The KBS 3 Step System Guide
Complete RustSeal Directions
KBS Klean Directions
RustBlast Directions
Can I Top Coat RustSeal?
RustBlast After Sandblasting?
RustSeal Tech Data Sheet
RustSeal Questions and Answers
RustSeal Instructional Videos
All Application Flow Charts
Order RustSeal
The RustSeal flow chart maps the KBS 3-Step System for steel. Unless the metal is freshly sandblasted with fresh sand, remove loose rust, clean with KBS Klean, etch with RustBlast, then brush or spray two coats of RustSeal. In direct sunlight, finish with an opaque, UV-stable topcoat such as BlackTop, KBS Top Coater, or KBS MAXX.
The RustSeal Flow Chart
Start at the top and follow the arrows. The yellow boxes are decisions: your answer tells you which way to go.
This flow chart is a general application guideline. It does not cover every application or environmental situation. If you still have questions, contact us for technical assistance.
Download the Printable Flow Chart (PDF)
Where Does Your Steel Start?
The only thing that changes between jobs is the starting point. Find your surface, then follow the chart from there.
It is not necessary to remove every trace of rust. RustSeal bonds to and permanently seals the tight rust that remains once the loose scale is gone.
Timing at Each Step
The RustBlast rinse does two jobs: it neutralizes the acid and it keeps a heavy zinc phosphate layer from building up. A slight white powder left afterward is a thin zinc phosphate coating that helps RustSeal adhere. Full details are in the KBS Klean Directions, RustBlast Directions, and RustSeal Directions.
Topcoat or Leave It?
RustSeal is not UV stable. Its rust protection does not degrade in sunlight, but its color and sheen will chalk and fade under prolonged direct UV. On frames, undercarriages, and anything else out of the sun, RustSeal is a durable, good-looking final finish on its own.
For sun-exposed work, topcoat with an opaque, UV-stable coating: BlackTop, KBS Top Coater, or KBS MAXX. Clear coats such as DiamondFinish Clear and KBS MAXX Clear let UV through to the RustSeal underneath, so they do not solve the fading. More in Can I Top Coat RustSeal?
Products in This Flow Chart
Frequently Asked Questions About the RustSeal Flow Chart
Still have questions about the RustSeal flow chart? Our technical team is ready to help.
More RustSeal questions and answers: RustSeal Questions
Get Instant Answers from the KBS Support Desk Contact Us for Technical AssistanceInstructional & How-To Videos
Watch more RustSeal videos on the KBS Instructional Videos page.
The Stop Rust Quart Kit includes KBS Klean, RustBlast, and RustSeal for about 50 square feet. For a full frame or up to 200 square feet, choose the Stop Rust Gallon Kit.
Shop the Stop Rust Quart Kit Shop the Stop Rust Gallon Kit
