RustSeal Safety Colors for Industrial Equipment and Floor Markings
Safety colors for industrial equipment and floor markings enhance visibility, identify hazards, and reinforce workplace safety — but only if the paint itself holds up. Industrial safety paint must resist corrosion, abrasion, impacts, and chemical exposure while maintaining a sharp, visible appearance over years of use. RustSeal by KBS Coatings is formulated to meet that challenge and is available in a range of OSHA-compliant safety colors for industrial applications.
Available in Safety Yellow, Safety Blue & Safety Green. RustSeal is a single-part coating — no mixing, no pot life. Shop RustSeal Safety Colors →
What Makes RustSeal the Right Safety Color Paint?
RustSeal is an advanced, moisture-cured coating engineered to seal surfaces and permanently prevent rust and corrosion. As a single-part (1K) product, it requires no mixing and no activator — just open, apply, and let the ambient humidity do the work. It flows out to a hard, ceramic-like finish that is highly resistant to chipping, scratching, cracking, and peeling. RustSeal also bonds strongly to porous surfaces like concrete, making it a true multi-surface solution for industrial environments.
Key performance characteristics that make RustSeal ideal for safety color applications:
  • Adheres directly to clean bare metal, concrete, fiberglass, ceramic, and most plastics
  • Impervious to most industrial chemicals, fuels, and solvents
  • Can be applied by brush, roller, or spray equipment — minimizing downtime on large projects
  • Meets OSHA Safety Color standards in Safety Yellow, Safety Blue, and Safety Green
  • Seals concrete floors from moisture, oil, and contaminants
OSHA Safety Color Standards: What Each Color Means
The following color assignments align with OSHA 29 CFR 1910.144 and ANSI Z535 safety color standards. Using the correct color for each application is not just best practice — in many facilities, it is a compliance requirement.
  • Safety Red: Fire protection equipment, emergency shutdown controls, and prohibition signage.
  • Safety Yellow: Caution, physical hazard warnings, and attention-demanding markings.
  • Safety Orange: Warning of dangerous parts of machinery or equipment that may cut, crush, or cause injury.
  • Safety Blue: Informational markings, non-hazardous areas, safe pathways, and emergency equipment locations.
  • Safety Green: Safe routes, emergency exit locations, first aid stations, and general safety information.
Indoor Industrial Equipment Applications
RustSeal Safety Color paint is well-suited for protecting and identifying a wide range of indoor industrial equipment. Below are the most common categories.
Lifting and Material Handling Equipment
Forklifts, pallet jacks, cranes, scissor lifts, and electric tuggers are high-traffic items that take constant physical abuse. Coating these with RustSeal in Safety Red or Safety Yellow keeps them highly visible while protecting the metal from rust caused by condensation, spills, and wash-down water.
Safety Barriers and Guardrails
Guardrails, crash barriers, retractable safety barriers, warehouse rack guards, and handrails need to be immediately recognizable and long-lasting. RustSeal in Safety Yellow, Safety Orange, or Safety Red resists impacts and abrasion while maintaining a bright, compliant finish.
Pipe and Valve Marking
Color-coded pipe and valve systems help workers quickly identify media type, flow direction, and hazard level. Safety Blue, Safety Green, and Safety Yellow are the most commonly used colors in piping identification systems following ASME A13.1 conventions.
Storage and Shelving Systems
Pallet racking, bulk storage racks, industrial cabinets, and drawer units coated with RustSeal in Safety Blue or Safety Green are easy to identify and protected against the moisture and oxidation common in warehouse environments.
Emergency Stop Controls
Emergency stop buttons and control panels on manufacturing equipment must be Safety Red — no exceptions. RustSeal's chip-resistant, ceramic-like finish ensures that color stays visible even on equipment subject to frequent contact and vibration.
RustSeal Safety Color Paint
Single-part moisture-cured coating. No mixing. Brush, roll, or spray. OSHA-compliant Safety Yellow, Safety Blue, and Safety Green. Bonds to metal, concrete, fiberglass, and more.
Shop RustSeal →
Floor Marking Applications
RustSeal Safety Colors double as durable floor marking paint. Unlike tape or standard floor paint, RustSeal bonds directly to concrete and cures to a hard, chemical-resistant surface that holds up to forklifts, foot traffic, and wash-down chemicals.
Fire Equipment and Danger Zones
Red floor markings designate fire extinguisher stations, hose cabinets, and areas with immediate danger. Use Safety Red.
Conveyor and Loading Zone Markings
Define loading zones, emergency stop points, and areas where personnel should exercise caution around conveyor systems. Use Safety Yellow.
Non-Hazardous and Low-Risk Areas
Clearly designate zones where safety precautions are reduced and activities carry lower risk. Use Safety Blue.
Wayfinding and Informational Guidance
Direct employees to emergency exits, AED locations, and safety equipment stations. Use Safety Blue.
First Aid and Emergency Stations
Mark first aid kits, eyewash stations, emergency showers, and safety-related equipment. Use Safety Green.
Traffic Lanes and Pedestrian Walkways
Define forklift traffic lanes, pedestrian walkways, and general housekeeping areas to reduce accidents and improve facility flow. Commonly used colors include Safety Yellow, white, and black.
RustSeal Safety Colors: Protection That Lasts as Long as the Marking
A safety color is only effective if it stays visible. RustSeal creates an abrasion-resistant, chemical-resistant surface that maintains its appearance under the daily abuse of an active industrial facility. On metal, it seals out moisture and oxygen to permanently block rust. On concrete, it seals against moisture, oil, and chemical contamination. Because RustSeal bonds to so many surfaces — metal, concrete, fiberglass, plastic, and ceramic — it can serve as a single-product safety color solution across an entire facility.
Need Safety Colors in an Aerosol?
For touch-ups, small equipment, or situations where spray equipment is not practical, KBS Top Coater Aerosol is available in safety colors and adheres well to surfaces pre-cleaned with KBS Klean. Keep a few cans on the shelf for fast maintenance touchups that keep your safety markings looking sharp and compliant.
Ready to Put Safety Color to Work?
RustSeal is in stock and ships fast. Orders over $75 ship free to the contiguous US.
Have Questions?
Have questions about using RustSeal Safety Colors for industrial equipment or floor markings? Contact the KBS Coatings team — we're real people ready to help you select the right product and application method for your facility.
