Engine Paint and Exhaust Paint: Motor Coater to 500°F, XTC to 1500°F
Engine paint is a heat-resistant enamel or coating chosen by how hot the part runs. KBS Motor Coater is a single-component engine enamel rated to 500°F in 42 OEM-matched colors, for blocks, transmissions and brake calipers. KBS XTC is a silicone high temperature coating for headers, manifolds and exhaust, rated to 1500°F as a liquid and 1200°F as an aerosol.
Which Engine or Exhaust Paint Do I Need?
Match the paint to the hottest surface you are coating, not to the engine bay as a whole.
| Your part | Choose | What you get |
| Engine block, heads, transmission or brake calipers | Motor Coater | Engine enamel rated to 500°F, bonds direct to metal, 42 OEM colors |
| Exhaust headers, manifolds, pipes, turbo housings, wood stoves or grills | XTC | Liquid runs 500°F to 1500°F, aerosol to 1200°F; not for cooking surfaces |
| Bare or rusty metal that runs hot | XTC Zinc Rich Primer | Zinc primer rated to 1200°F; topcoat with XTC for a 1500°F system |
| Engine paint with the prep products included | Motor Coater Kit | KBS Klean, RustBlast and Motor Coater in one 3 step kit |
Still deciding? Motor Coater directions | XTC directions | Ask an expert
Watch the Motor Coater engine paint kit video
$28.00
(162)
$24.00
(210)
$25.00
(24)
$24.00
(4)
$66.00
(48)
$66.00
(3)
