The Ultimate System Sampler Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 12.5 square foot area.
The Ultimate System Sampler Kit also contains Cavity Coater Aerosol and Cavity Wand which is the Perfect Solution for hard to reach areas that are prone to rusting!
RustSeal is a paint that acts as a total rust inhibitor and preventive.
RustSeal features very good spreadability. RustSeal chemically bonds to rusted steel to form a rock-hard, non-porous coating that won't crack chip, or peel.
RustSeal works by isolating metal from moisture. Without moisture present, steel can't rust.
RustSeal is a non-porous, flexible coating that is incredibly tough and extremely resistant to abrasion and impact.
RustSeal is highly surface tolerant and capable of adhering to almost any prepared surface.
*Click HERE for more information on which color of RustSeal you should use. NOTE: Some colors of RustSeal are only available in select sizes.
The Ultimate System Sampler Kit seals 12.5 sq. ft. with two coats of RustSeal.
4.8
