive coating that seals out moisture, oxygen and grass residue, bonds tightly to the steel and stands up to abrasion under the deck. KBS RustSeal is a single-component, moisture-cured coating that cures to a non-porous barrier that stops rust.
KBS RustSeal is hard but flexible, so it resists impacts and abrasion without cracking, chipping or peeling. It self-levels well enough that brush marks flow out, and it goes directly onto rusted, treated or bare steel. RustSeal comes in 11 colors.
RustSeal also cuts prep time. Light surface rust can stay and be coated over, and deep pitting or rust in weld seams that you cannot fully remove gets sealed and stops spreading.
How to Apply RustSeal to a Mower Deck
Apply KBS RustSeal in at least two thin coats, about 2 mils each, once the deck is clean, etched and dry. Work between 55 and 82°F and recoat as soon as the previous coat is dry to the touch.
Use RustSeal as directed:
  • Application method: brush, roll or spray.
  • Temperature: apply between 55 and 82°F. Avoid rain and high humidity, and stay under 80% relative humidity.
  • Mixing: stir from the bottom of the can to the top before use. Pour what you need into a separate container and keep the can closed.
  • Thinning: usually not needed. If spraying requires it, 5 to 10% KBS #1 Thinner is normally enough. Never use lacquer thinner.
  • Coats: at least two thin covering coats, about 2 mils each. Several thin coats beat one thick one.
  • Recoating: recoat when the last coat is dry to the touch and leaves no fingerprint, typically 2 to 6 hours. If more than 8 hours pass, wait 24 hours and lightly scuff with 320 grit or a green Scotch-Brite pad first.
  • Over rust: RustSeal can go over light surface rust that has been treated with KBS RustBlast.
  • Cure: RustSeal is fully cured 24 hours after the final coat. Reassemble the deck and mow after that.
  • Top of the deck: RustSeal chalks and fades in sunlight, so topcoat any area that sits in the sun with BlackTop, KBS Top Coater or KBS MAXX when the last RustSeal coat is 3 to 8 hours old, or let the RustSeal cure 24 hours and scuff with 320 grit first.
  • Follow the RustSeal directions.
Brushing a thin coat of gray RustSeal onto the underside of a mower deck
Brush on thin coats of RustSeal, recoating at dry to the touch, typically 2 to 6 hours.
RustSeal rust preventive coating can
Seals the deck steel against moisture and rust.
Shop RustSeal
RustBlast rust remover and metal etch bottle
Dissolves light rust and etches the steel so RustSeal grips.
Shop RustBlast
KBS Klean cleaner and degreaser bottle
Strips grass residue, grease and dirt before you coat.
Shop KBS Klean
Routine Inspection and Maintenance
Clean the mower deck after each use and inspect it regularly, even with a durable coating on it. Scrape out clippings and rinse the underside so moisture does not sit against the coating, check for chips, worn spots and new rust, and touch up damaged areas right away to keep the barrier intact all season.
Additional Benefits of Coating a Mower Deck
Besides stopping rust, a coated deck is easier to clean, collects less grass, takes abrasion in place of the steel and helps the mower hold its value.
Easier Cleaning and Maintenance
A smooth, durable coating is easier to wash and inspect, so routine cleaning goes faster and the deck stays in good condition through the season.
Reduces Grass Buildup
A smooth coating makes it harder for clippings and debris to stick under the deck. Less buildup helps grass discharge and airflow and leaves fewer places for moisture to sit against the metal.
Protection Against Abrasion and Wear
A durable coating takes the wear from grass, dirt, sand and debris instead of the steel, which slows surface deterioration and extends deck life.
Preservation of Equipment Value
A deck that does not rust stays solid and looks cared for, which keeps the mower working longer and helps at resale.
Common Mistakes That Lead to Mower Deck Coating Failure
Mower deck coatings usually fail early for one of four reasons: coating over loose rust, poor surface preparation, choosing the wrong coating, or skipping maintenance.
Coating Over Loose Rust
Loose rust gives a coating nothing stable to bond to. The rust keeps working underneath until the coating lets go.
Inadequate Surface Preparation
Skipping the cleaning, leaving contaminants behind or not etching the steel leads to peeling, flaking and early coating failure.
Using the Wrong Type of Coating
Not every coating can handle constant moisture, abrasion and debris impact. The wrong product wears through quickly and lets rust back in.
Neglecting Ongoing Maintenance
Without regular cleaning, inspection and touch-up, small chips grow into rust spots and shorten the coating's life.
Frequently Asked Questions About Mower Deck Rust and Coatings
How often should I clean my lawn mower deck?
Clean the underside of the mower deck after every mow. Scrape or blow out the clippings before they dry, rinse the deck, and let it dry completely before you store the mower. Wet clippings left under the deck hold moisture against the steel, and that trapped moisture is what starts mower deck rust.
How to fix a rusty mower deck?
Fix a rusty mower deck in four steps: remove loose rust and flaking paint with a wire wheel or 320 grit sandpaper, clean the deck with KBS Klean, keep KBS RustBlast wet on the steel for at least 30 minutes, then rinse, dry and apply at least two thin coats of KBS RustSeal. Rust that has eaten holes through the steel needs welding or patching first.
What is the best paint to use on the underside of a lawn mower deck?
The best paint for the underside of a lawn mower deck is a moisture-cured rust preventive coating such as KBS RustSeal. It bonds to bare or lightly rusted steel prepped with RustBlast, cures to a hard, non-porous film that resists abrasion and chipping, and is fully cured 24 hours after the final coat.
How do I prevent a mower deck from rusting?
Prevent mower deck rust by removing grass buildup after each use, repairing damaged coating areas promptly, and sealing the steel with a durable protective coating such as KBS RustSeal that blocks moisture and oxygen from reaching bare metal.
Can a rusted mower deck be repaired?
Yes, most rusted mower decks can be repaired if corrosion has not severely weakened the metal. Surface rust and light pitting can be treated with KBS RustBlast and sealed with KBS RustSeal. Early repair is easier and less costly than replacing the deck.
Does mowing wet grass cause mower deck rust?
Yes, wet grass contributes to mower deck rust by packing under the deck and trapping moisture against the metal. Clean the deck after mowing wet grass and let it dry before storage to reduce corrosion risk.
Should all rust be removed from a mower deck before applying a coating?
No. Remove loose and flaking rust, but tight surface rust can stay. KBS RustSeal bonds to and seals light rust that has been treated with KBS RustBlast, so you do not need to grind the whole deck to bare metal.
Can mower deck rust be stopped permanently?
Yes, when the steel is sealed. Rust stops when moisture and oxygen can no longer reach the steel. Remove loose rust, clean and etch the metal, and seal it with KBS RustSeal, which cures to a non-porous barrier that stops rust. Keep the deck clean and touch up chips as they appear.
Does the top of a mower deck need a topcoat over RustSeal?
Yes, if the top of the deck sits in the sun. KBS RustSeal keeps protecting against rust in sunlight, but its color and sheen chalk and fade. Topcoat sun-exposed areas with BlackTop, KBS Top Coater or KBS MAXX once the last RustSeal coat is 3 to 8 hours old, or let the RustSeal cure 24 hours and scuff with 320 grit first. The shaded underside needs no topcoat.
Key Takeaways for Long-Term Mower Deck Rust Protection
To keep a mower deck from rusting, knock off loose rust, clean it with KBS Klean, etch it with KBS RustBlast, seal it with at least two thin coats of KBS RustSeal, and clean the underside after every mow. For more answers, see the RustSeal FAQs.
Finished mower deck underside sealed in gray RustSeal
The finished deck: cleaned, etched and sealed with two thin coats of RustSeal.
Related guides: How to Repair Trailer Frame Rust, How to Stop Rust on a Car's Undercarriage, Rubberized Undercoating: Why It Traps Rust, or browse all KBS application guides.
