Posted by KBS Coatings on 1/28/2026 to
Prevent cracking, peeling, and rust on your suspension springs! Learn how to prep and paint coil & leaf springs using the KBS 3-Step System for a long-lasting, flexible finish. Read more→
Posted by KBS Coatings on 1/26/2026 to
KBS RustSeal outperforms Glyptal as an engine internal coating. Seals porous castings, resists oil and fuel, and cures permanently. See how engine builders use it during rebuilds.
How to Paint Rusty Exhaust Headers So the Finish Won’t Crack, Flake, or Peel
Posted by KBS Coatings on 1/14/2026 to
This in-depth guide explains why header paint peels and shows how proper prep, high-temperature coatings, and correct heat curing deliver a durable, long-lasting finish that won’t crack, flake, or burn off under extreme heat. →
