Coverage:
The Headlight Restore Kit should allow coverage of 4 or more average size headlight lenses.
1. Assess current headlight condition:
Although our KBS Headlight Restore Kit has been said to “perform miracles”, the condition of some lenses are beyond restoration and need to be replaced. Please evaluate your headlight lenses objectively before proceeding.
2. Klean and Scuff
Heavily oxidized lenses: sand the lens with 320 grit sandpaper (not included) to clean up the oxidation before you Klean and scuff. DiamondFinish Clear fills in the sanding marks.
In a proper container, mix 1 part KBS Klean with 10 parts hot water. Wearing gloves provided, dip scuff pad in Klean solution and Klean & scuff the entire headlight lens surface to remove any bugs, tar, wax, and/or road contaminants.
NOTE: Be careful not to scuff any surrounding painted or chromed surfaces. Rinse thoroughly with clean water. Repeat Klean as necessary. Using a clean & dry towel/cloth, dry lens surface to remove standing water to eliminate spotting. Allow lenses to air dry thoroughly.
3. Apply DiamondFinish Clear
NOTE: Do not apply in direct sunlight. Open can and stir contents thoroughly. DO NOT SHAKE. Using supplied brush(es), working from top to bottom & side to side, apply the first coat of DiamondFinish Clear brushing mainly in one direction. Do not over brush the coating. Avoid applying too heavy to avoid runs & drips.
DiamondFinish Clear is typically dry to the touch in 1 to 2 hours. Apply the second coat 2 to 4 hours after the first, once the first coat is dry to the touch and does not leave a fingerprint. A minimum of two coats is required. Allow the final coat to cure overnight before putting lenses back into service.
4. Clean Up
Use KBS #1 Thinner or lacquer thinner for immediate clean up.
IMPORTANT: Remember DiamondFinish Clear must be cleaned up before it dries. It cannot be removed by any solvent once cured. Always wear protective gloves to avoid skin contact. If skin contact accidentally occurs, immediately remove with #1 Thinner or lacquer thinner followed by soap and water.
Additional Information
Please review the DiamondFinish Clear Directions for more information on the application of DiamondFinish Clear.
