Find step-by-step application directions, technical data sheets, and flow charts for every KBS Coatings product in one place. Use the search box below to jump straight to the guide for your product, or browse by category. For best results, always clean and prep the surface before you coat.
No guides matched your search. Try a shorter term, or a product name like RustSeal, Tank Sealer, or KBS Klean.
Contact us and we'll point you to the right guide
Surface Preparation
Rust Prevention & Tank Sealers
KBS UnderCoat
Cavity Coater
Topcoats & Protective Finishes
High-Temperature Coatings
Primers & Adhesion
Repair & Restoration
NuMetal Epoxy Putty
Trunk & Floorpan Repair Kit
Headlight Restore Kit
Resources & Reference
