RustSeal Directions
RustSealInstructional Videos RustSeal Flow Chart Spraying Guidelines Order RustSeal Using RustSeal
to Seal Concrete RustSeal Chemical
Resistance Guide
Physical Data
Type of coating: Single Component Moisture Curing Polymeric Isocyanate.
Colors: Gloss Black, Satin Black, Silver, Grey, Oxide Red, Green, Off-White, Cat Yellow, Galvanized Steel, Safety Blue, Safety Yellow.
Gloss: Galvanized Steel (about 30%), Satin Black and Oxide Red (65 to 75%), Gloss Black (85 to 95%), Other Colors (80 to 90%)
Solids: 72-76% depending on color.
Flash Point: 103°F (40°C)
Viscosity: at 77°F (25°C), 250-450cps depending on color.
VOC: Not more than 200 g/l
Minimum Recommended Dry film thickness: 3-5 mils (75-125um). This is normally achieved in 2-3 coats.
Coverage: On porous surfaces like rust and corrosion approximately 100 sq. ft. per quart or 400 sq. ft. per gallon (9.5 m² per liter) at 2 mils (50um) thickness. Coverage will vary depending on surface profile, application method and film thickness.
General appearance and Characteristics: Smooth ceramic like finish with very high levels of flexibility and toughness. Strong resistance to impact, high temperature, abrasion and common aggressive chemicals including; Acids, Alkalis, Salts, Minerals, Solvents, Fuels and Hydraulic fluids.
Compatibility with other topcoats: RustSeal can be topcoated with any type of topcoat and primer systems including but not limited to Urethanes, Epoxies, Enamels, Fiberglass resins, Water based coatings, lacquers and two component automotive refinishing products.
Container Availability: 8oz (236mls), Pint (475mls), Quart (946mls), Gallon (3.78L), 5 Gallon (18.9L), Drum 55 Gallon (208L)
Clean Up & Storage
Pot life: Pot life will depend on local humidity conditions and the length of time the coating is exposed to moisture. Though providing the can is resealed well and only opened for limited periods at a time the average life is approximately 6 months.
Solvent: Use only KBS #1 Thinner or Xylene. The use of other solvents can cause premature coating failure and/or loss of adhesion.
Storage Requirements: Store in cool dry conditions away from direct sun light 41-95°F (5-35°C)
Dry Times
Full Cure: 24 Hrs depending on humidity.
Physical & Performance Characteristics
ASTM-D-412)
95°F (35°C) at 5% salt water for 2000 Hrs
(ASTM-C-501) (1 kg load/1000 cycle)
(MIL-D-3134F sec 4.7.3)
(MIL-D-3134J)
(ASTM C-307 psi
(ASTM C-580 psi)
(ASTM C-579 psi)
(ASTM-D-635)
(MIL-D-3134F sec 4.7.4)
No indentation
Temperature, Weather & Bacteria Resistance
*Across Entire Color Range
(Mil-F-52505)
(ASTM B-117)
250 hrs @ 98°F / 37°C
1000 hrs @ 98°F / 37°C
Zero (0) Change
temperatures
(ASTM C-413)
(NTS Climatic Test Cell)
120 day cycle
(-30°F-140°F / -34°C-60°C)
Chemical Resistance
Results of contact spot testing of RustSeal with various common materials.
RustSeal applied to steel Q panels at 4 mil (100um) film thickness and placed in continuous contact with the following materials for 168 Hr (7days).
