Need a beautiful, and incredibly durable protective coating? Check out BlackTop, which is an easy-to-use, one-part, single stage, and highly UV stable moisture cured coating. Its excellent flow out and self-leveling provides a smooth, beautiful, professional appearance whether applied with a brush, roller, or spray equipment.
BlackTop is a one-part coating, so no need to mix two components and being a single stage paint, there's no need for a separate clear coat. BlackTop is available in Gloss Black, OEM Satin Black, and Flat Black to provide just the right finish for your project.
BlackTop bonds directly to surfaces like prepared ferrous and non-ferrous metals, primed surfaces, other paints and coatings, wood, and cement. It’s also ideal for plastics including rigid and flexible. First, simply prime the surface with KBS Fusion Self Etching Primer or Fusion Flexible Plastics Primer.
BlackTop offers incredible adhesion and can be used as a standalone coating for strong rust prevention. And it can provide a beautiful finish with lifetime rust protection on surfaces that are first primed with RustSeal. Not all top coats are created equal.
While some are made to be durable or flexible, BlackTop is formulated to be both. KBS crossed-linked coatings technology makes BlackTop rock hard to withstand impacts and wear, and to be permanently flexible so it won't crack or peel. Keeping your project protected and looking great for a long time to come.
Some coatings lose their luster and degrade in the sun. However, BlackTop is designed for exterior use and is formulated to provide excellent UV stability to avoid the dulling and fading caused by prolonged sunlight exposure. BlackTop is incredibly durable and chemical resistant. Plus, it can handle high temperatures to 500°F.
Originally created for automotive chassis components, BlackTop can be used to provide a beautiful, durable, UV stable finish for other applications like:
- Car and truck bodies, bumpers, and trim
- Motorcycle frames
- Boat and utility trailers
- Industrial and agricultural applications
- Mailboxes
- Garage doors and shutters
- Wrought iron railings and steel fences
- Fire escapes
- Automotive rims
- Dump trucks and much more
If you want an easy-to-use coating that provides a beautiful, durable finish with incredible adhesion and UV stability, BlackTop is what you need.
Get More Info HERE.
