The Trailer and Shed Floor Paint Calculator works out how much KBS MAXX, KBS #1 Thinner, and KBS Klean a wood floor needs. Bare wood gets a thinned seal coat plus two full coats, and a coated floor gets three full coats. A 6 x 12 trailer floor takes about one gallon of KBS MAXX.
Build Your Floor Coating Package
Enter your floor size and we will put together everything the job takes: KBS MAXX, KBS #1 Thinner, and KBS Klean. One click adds it all to your cart.
Shop KBS MAXX, KBS #1 Thinner, and KBS Klean.
Trailer Floor Guide
Shed Floor Guide
KBS MAXX Directions
KBS MAXX FAQs
RustSeal Calculator for Metal
Order KBS MAXX
How the Calculator Works
- Coats: A wood floor needs at least three coats of KBS MAXX. Bare or new wood gets one seal coat thinned 30 to 50% with KBS #1 Thinner, then two full coats. A floor with a sound existing coating gets three full coats.
- Coverage: KBS MAXX covers about 450 sq ft per gallon per coat, or about 110 sq ft per quart. Bare wood soaks up the seal coat, so the calculator counts that coat at half coverage.
- Full cans: The calculator rounds up to full cans, so most jobs have some KBS MAXX left for touch-ups.
- KBS #1 Thinner: Enough to thin the seal coat 50% and the rolling coats about 5%, plus 16 oz for cleanup.
- KBS Klean: A quart washes up to about 200 sq ft at 1 part KBS Klean to 25 parts water. A very dirty or oily floor may need more.
How Much KBS MAXX for Common Floor Sizes
These amounts are for bare or new wood: one seal coat plus two full coats.
| Floor | Floor area | KBS MAXX to order |
| 5 x 8 ft trailer | 40 sq ft | 2 quarts |
| 6 x 12 ft trailer | 72 sq ft | 1 gallon |
| 7 x 14 ft trailer | 98 sq ft | 1 gallon |
| 8.5 x 20 ft trailer | 170 sq ft | 2 gallons |
| 8 x 10 ft shed | 80 sq ft | 1 gallon |
| 10 x 12 ft shed | 120 sq ft | 1 gallon plus 1 quart |
| 12 x 16 ft shed | 192 sq ft | 2 gallons |
How to Measure Your Floor
Measure the floor inside the walls or rails, then multiply length by width. A 6 x 12 trailer floor is 72 sq ft. Split an L-shaped or notched floor into rectangles and add them together. Enter the length and width in the calculator, or tap one of the common sizes.
KBS MAXX Beyond Wood Floors
KBS MAXX also coats metal and concrete. It goes over clean, prepared steel and aluminum, hot-dipped galvanized steel, concrete, the KBS 3-Step System, and most epoxy and urethane primers. This calculator covers wood floors. For a metal frame, trailer, fence, or equipment coated with RustSeal and topped with KBS MAXX, use the RustSeal Calculator.
Step-by-Step Floor Coating Guides
The calculator tells you what to order. These guides show how to prep the wood, apply the seal coat, and roll on the full coats.
Frequently Asked Questions About Coating a Wood Floor
About one gallon. A 6 x 12 floor is 72 sq ft. Bare wood takes a thinned seal coat plus two full coats, about two thirds of a gallon in all, and the calculator rounds that up to one gallon kit of KBS MAXX.
At least three. Bare or new wood gets one seal coat thinned 30 to 50% with KBS #1 Thinner, then two full coats. A floor with a sound existing coating gets three full coats.
About 450 sq ft per coat. A quart kit covers about 110 sq ft and a 5 gallon kit about 2,250 sq ft. Expect up to 50% less on the first coat over bare wood, because the seal coat soaks in.
Yes. Thin the seal coat 30 to 50% with KBS #1 Thinner so it soaks into the wood. The full coats roll on with about 5% thinner.
Not before the seal coat if the wood is smooth and clean. Wash it with KBS Klean, let it dry, apply the thinned seal coat, and sand before the full coats.
Yes, once the wood has dried out thoroughly. Prep and coat it exactly like raw wood. Washed wood usually needs 24 to 48 hours to dry; a plastic sheet taped to the floor tells you whether moisture is still coming out.
A quart of KBS Klean, mixed 1 part to 25 parts water, washes about 200 sq ft. Larger floors get a gallon. A very dirty or oily floor may need more.
Yes. KBS MAXX goes over clean, prepared steel and aluminum, hot-dipped galvanized steel, concrete, and RustSeal. This calculator covers wood floors only. For metal coated with RustSeal and topped with KBS MAXX, use the RustSeal Calculator.
More KBS MAXX questions and answers: KBS MAXX FAQs
Still have questions about KBS MAXX? Our technical team is ready to help.
