Clear Concrete Sealer Directions
KBS Hurricane Paint Mixer
KBS MAXX and MAXX Clear FAQs
Order KBS MAXX Clear
KBS MAXX Clear is applied by cleaning the surface with KBS Klean, mixing 3 parts Base to 1 part MAXX Activator, then brushing, rolling, or spraying at 1.5 to 2.0 mils DFT per coat. Apply between 45 and 110 degrees F. Touch dry is 30 minutes, recoat window runs 30 minutes to 3 days, and it is polishable at 24 hours with full cure at 7 days.
On This Page
Surface Preparation:
Clear Coating Over an Automotive Base Coat
Apply base coat as per the manufacturer's directions. Allow to dry, which is normally about one hour.
Note: If the surface being clear coated will be consistently exposed to sunlight, be sure your automotive base coat is UV stable.
Clear Coating Over Cured Coatings
Clean the surface with KBS Klean diluted 10 parts hot water to 1 part KBS Klean. If needed, scuff with 600 to 1200 grit sandpaper and repeat the cleaning process. Rinse and allow to thoroughly dry.
Note: If the surface being clear coated will be consistently exposed to sunlight, be sure your base coat is UV stable.
Clear Coating Bare Metals
For ferrous metals, clean with KBS Klean at a dilution rate of 10 parts hot water to 1 part KBS Klean (10% strength) using a soft non-abrasive cleaning pad. Rinse the KBS Klean solution immediately, making sure you do not let it sit on the surface and dry in a way that leaves water stains.
For aluminum, clean with KBS Klean at a dilution rate of 25 parts hot water to 1 part KBS Klean (4% strength) using a very soft non-abrasive cleaning pad. Wipe the surface and do not soak. Rinse the KBS Klean solution immediately, making sure you do not let it sit on the surface and dry in a way that leaves water stains.
Clear Coating Wood
Wood surfaces should be smooth and dry with the wood having a low moisture content. Remove all existing failed coatings, sand smooth, and remove dust. Thin the initial coat of KBS MAXX Clear 30 to 50% with KBS #1 Thinner and apply a single covering coat to seal the wood. Allow to cure 24 hours. The wood will generally need to be sanded smooth again, since KBS MAXX Clear tends to raise the wood grain with the first coat. Sand the surface smooth with a fine grade of sandpaper (280 to 320). Apply at least one additional full coat for general applications, and a minimum of 3 coats for marine or industrial use.
Clear Coating Fiberglass or Carbon Fiber
Clean the surface with KBS Klean diluted 10 parts hot water to 1 part KBS Klean. Scuff with 600 to 1200 grit sandpaper and repeat the cleaning process. Rinse and allow to thoroughly dry.
Do not apply if the surface temperature is below 45°F or above 110°F, or if the surface temperature is within 5°F of the dew point. Always clean the surface well with KBS Klean. The surface should be free of all grease, dirt, oil, rust, and foreign material that would be detrimental to proper adhesion and the desired performance of the coating system being applied.
Questions about prepping your surface for KBS MAXX Clear?
Mixing and Mix Ratio:
Always mix KBS MAXX Clear Base thoroughly. Use of the KBS Hurricane Paint Mixer or a similar mechanical mixing blade attached to a variable speed drill is highly recommended.
After the KBS MAXX Clear Base has been mixed well and is smooth in consistency, in a mixing cup or container, carefully measure 3 parts mixed KBS MAXX Clear Base. Add 1 part MAXX Activator. Mix thoroughly, again using a mechanical mixer such as the KBS Hurricane Paint Mixer.
Only mix the amount you can apply within 30 minutes. You do not need to mix the entire kit at once. For example, if you bought a quart, measure out and mix only the Base and Activator you can use in 30 minutes, keeping the 3 to 1 ratio, and leave the rest unmixed.
KBS MAXX Clear Base and MAXX Activator are pre-thinned and ready to brush, roll, or spray, but you can add KBS #1 Thinner or Xylene as needed at this point, then mix well again with a mechanical mixer.
Application Characteristics:
Mix Ratio: 3:1 (Base Component : Activator)
Reducer: Ready to apply. KBS #1 Thinner or Xylene may be added if needed.
Pot Life: Doubles in viscosity in 30 minutes.
Dry Times:
Touch: 30 minutes
Through Dry: 1 to 2 hours
Hard: 3 to 4 hours
Recoat: 30 minutes to 3 days
Force Cure: Allow 15 minutes to flash, then 20 to 30 minutes at 140 to 180°F.
Full Cure: A function of time, temperature, and film build. This product will not reach full cure for 7 days.
Note: Testing performed at 77°F, approximately 70% relative humidity.
Application:
For optimum results, KBS MAXX Clear can be applied by brush or roller, or with spray equipment such as conventional electrostatic, conventional suction spray gun, HVLP, air assisted airless, or airless.
Brush and Roll: Use a poly bristle brush, high-density foam roller, or low nap mohair roller and reduce or thin with KBS #1 Thinner or Xylene. A poly bristle brush lays KBS MAXX Clear out smoother than a natural bristle brush. When brushing KBS MAXX Clear, for best results do not overwork the brush, as this can cause the coating to cure too quickly and leave visible brush marks. It is best to brush an area and move on immediately rather than brushing an area over and over again. Reworking an area forces the solvents out and risks the brush marks not flowing out as designed.
Note: The above parameters are guidelines only. Customer-specific equipment may require a different setup.
Clean Up:
KBS #1 Thinner, Xylene, or lacquer thinner for cleanup. KBS MAXX Clear must be cleaned up immediately, before it dries. Once cured, KBS MAXX Clear cannot be removed by any solvent. Wear protective gloves to avoid skin contact.
Dry Time / Cure:
Air Dry: Curing is a function of time, temperature, and film build. Air dry in 30 minutes to touch, thorough dry in 1 to 2 hours, dry hard in 3 to 4 hours. Tested at 77°F, approximately 70% relative humidity.
Note: The above information is a guideline for our customers. The user must be aware of the cleaning, pretreatment, application, and testing requirements for their specific job.
Questions about cure times or recoat windows for your project?
Technical Data:
Physical Properties
Chemical Resistance
Need a spec that isn't listed above, or a copy of the SDS?
Frequently Asked Questions: KBS MAXX Clear
More KBS MAXX Clear questions and answers: KBS MAXX and MAXX Clear FAQs
Still have questions about KBS MAXX Clear? Search our Support Desk or contact our technical team directly.
