DiamondFinish Clear is the best clear coat for outdoor metal art: a 1K moisture-cured urethane that applies direct to bare, painted, or rusted metal with no primer, resists UV yellowing and cracking outdoors, and cures to a permanently flexible, non-porous film. For smaller sculptures or lighter-duty pieces, DiamondFinish Clear 1K Aerosol gives the same direct-to-metal formula in a spray can with no mixing. Both depend on proper surface prep to perform, covered step by step below.
- Why Clear Coat Fails on Metal
- What the Best Clear Coat for Metal Needs to Do
- Best Clear Coat System for Bare Metal and Rust Patina
- Materials and Tools Needed
- How to Properly Prepare Metal Before Applying Clear Coat
- How to Apply Clear Coat to Metal
- How to Maintain Clear Coated Metal
- Frequently Asked Questions
- Protecting Metal While Preserving Its Appearance
Clear coat fails on metal most often because the surface was not prepped correctly or the product was never designed for direct-to-metal use in the first place. A coating that looks fine going on can still peel, yellow, haze, or crack within a season if the metal underneath was not clean, dry, and properly profiled first.
Peeling and Flaking
Oils, waxes, oxidation, smooth polished metal, loose rust, or poor surface profiling can prevent the clear coat from bonding properly, and peeling or flaking is usually the first sign something in the prep was skipped.
Yellowing
Yellowing shows up most in clear coats that were never built for long-term UV exposure.
Cloudiness or Hazing
Cloudiness or hazing develops when moisture gets trapped under or inside the coating during application.
Rust Creep
Rust creep happens when moisture works its way under the coating through scratches, chips, cracks, pinholes, or edges that were not sealed properly.
Cracking
Cracking sets in when a coating turns brittle from UV exposure, too much film thickness, or a cure that did not go right.
A clear coat built for metal has to do five things at once: bond strongly to the surface, block moisture and corrosion, resist UV, flex with the metal, and stand up to chemicals, abrasion, and heat.
Strong Adhesion
Poor adhesion is one of the leading causes of coating failure. Bare metal, polished metal, and rust patina all need a clear coat that bonds strongly to that specific surface.
Moisture and Corrosion Resistance
A high-quality clear coat forms a non-porous barrier that isolates metal from water, oxygen, and contaminants.
UV Stability
Many clear coats eventually yellow, chalk, fade, or lose gloss under prolonged sunlight and outdoor weathering.
Flexibility and Crack Resistance
Metal expands and contracts with temperature swings and vibration, and a coating that turns brittle over time is more likely to crack under that movement.
Chemical, Abrasion, and Heat Resistance
Metal surfaces regularly take impacts, chemicals, road debris, abrasion, harsh cleaners, and elevated temperatures, so the coating has to handle all of it without breaking down.
The two-step system of KBS Klean and DiamondFinish Clear works for preparing and sealing both bare metal and rust patina surfaces.
KBS Klean is a water-based cleaner and degreaser that removes oils, grease, grime, and contamination that can interfere with coating adhesion.
DiamondFinish Clear is a 1K moisture-cured urethane for projects that need maximum durability and long-term outdoor protection.
DiamondFinish Clear Aerosol is a single-component acrylic resin clear coat spray, a convenient option for indoor and lighter-duty outdoor jobs.
Clear coating metal takes one cleaner, one clear coat, and a short list of prep tools.
- KBS Klean
- DiamondFinish Clear or DiamondFinish Clear 1K Aerosol
- Bucket for mixing KBS Klean
- KBS #1 Thinner, for reducing DiamondFinish Clear if spraying
- Wire brush, wire wheel, or 600-grit sandpaper
- Soft non-abrasive cleaning pad
- Paint brushes, rollers, or spray equipment
- Lint-free cloths or compressed air for drying
Most clear coat failures on metal start during prep, not from the clear coat itself. Getting the surface clean, profiled, and dry is the single biggest factor in how long the finish lasts.
How to Prepare Bare Metal for Clear Coat
Step 1: Remove Oxidation or Surface Rust. Use a wire brush or 600-grit sandpaper to remove oxidation, surface rust, or contamination.
Step 2: Clean the Surface with KBS Klean. Clean with KBS Klean to remove grease, grime, and other contaminants without leaving a residue that hurts adhesion.
- For ferrous metals, mix 10 parts hot water to 1 part KBS Klean
- For non-ferrous metals, mix 25 parts hot water to 1 part KBS Klean
- Scrub with a soft non-abrasive cleaning pad
- Rinse immediately and do not let the cleaner dry on the surface
- Dry the surface thoroughly to prevent flash rust
- Full directions: View full KBS Klean directions
Step 3: Sand or Polish as Needed. Polish or sand the metal to the finish required.
Step 4: Final Cleaning and Drying. Do a final cleaning with KBS Klean and dry thoroughly with lint-free cloths or compressed air.
How to Prepare Rusted or Patina Metal for Clear Coat
Step 1: Remove Loose Rust. Remove flaky or powdery rust with a wire brush, 600-grit or finer sandpaper, or a red Scotch-Brite pad.
Step 2: Clean the Surface.
- Mix KBS Klean with hot water at 10 parts hot water to 1 part KBS Klean
- Rinse immediately and do not let the solution dry on the surface
- Use compressed air or lint-free cloths to dry the surface thoroughly
DiamondFinish Clear goes on in at least 2 thin coats between 50 and 82 degrees F, once the metal is prepped and dry.
Tips for Applying DiamondFinish Clear 1K
- Apply in temperatures between 50 and 82 degrees F
- Apply only in moderate to dry conditions
- Stir gently and thoroughly before use
- When spraying, thin with KBS #1 Thinner or Xylene
- Apply at least 2 thin coats for general use
- Apply at least 3 thin coats for marine, industrial, wet, or maximum rust protection applications
- Avoid puddling and pooling
- Let the coating fully cure before exposing it to abrasion or harsh conditions
- Full directions: View full DiamondFinish Clear directions
Tips for Applying DiamondFinish Clear 1K Aerosol
- Apply when surface and air temperatures are between 50 and 85 degrees F
- Apply only in moderate to dry conditions with 70 percent humidity or lower
- Shake the can for at least one minute after the mixing ball starts to rattle
- Hold the can 8 to 12 inches from the surface
- Spray in light, even, overlapping strokes
- Apply multiple thin coats instead of fewer thick ones
- Full cure is usually reached within 48 hours
- Full directions: View full DiamondFinish Clear 1K Aerosol directions
Clear coated metal holds up longest with routine cleaning and quick attention to damage, not a heavy maintenance schedule.
Keep the Surface Clean
Regularly remove dirt, road salt, and contaminants that can hold moisture against the coating surface.
Inspect High-Wear Areas
Periodically check areas exposed to impacts, abrasion, or harsh environments for chips or damage.
Clean Spills and Chemicals Promptly
Cleaning spills promptly helps maintain the coating's long-term appearance.
Minimize Standing Moisture
Avoid prolonged exposure to standing water or consistently damp environments whenever possible.
Frequently Asked Questions About Clear Coating Metal
Can DiamondFinish Clear be applied directly to metal?
Yes. DiamondFinish Clear is formulated to be applied direct to metal without a separate primer step.
Does DiamondFinish Clear yellow over time?
No. DiamondFinish Clear is an exterior-grade, UV-stable clear coat designed to resist yellowing, chalking, and fading.
How long does DiamondFinish Clear take to cure?
DiamondFinish Clear can be recoated in 2 to 4 hours and reaches full cure in approximately 7 days.
How many coats of DiamondFinish Clear should I apply?
For most applications, 2 to 3 thin coats provide the best results.
Is DiamondFinish Clear heat resistant?
Yes. DiamondFinish Clear withstands continuous temperatures up to 300 degrees F without yellowing or degrading.
A durable, long-lasting clear coated metal finish comes from proper surface prep, a UV-stable coating built for metal, and correct application. KBS Klean cleans and prepares the surface for strong adhesion, DiamondFinish Clear provides a tough, flexible moisture-cured finish for maximum durability, and DiamondFinish Clear 1K Aerosol covers smaller or lighter-duty projects. All three protect bare metal, polished metal, and rust patina surfaces while keeping their appearance intact.
