KBS UnderCoat is applied by cleaning the surface with KBS Klean, then spraying, brushing, or rolling a rubberized or asphalt-based coating onto wheel wells, gas tanks, frames, and floor pans. Apply light coats and allow 10 minutes between aerosol coats, or 2 hours between brush and roll coats. The coating is dry to the touch in 60 minutes and reaches full cure in 2 to 4 hours.
KBS UnderCoat Application: At a Glance
60 Min
Dry to Touch
2-4 Hrs
Full Cure
100-120 sq ft
Coverage per Gallon
3 Formulas
Solvent Rubberized, Water Asphalt, Solvent Asphalt
Description:
KBS UnderCoat provides protection in wheel wells, gas tanks, frames, and floor pans. It produces a tough, flexible film with excellent adhesion and helps prevent road salt from eating away at your car's metal and fiberglass. KBS UnderCoat offers excellent adhesion to metal or painted surfaces, provides moisture and corrosion resistance in a black finish, and helps deaden road noise and vibration.
For the ultimate rust protection, follow the KBS 3-Step System and treat bare metal areas with RustSeal before applying KBS UnderCoat. KBS UnderCoat has excellent adhesion to cured RustSeal.
Coverage:
Coverage varies by container size and by how smooth the surface is:
Size
Typical Coverage
Aerosol
16-20 sq ft
Quart
25-30 sq ft
Gallon
100-120 sq ft
5 Gallon Pail
500-600 sq ft
Surface Preparation:
Surfaces must be free of dirt, dust, oil, grease, and any contamination that may interfere with adhesion. Remove any loose paint, rust, oil, and grease. Use KBS Klean diluted 5:1 to clean the surface and ensure excellent adhesion. Allow the surface to dry thoroughly. Mask off the area to avoid overspray on the auto finish.
Aerosol Can Directions:
Shake the can for at least 60 seconds after the agitator ball moves freely. Hold the can 10 to 12 inches from the surface and apply a uniform coat. Apply light coats, waiting about 10 minutes between coats. The coating is dry to the touch in 60 minutes and reaches full cure in 2 to 4 hours.
Clean the spray head immediately after use by turning the can upside down and spraying until no more paint appears. If clogging occurs, remove the spray head and clean it with a fine wire. Replace it carefully, pointing the can and spray head away from you.
Bulk Can (Quart/Gallon) Spray Directions:
The surface should be clean and dry. Shake the can well before using.
KBS UnderCoat is applied with the Schutz Underseal Spray Gun or an auto body Schutz-style applicator gun. Contents may be poured into a clean container pot that fits your applicator gun. Thinning is not usually needed, but you can thin KBS UnderCoat with KBS #1 Thinner for solvent-based formulas or with water for the water-based formula. Excess coating may be removed with KBS #1 Thinner for solvent-based, or soap and water for water-based.
Bulk Can (Quart/Gallon) Brush/Roll Directions:
Mix thoroughly to ensure any settled pigment has been re-dispersed. For best appearance, apply using a high quality synthetic paint brush or synthetic roller. Do not use on surfaces that will be exposed to rain or moisture within 24 hours after application.
Dry and recoat times are based on 70°F (21°C) and 50% relative humidity. Allow more time at cooler temperatures. The first coat dries to touch in 1 to 2 hours. Apply the second coat after 2 hours. The Rubberized formula can be topcoated 24 hours after the second coat. The Asphalt formulas are not paintable, because asphalt typically bleeds through a topcoat. Allow a minimum of 24 hours to fully dry.
Cure Times:
Solvent-Based: For best results, use between 70°F and 90°F with 50% or less humidity. Apply light coats, waiting about 10 minutes between coats. The coating is dry to the touch in 60 minutes, with full cure in 2 to 4 hours.
Water-Based: For best results, use between 70°F and 90°F with 50% or less humidity. Apply light coats, waiting about 30 to 60 minutes between coats. Dry times vary based on temperature, humidity, and application rate; typical dry time is 30 to 60 minutes to the touch, with 24 hours to completely cure.
Clean-Up:
Solvent-Based: Clean KBS UnderCoat from the spray gun immediately after spraying with KBS #1 Thinner. Wipe excess KBS UnderCoat from any unintended surfaces immediately with KBS #1 Thinner. Properly discard the empty container.
Water-Based: Clean KBS UnderCoat from the spray gun immediately after spraying with KBS Klean diluted 1 to 1 with warm water. Wipe excess KBS UnderCoat from any unintended surfaces immediately with KBS Klean diluted 1 to 1 with warm water while wet, or with KBS #1 Thinner once dry.
Frequently Asked Questions: KBS UnderCoat
KBS UnderCoat is dry to the touch in 60 minutes and reaches full cure in 2 to 4 hours for the solvent-based formulas. The water-based formula is typically dry to the touch in 30 to 60 minutes and fully cures in about 24 hours. Dry and cure times are based on 70°F and 50% relative humidity; cooler or more humid conditions take longer.
Clean the surface first with KBS Klean diluted 5:1, then let it dry. From an aerosol can, hold it 10 to 12 inches from the surface and apply light, even coats about 10 minutes apart. From a quart or gallon, spray with a Schutz-style underseal gun, or apply by brush or roller in a single, even pass without overworking the coating.
No. KBS UnderCoat is a rubberized or asphalt-based coating formulated specifically for underbody protection, not a diluted topcoat. It is designed to stay flexible after curing so it can absorb road vibration and resist stone chipping, while also sealing out moisture and road salt.
Mask off any area you do not want coated, since overspray can land on the auto finish, brake components, exhaust surfaces, driveshafts, and other moving parts. Do not apply KBS UnderCoat over components that generate significant heat, and keep it off rubber bushings, weatherstripping, and any surface that needs to stay flexible or friction-free.
The solvent-based rubberized and solvent-based asphalt formulas dry to the touch in 60 minutes with a 2 to 4 hour full cure, and clean up with KBS #1 Thinner. The water-based asphalt formula dries to touch in 30 to 60 minutes with a 24-hour full cure, and cleans up with KBS Klean diluted 1:1 with warm water while wet.
A primer is not required; KBS UnderCoat bonds to bare or painted metal and fiberglass on its own. For the best long-term rust protection on bare or rusted metal, treat the surface first with the KBS 3-Step System (KBS Klean, RustBlast, and RustSeal), then apply KBS UnderCoat over the cured RustSeal.
Still have questions about KBS UnderCoat? Our technical team is ready to help.
Get Instant Answers: KBS Support Desk Browse All KBS UnderCoat FAQs Contact Us for Technical Assistance
Order KBS UnderCoat: Sound-Deadening Rust Protection
