Tip of the Month – Patience When Using Tank Sealer
PATIENCE IS A VIRTUE THAT WILL BE REWARDED...
Over the years, one of the BEST TIPS that we can give to people who are sealing a tank is to BE PATIENT. Proper prep and sealing IS NOT a lunch hour project. The KBS 3 Step System works perfectly if the Instructions are followed which includes:
  • Be Patient and allow the KBS Klean the time to thoroughly dissolve all the oily fuel residues before rinsing.
  • Be Patient and allow the RustBlast to soak and disintegrate the rust in your tank before rinsing.
  • Be Patient while waiting for the tank interior to dry completely as the tank can NEVER be too dry!
  • Be Patient and allow the tank to cool to room temperature before applying the sealer.
  • Be Patient when sloshing the sealer around to insure complete coverage.
  • Be Patient when draining any & all excess sealer from the tank.
  • Be Patient while waiting for the sealer to cure.
Click HERE for Detailed Tank Sealer Instructions.
Read More
Ray W. Talks About RustSeal
others - Stop Rust
others - Stop Rust
others - Stop Rust
"Yes I did have the chance to use your RustSeal! And I have to admit it is a bit better than the other two leading sellers. It was a hot day and humid too, since I'm in texas, and it went on nice but didn't tack up for over an hour. But within two hours it was a really nice finish and really secured the little rust area's very nicely!
I will be ordering another gallon within the next month or so when I go to finish the floors on my camaro. I have attached a photo or two for you.
Great product! Best yet!"
Read More
JavaTree on Jeepforum.com talks about Frame Paint
others - Stop Rust - Paint For Rust
others - Stop Rust - Paint Over Rust
"I wire wheeled the entire tub, used the three stage Chassis kit Chassis Paint Kit - KBS All-In-One Chassis Kit - KBS Coatings - prewash, metal prep, then applied paint with a brush/roller ... I painted the chassis, tub (inside & out), fenders, hood, bumpers and windshield frame. The main thing with this type of paint is to do ALL of the prep work, however painstaking it may be, and READ the instructions twice before starting. (That advice is for any of the rust preventive sealer paints.)"
Find out more about the All-In-One Chassis Coater Kit here: https://www.kbs-coatings.com/chassis-paint-kit.html
Read More
