Posted by KBS Coatings on 4/18/2013 to
Remember Your Lawnmowers!
Pick a glossy finish like Gloss Black RustSeal for the slickest surface and watch the grass fall right off and not clog up your mower. Because the underside of most mower decks is coarse, we always apply at least 3 thin coats for this application.
